LG BP640 – Can't reproduce .mkv file with DTS-HD MA
Hi all, I'm am a new – and newbie – member of this forum, so please apologize me if my topic lacks precision.
I began use Serviio with my BD Player BP640 and after turning off transcoding every file I sent to it (including .mkv) could rendered, even with .srt support, except one. This one has DTS-HD Master Audio audio track and it can be reproduced on the player from a USB drive. Here is its specification:
I use Serviio on a Macbook (late 2008) running Mac OS X 10.10.2
Here it is the log of the DLNA transmission:
Could someone help me? Thanks!
EDIT: Almost forgot, I'm using LG TV/ Player profile and I think the problem it's in there, because with Generic DNLA profile the file is reproduced, though it stutters (suppose it's transcoded),
- Code:
ffmpeg version 2.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Nov 26 2013 08:41:46 with llvm-gcc 4.2.1 (LLVM build 2336.11.00)
configuration: --prefix=/Volumes/Ramdisk/sw --enable-gpl --enable-pthreads --enable-version3 --enable-libspeex --enable-libvpx --disable-decoder=libvpx --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-avfilter --enable-libopencore_amrwb --enable-libopencore_amrnb --enable-filters --enable-libgsm --arch=x86_64 --enable-runtime-cpudetect
libavutil 52. 48.101 / 52. 48.101
libavcodec 55. 39.101 / 55. 39.101
libavformat 55. 19.104 / 55. 19.104
libavdevice 55. 5.100 / 55. 5.100
libavfilter 3. 90.100 / 3. 90.100
libswscale 2. 5.101 / 2. 5.101
libswresample 0. 17.104 / 0. 17.104
Input #0, matroska,webm, from '/Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).mkv':
title : RARBG.COM - Birdman.2014.1080p.BluRay.x264.DTS-HD.MA.5.1-RARBG
creation_time : 2015-02-06 10:50:55
Duration: 01:59:17.20, start: 0.000000, bitrate: 12746 kb/s
Chapter #0.0: start 0.000000, end 209.084000
title : 00:00:00.000
Chapter #0.1: start 209.084000, end 453.828000
title : 00:03:29.084
Chapter #0.2: start 453.828000, end 548.506000
title : 00:07:33.828
Chapter #0.3: start 548.506000, end 759.384000
title : 00:09:08.506
Chapter #0.4: start 759.384000, end 1013.429000
title : 00:12:39.384
Chapter #0.5: start 1013.429000, end 1147.146000
title : 00:16:53.429
Chapter #0.6: start 1147.146000, end 1222.096000
title : 00:19:07.146
Chapter #0.7: start 1222.096000, end 1521.186000
title : 00:20:22.096
Chapter #0.8: start 1521.186000, end 1905.028000
title : 00:25:21.186
Chapter #0.9: start 1905.028000, end 2169.834000
title : 00:31:45.028
Chapter #0.10: start 2169.834000, end 2232.772000
title : 00:36:09.834
Chapter #0.11: start 2232.772000, end 2529.444000
title : 00:37:12.772
Chapter #0.12: start 2529.444000, end 2929.802000
title : 00:42:09.444
Chapter #0.13: start 2929.802000, end 3210.541000
title : 00:48:49.802
Chapter #0.14: start 3210.541000, end 3511.341000
title : 00:53:30.541
Chapter #0.15: start 3511.341000, end 3797.085000
title : 00:58:31.341
Chapter #0.16: start 3797.085000, end 4109.147000
title : 01:03:17.085
Chapter #0.17: start 4109.147000, end 4362.567000
title : 01:08:29.147
Chapter #0.18: start 4362.567000, end 4621.450000
title : 01:12:42.567
Chapter #0.19: start 4621.450000, end 4845.090000
title : 01:17:01.450
Chapter #0.20: start 4845.090000, end 5113.984000
title : 01:20:45.090
Chapter #0.21: start 5113.984000, end 5284.946000
title : 01:25:13.984
Chapter #0.22: start 5284.946000, end 5602.472000
title : 01:28:04.946
Chapter #0.23: start 5602.472000, end 5954.949000
title : 01:33:22.472
Chapter #0.24: start 5954.949000, end 6190.726000
title : 01:39:14.949
Chapter #0.25: start 6190.726000, end 6403.856000
title : 01:43:10.726
Chapter #0.26: start 6403.856000, end 6736.855000
title : 01:46:43.856
Chapter #0.27: start 6736.855000, end 7157.195000
title : 01:52:16.855
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1040, SAR 1:1 DAR 24:13, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
title : Birdman.2014.1080p.BluRay.x264.DTS-HD.MA.5.1-RARBG
Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
- Code:
Unique ID : 242108031105395772978870869174621956343 (0xB6244F8943E8C0E5B0925647A0B5E8F7)
Complete name : /Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).mkv
Format : Matroska
File size : 10.6 GiB
Duration : 1h 59mn
Overall bit rate : 12.7 Mbps
Movie name : RARBG.COM - Birdman.2014.1080p.BluRay.x264.DTS-HD.MA.5.1-RARBG
Encoded date : UTC 2015-02-06 10:50:55
Writing application : mkvmerge v7.5.0 ('Glass Culture') 64bit built on Jan 4 2015 16:48:44
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 59mn
Nominal bit rate : 8 982 Kbps
Width : 1 920 pixels
Height : 1 040 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.188
Title : Birdman.2014.1080p.BluRay.x264.DTS-HD.MA.5.1-RARBG
Writing library : x264 core 144 r2525 40bb568
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8982 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Format : DTS
Format profile : MA / Core
Mode : 16
Codec ID : A_DTS
Duration : 1h 59mn
Bit rate mode : Variable
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:03:29.084 : en:00:03:29.084
00:07:33.828 : en:00:07:33.828
00:09:08.506 : en:00:09:08.506
00:12:39.384 : en:00:12:39.384
00:16:53.429 : en:00:16:53.429
00:19:07.146 : en:00:19:07.146
00:20:22.096 : en:00:20:22.096
00:25:21.186 : en:00:25:21.186
00:31:45.028 : en:00:31:45.028
00:36:09.834 : en:00:36:09.834
00:37:12.772 : en:00:37:12.772
00:42:09.444 : en:00:42:09.444
00:48:49.802 : en:00:48:49.802
00:53:30.541 : en:00:53:30.541
00:58:31.341 : en:00:58:31.341
01:03:17.085 : en:01:03:17.085
01:08:29.147 : en:01:08:29.147
01:12:42.567 : en:01:12:42.567
01:17:01.450 : en:01:17:01.450
01:20:45.090 : en:01:20:45.090
01:25:13.984 : en:01:25:13.984
01:28:04.946 : en:01:28:04.946
01:33:22.472 : en:01:33:22.472
01:39:14.949 : en:01:39:14.949
01:43:10.726 : en:01:43:10.726
01:46:43.856 : en:01:46:43.856
01:52:16.855 : en:01:52:16.855
- Code:
2015-02-27 17:08:59,896 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.1 (rev. 9d3f18af690f)
2015-02-27 17:08:59,896 INFO [MediaServer] Petr Nejedly 2009-2015
2015-02-27 17:08:59,896 INFO [MediaServer] http://www.serviio.org
2015-02-27 17:08:59,896 INFO [MediaServer] Java 1.8.0_31-Oracle Corporation x86_64
2015-02-27 17:08:59,898 INFO [MediaServer] OS Mac OS X 10.10.2
2015-02-27 17:08:59,898 INFO [MediaServer] File encoding: UTF-8
2015-02-27 17:08:59,899 INFO [MediaServer] Headless mode enabled: true
2015-02-27 17:08:59,899 INFO [MediaServer] User: root
2015-02-27 17:08:59,899 INFO [MediaServer] User home dir: /var/root
2015-02-27 17:08:59,899 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-02-27 17:09:58,574 DEBUG [ServiioHttpService] Incoming request from /192.168.0.36:58805: HEAD /resource/1/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.35:8895,Accept: */*,getcontentFeatures.dlna.org: 1]]
2015-02-27 17:09:58,575 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,577 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,585 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.36, Profile=LG TV / player'
2015-02-27 17:09:58,586 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'MEDIA_ITEM' received
2015-02-27 17:09:58,587 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2015-02-27 17:09:58,587 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2015-02-27 17:09:58,598 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:58,599 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1, format MATROSKA and profile LG TV / player
2015-02-27 17:09:58,604 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 11404021781,Content-Type: video/x-matroska,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Fri, 27 Feb 2015 16:09:58 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Streaming]]
2015-02-27 17:09:58,638 DEBUG [ServiioHttpService] Incoming request from /192.168.0.36:58806: GET /resource/1/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.35:8895,Accept: */*,Range: bytes=0-1023,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming]]
2015-02-27 17:09:58,638 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,639 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,641 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.36, Profile=LG TV / player'
2015-02-27 17:09:58,642 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'MEDIA_ITEM' received
2015-02-27 17:09:58,642 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2015-02-27 17:09:58,642 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2015-02-27 17:09:58,644 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:58,645 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1, format MATROSKA and profile LG TV / player
2015-02-27 17:09:58,645 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2015-02-27 17:09:58,645 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2015-02-27 17:09:58,646 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:58,647 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'Identifier=192.168.0.36, Profile=LG TV / player'
2015-02-27 17:09:58,647 DEBUG [VideoDeliveryEngine] Delivering file 'Birdman (2014).mkv' in native format
2015-02-27 17:09:58,648 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2015-02-27 17:09:58,648 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1) as read
2015-02-27 17:09:58,676 DEBUG [ServiioHttpService] Incoming request from /192.168.0.36:58807: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.0.35:8895,CONTENT-LENGTH: 417,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",USER-AGENT: LG-BDP Linux/2.6.35 UPnP/1.0 DLNADOC/1.50 LGE_DLNA_SDK/1.5.0]]
2015-02-27 17:09:58,676 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,677 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.36
2015-02-27 17:09:58,677 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,682 DEBUG [ContentDirectory] Browse() called for renderer LG BDP (profile 8) with parameters: objectID = V_T^INI_66^V_1, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 1, sortCriteria =
2015-02-27 17:09:58,682 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2015-02-27 17:09:58,683 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2015-02-27 17:09:58,688 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-02-27 17:09:58,688 DEBUG [GETMethodProcessor] Stream entity has length: 1024
2015-02-27 17:09:58,689 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 1024,Content-Type: video/x-matroska,Cache-control: no-cache,Connection: close,Content-Range: bytes 0-1023/11404021781,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Fri, 27 Feb 2015 16:09:58 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Streaming]]
2015-02-27 17:09:58,696 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-02-27 17:09:58,714 DEBUG [ServiioHttpService] Incoming request from /192.168.0.36:58808: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.0.35:8895,CONTENT-LENGTH: 417,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",USER-AGENT: LG-BDP Linux/2.6.35 UPnP/1.0 DLNADOC/1.50 LGE_DLNA_SDK/1.5.0]]
2015-02-27 17:09:58,714 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,715 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.36
2015-02-27 17:09:58,715 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,722 DEBUG [ContentDirectory] Browse() called for renderer LG BDP (profile 8) with parameters: objectID = V_T^INI_66^V_1, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 1, sortCriteria =
2015-02-27 17:09:58,722 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2015-02-27 17:09:58,723 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2015-02-27 17:09:58,735 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-02-27 17:09:58,756 DEBUG [ServiioHttpService] Incoming request from /192.168.0.36:58809: POST /serviceControl HTTP/1.1, headers = [HOST: 192.168.0.35:8895,CONTENT-LENGTH: 417,CONTENT-TYPE: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",USER-AGENT: LG-BDP Linux/2.6.35 UPnP/1.0 DLNADOC/1.50 LGE_DLNA_SDK/1.5.0]]
2015-02-27 17:09:58,756 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,757 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.36
2015-02-27 17:09:58,757 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,764 DEBUG [ContentDirectory] Browse() called for renderer LG BDP (profile 8) with parameters: objectID = V_T^INI_66^V_1, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 1, sortCriteria =
2015-02-27 17:09:58,764 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2015-02-27 17:09:58,765 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2015-02-27 17:09:58,770 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2015-02-27 17:09:58,822 DEBUG [ServiioHttpService] Incoming request from /192.168.0.36:58810: GET /resource/1/SUBTITLE.srt HTTP/1.1, headers = [Host: 192.168.0.35:8895,Accept: */*,Range: bytes=0-]]
2015-02-27 17:09:58,823 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,824 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.36, Profile=LG TV / player'
2015-02-27 17:09:58,824 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'SUBTITLE' received
2015-02-27 17:09:58,826 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:58,827 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2015-02-27 17:09:58,828 DEBUG [SubtitlesService] Found external subtitle file: /Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).srt
2015-02-27 17:09:58,829 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 1
2015-02-27 17:09:58,829 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:58,830 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2015-02-27 17:09:58,831 DEBUG [SubtitlesService] Found external subtitle file: /Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).srt
2015-02-27 17:09:58,831 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 1
2015-02-27 17:09:58,832 DEBUG [GETMethodProcessor] Stream entity has length: 130335
2015-02-27 17:09:58,832 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 130335,Content-Type: text/srt,Cache-control: no-cache,Connection: close,Content-Range: bytes 0-130334/130335,Date: Fri, 27 Feb 2015 16:09:58 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2015-02-27 17:09:58,885 DEBUG [WebServer] I/O error: Broken pipe
2015-02-27 17:09:58,886 DEBUG [ServiioHttpService] Incoming request from /192.168.0.36:58811: GET /resource/1/SUBTITLE.srt HTTP/1.1, headers = [Host: 192.168.0.35:8895,Accept: */*,Range: bytes=0-32255]]
2015-02-27 17:09:58,886 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,887 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,888 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.36, Profile=LG TV / player'
2015-02-27 17:09:58,888 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'SUBTITLE' received
2015-02-27 17:09:58,888 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:58,889 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2015-02-27 17:09:58,890 DEBUG [SubtitlesService] Found external subtitle file: /Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).srt
2015-02-27 17:09:58,890 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 1
2015-02-27 17:09:58,895 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:58,897 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2015-02-27 17:09:58,898 DEBUG [SubtitlesService] Found external subtitle file: /Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).srt
2015-02-27 17:09:58,898 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 1
2015-02-27 17:09:58,898 DEBUG [GETMethodProcessor] Stream entity has length: 32256
2015-02-27 17:09:58,899 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 32256,Content-Type: text/srt,Cache-control: no-cache,Connection: close,Content-Range: bytes 0-32255/130335,Date: Fri, 27 Feb 2015 16:09:58 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2015-02-27 17:09:58,966 DEBUG [ServiioHttpService] Incoming request from /192.168.0.36:58812: GET /resource/1/SUBTITLE.srt HTTP/1.1, headers = [Host: 192.168.0.35:8895,Accept: */*,Range: bytes=0-32255]]
2015-02-27 17:09:58,967 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,968 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:58,968 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.36, Profile=LG TV / player'
2015-02-27 17:09:58,968 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'SUBTITLE' received
2015-02-27 17:09:58,968 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:58,970 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2015-02-27 17:09:58,971 DEBUG [SubtitlesService] Found external subtitle file: /Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).srt
2015-02-27 17:09:58,971 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 1
2015-02-27 17:09:58,971 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:58,972 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2015-02-27 17:09:58,973 DEBUG [SubtitlesService] Found external subtitle file: /Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).srt
2015-02-27 17:09:58,973 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 1
2015-02-27 17:09:58,973 DEBUG [GETMethodProcessor] Stream entity has length: 32256
2015-02-27 17:09:58,973 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 32256,Content-Type: text/srt,Cache-control: no-cache,Connection: close,Content-Range: bytes 0-32255/130335,Date: Fri, 27 Feb 2015 16:09:58 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2015-02-27 17:09:59,030 DEBUG [ServiioHttpService] Incoming request from /192.168.0.36:58813: GET /resource/1/SUBTITLE.srt HTTP/1.1, headers = [Host: 192.168.0.35:8895,Accept: */*,Range: bytes=0-32255]]
2015-02-27 17:09:59,030 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:59,031 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.36
2015-02-27 17:09:59,032 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.36, Profile=LG TV / player'
2015-02-27 17:09:59,032 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'SUBTITLE' received
2015-02-27 17:09:59,032 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:59,033 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2015-02-27 17:09:59,034 DEBUG [SubtitlesService] Found external subtitle file: /Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).srt
2015-02-27 17:09:59,034 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 1
2015-02-27 17:09:59,034 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2015-02-27 17:09:59,035 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2015-02-27 17:09:59,036 DEBUG [SubtitlesService] Found external subtitle file: /Users/giammi29/Movies/Films/Birdman (2014)/Birdman (2014).srt
2015-02-27 17:09:59,036 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 1
