Serviio on QNap 459 Pro II
Hello Guys,
i am new with all this Linux stuff but spent yesterday several Hours to bring this Server to run. I used this Tutorial: viewtopic.php?f=14&t=2443 to install everything.
How far i get:
- I can start in Windows 7 the console and it will connect to the server
- My Phillips TV see this Server
My Problems:
- I added first in the Windows Tool a local File with a Address like //192.168.0.1/Disk1/Series -> But he dont find any content (nearly everything mkv)
- After restarting my QNap, the folder /opt/etc/init.d and all the Startupfiles are gone and Serviio does not start
- If i start Serviio manually like described, and close connection from console it seems that Servio shuts down
-> How do i add in the Windowstool a coorect Path like /share/HDA_DATA/Disk1/ -> he always adds C:\ when i save this path to the list? What is the difference between Local and Path Button in this Tool?
And my last Problem
Where do i find the Tutorial to install the Web UI for Serviio.
I get alwas some kind of Message : Required Serviio 0.5.2, but found ''. The Server is running.
Thanks for any Help
How far i get:
My Problems:
And my last Problem
Thanks for any Help
