Can i get the Freecom 2TB Datatank WLAN drives (and One USB
Can i get the Freecom 2TB Datatank WLAN drives (and One USB drive) to work?
I bought a couple of these a while back. They are very underused, but since I have grabbed this application, i am keen to put these to use.
http://www.trustedreviews.com/networkin ... LAN-2TB/p1
http://www.laptopsdirect.co.uk/Freecom_ ... ersion.asp
I had a quick look into these to learn these already run Twonky (pre installed). The strange this is, despite these having this application already installed to a tick box, you cannot connect them unless you can enter a password. The forums have already said, the set up i want is not possible with these drives, (TV sees them but cannot connect). Tried this originally a long time back through XboX360.
I know little about makeup/setup of these things. Am i able to change the configuration of these, install serviio and have no password.
Furthermore, the USB drive (also 2tb) needs software on whatever PC to see it.
Cheers……Q
Cheers……Q
