Subtitles work on LG TV but not on HT
Posted: Wed Dec 12, 2012 9:51 am
So I got this 42LM3450 TV which works pretty nice except for the DTS decoding, which is fine because I can play the same stuff with DTS on my HX352 (home theather). The problem is though, when I play files on my TV, I've got the external subtitles whereas they don't work on my home theater. So I checked the manual which says that it supports subrip (.srt) files and (I've translated this from Dutch): "To play a movie-file, the filename of the subtitles and the movie should be identical". Which to me implies that the system works with external subtitles (i have the names identical of course).
Now, to check my assumption, I've tried playing the same stuff with Nero Mediahome 4 and it works just fine. So I suppose it's a Serviio-problem. I tried converting the file to UTF-8 because it was ISO-8859-1 but it doesn't matter. SRTWiz doesn't change a bit in the file so that doesn't fix the problem either.
I put the debug log on pastebin: http://www.pastebin.ca/2291746
This is the mediainfo of the file: http://www.pastebin.ca/2291747
I'm running Ubuntu 12.04.
Hope someone can figure out what's wrong!
