Page 1 of 1
Serviio Not updating libraray
PostPosted: Tue Mar 27, 2012 3:47 am
by raulm753
Hi after much work and frustration i manage to install serviio on freebsd 9.0. Then I was able to connect to the server through the windows serviio-console. I set my shared folder to /tank/multimedia and nothing happens :(. I can see the server through windows media player but no video shows up. here is my log file
2012-03-26 22:56:59,819 INFO [MediaServer] ------------------------------------------------------------------------
2012-03-26 22:56:59,819 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2012-03-26 22:56:59,819 INFO [MediaServer] Petr Nejedly 2009-2011
2012-03-26 22:56:59,819 INFO [MediaServer] http://www.serviio.org
2012-03-26 22:56:59,819 INFO [MediaServer] Java 1.6.0_07-The FreeBSD Foundation
2012-03-26 22:56:59,819 INFO [MediaServer] OS FreeBSD amd64 9.0-RELEASE
2012-03-26 22:56:59,819 INFO [MediaServer] File encoding: ISO-8859-1
2012-03-26 22:56:59,820 INFO [MediaServer] Headless mode enabled: true
2012-03-26 22:56:59,820 INFO [MediaServer] User home dir: /nonexistent
2012-03-26 22:56:59,820 INFO [MediaServer] Temp dir: /var/tmp/
2012-03-26 22:56:59,820 INFO [MediaServer] ------------------------------------------------------------------------
2012-03-26 22:56:59,999 INFO [RestletServer] Starting Restlet server exposed on 192.168.0.9:23423
2012-03-26 22:57:00,047 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-03-26 22:57:01,175 INFO [WebServer] Socket buffer set to 65535 bytes
2012-03-26 22:57:01,175 INFO [Device] Created UPnP Device with UUID: 8eda6066-4ca3-3622-adc9-b1740bc8c845, bound address: 192.168.0.9
2012-03-26 22:57:01,211 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2012-03-26 22:57:01,218 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2012-03-26 22:57:01,228 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2012-03-26 22:57:01,228 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2012-03-26 22:57:01,237 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-26 22:57:01,237 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2012-03-26 22:57:01,237 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1332817021237, LastAccessTime = 1332817021237, getTimeToLiveSeconds() = -1, createTime = 1332817021237 ]
2012-03-26 22:57:01,257 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2012-03-26 22:57:01,257 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-26 22:57:01,258 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2012-03-26 22:57:01,258 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-26 22:57:01,258 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2012-03-26 22:57:01,258 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2012-03-26 22:57:01,258 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-26 22:57:01,258 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2012-03-26 22:57:01,258 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2012-03-26 22:57:01,258 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-26 22:57:01,258 INFO [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2012-03-26 22:57:01,258 INFO [CompositeCacheConfigurator] Finished configuration in 39 ms.
2012-03-26 22:57:01,475 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-03-26 22:57:01,751 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-03-26 22:57:01,904 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-03-26 22:57:01,979 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2012-03-26 22:57:02,053 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-03-26 22:57:02,114 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-03-26 22:57:02,176 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-03-26 22:57:02,311 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-03-26 22:57:02,334 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-03-26 22:57:02,543 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2012-03-26 22:57:02,833 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2012-03-26 22:57:02,949 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-03-26 22:57:03,058 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-03-26 22:57:03,090 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-03-26 22:57:03,107 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-03-26 22:57:03,161 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-03-26 22:57:03,186 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-03-26 22:57:03,245 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-03-26 22:57:03,448 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2012-03-26 22:57:03,633 INFO [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2012-03-26 22:57:03,711 INFO [PluginCompilerThread] Looking for plugins at /usr/local/share/java/classes/serviio/plugins
2012-03-26 22:57:03,711 INFO [PluginCompilerThread] Started looking for plugins
2012-03-26 22:57:04,415 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2012-03-26 22:57:04,418 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-03-26 22:57:04,436 INFO [WebServer] WebServer starting on port 8895
2012-03-26 22:57:04,439 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-26 22:57:04,439 INFO [EventDispatcher] Starting EventDispatcher
2012-03-26 22:57:04,440 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface re0 (re0) and address 192.168.0.9, timeout = 0
2012-03-26 22:57:04,440 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-26 22:57:04,443 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-26 22:57:04,443 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-03-26 22:57:30,456 INFO [FeedUpdaterThread] Started looking for information about online feeds
2012-03-26 22:57:30,456 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-26 22:57:30,463 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-03-26 23:02:05,434 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-03-26 23:02:05,439 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-03-26 23:02:06,073 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-03-26 23:14:49,667 INFO [WebServer] WebServer shutting down
2012-03-26 23:14:49,667 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-26 23:14:49,667 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-26 23:14:49,667 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-26 23:14:53,180 INFO [WebServer] WebServer starting on port 8895
2012-03-26 23:14:53,180 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-26 23:14:53,180 INFO [EventDispatcher] Starting EventDispatcher
2012-03-26 23:14:53,181 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-26 23:14:53,181 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-26 23:14:53,181 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface re0 (re0) and address 192.168.0.9, timeout = 0
2012-03-26 23:14:54,656 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-03-26 23:19:05,982 INFO [WebServer] WebServer shutting down
2012-03-26 23:19:05,982 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-26 23:19:05,983 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-26 23:19:05,982 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-26 23:19:23,939 INFO [WebServer] WebServer starting on port 8895
2012-03-26 23:19:23,939 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-26 23:19:23,939 INFO [EventDispatcher] Starting EventDispatcher
2012-03-26 23:19:23,939 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-26 23:19:23,939 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-26 23:19:23,939 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface re0 (re0) and address 192.168.0.9, timeout = 0
2012-03-26 23:31:59,056 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-03-26 23:31:59,156 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-03-26 23:31:59,257 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-26 23:31:59,258 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-03-26 23:32:22,068 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-03-26 23:32:22,168 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-03-26 23:32:22,269 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-26 23:32:22,270 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-03-26 23:37:04,335 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-03-26 23:37:04,435 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-03-26 23:37:04,536 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-26 23:37:04,537 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Re: Serviio Not updating libraray
PostPosted: Tue Mar 27, 2012 5:31 am
by moltra
Does the serviio user have access to the folder? Is the folder on the computer serviio is running on?. I would check permissions.
PostPosted: Tue Mar 27, 2012 12:29 pm
by raulm753
moltra wrote:Does the serviio user have access to the folder? Is the folder on the computer serviio is running on?. I would check permissions.
Im a noob when it comes to freebsd. I figure out how to change the user, still same behavior. The folder share that im trying to share has the permissions 777 and owned by nfs:nfs.
I also running transmission and samba and they can see the folder. I installed minidlna and it can see the folder and share them. So I dont know what wrong with serviio.
yes serviio has access to the folder
yes the folder is on the computer that serviio is running on.
rc.d/serviio
#!/bin/sh
D: ports/net/serviio/files/serviio.in,v 1.2 2012/01/14 08:56:27 dougb Exp $
# PROVIDE: serviio
# REQUIRE: LOGIN
# KEYWORD: shutdown
# Add the following line to /etc/rc.conf[.local] to enable serviio:
# pc5dczc_enable="YES"
. /etc/rc.subr
name=serviio
rcvar=pc5dczc_enable
command=/usr/local/sbin/serviiod
load_rc_config $name
pc5dczc_user=${pc5dczc_user-"nfs"}
_dirs="/var/db/serviio /var/log/serviio"
start_precmd="mkdir -p $_dirs; chown $pc5dczc_user $_dirs"
command_args="$pc5dczc_args &"
stop_cmd="$command -stop"
run_rc_command $1
etc/rc.conf
hostname="freebsd"
ifconfig_re0="DHCP"
sshd_enable="YES"
# Set dumpdev to "AUTO" to enable crash dumps, "NO" to disable
dumpdev="NO"
zfs_enable="YES"
samba_enable="YES"
winbindd_enable="YES"
transmission_enable="YES"
transmission_watch_dir="/tank/torrents"
transmission_download_dir="/tank/multimedia"
transmission_incomplete_dir="/tank/torrents/incomplete"
transmission_user="nfs"
transmission_conf_dir="/usr/local/etc/transmission/home"
pc5dczc_args="-Dserviio.remoteHost=192.168.0.9"
hald_enable="YES"
dbus_enable="YES"
minidlna_enable="NO"
this folder structure and permissions
freebsd# cd /tank/
freebsd# ls -l
total 19
drwxr-xr-x  2 nfs  nfs  2 Mar 25 23:24 family
drwxr-xr-x  2 nfs  nfs  2 Mar 25 23:23 finance
drwxrwxrwx  5 nfs  nfs  5 Mar 27 00:14 multimedia
drwxr-xr-x  2 nfs  nfs  2 Mar 25 23:23 software
drwxr-xr-x  3 nfs  nfs  3 Mar 26 03:34 torrents
latest log
2012-03-27 08:36:37,861 INFO  [MediaServer] ------------------------------------------------------------------------
2012-03-27 08:36:37,861 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2012-03-27 08:36:37,861 INFO  [MediaServer] Petr Nejedly 2009-2011
2012-03-27 08:36:37,861 INFO  [MediaServer] http://www.serviio.org
2012-03-27 08:36:37,861 INFO  [MediaServer] Java 1.6.0_07-The FreeBSD Foundation
2012-03-27 08:36:37,861 INFO  [MediaServer] OS FreeBSD amd64 9.0-RELEASE
2012-03-27 08:36:37,861 INFO  [MediaServer] File encoding: ISO-8859-1
2012-03-27 08:36:37,861 INFO  [MediaServer] Headless mode enabled: true
2012-03-27 08:36:37,861 INFO  [MediaServer] User home dir: /home/nfs
2012-03-27 08:36:37,861 INFO  [MediaServer] Temp dir: /var/tmp/
2012-03-27 08:36:38,040 INFO  [RestletServer] Starting Restlet server exposed on 192.168.0.9:23423
2012-03-27 08:36:38,080 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-03-27 08:36:39,225 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-03-27 08:36:39,225 INFO  [Device] Created UPnP Device with UUID: 8eda6066-4ca3-3622-adc9-b1740bc8c845, bound address: 192.168.0.9
2012-03-27 08:36:39,261 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2012-03-27 08:36:39,268 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2012-03-27 08:36:39,278 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2012-03-27 08:36:39,278 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2012-03-27 08:36:39,287 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-27 08:36:39,287 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2012-03-27 08:36:39,287 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1332851799287, LastAccessTime = 1332851799287, getTimeToLiveSeconds() = -1, createTime = 1332851799287 ]
2012-03-27 08:36:39,307 INFO  [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2012-03-27 08:36:39,307 INFO  [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-27 08:36:39,308 INFO  [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2012-03-27 08:36:39,308 INFO  [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-27 08:36:39,308 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2012-03-27 08:36:39,308 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2012-03-27 08:36:39,308 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-27 08:36:39,308 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2012-03-27 08:36:39,308 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2012-03-27 08:36:39,308 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-03-27 08:36:39,308 INFO  [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2012-03-27 08:36:39,308 INFO  [CompositeCacheConfigurator] Finished configuration in 39 ms.
2012-03-27 08:36:39,524 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-03-27 08:36:39,797 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-03-27 08:36:39,943 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-03-27 08:36:40,022 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2012-03-27 08:36:40,093 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-03-27 08:36:40,159 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-03-27 08:36:40,215 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-03-27 08:36:40,351 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-03-27 08:36:40,375 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-03-27 08:36:40,588 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2012-03-27 08:36:40,881 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2012-03-27 08:36:40,999 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-03-27 08:36:41,110 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-03-27 08:36:41,143 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-03-27 08:36:41,160 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-03-27 08:36:41,214 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-03-27 08:36:41,240 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-03-27 08:36:41,300 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-03-27 08:36:41,508 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2012-03-27 08:36:41,695 INFO  [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2012-03-27 08:36:41,761 INFO  [PluginCompilerThread] Looking for plugins at /usr/local/share/java/classes/serviio/plugins
2012-03-27 08:36:41,761 INFO  [PluginCompilerThread] Started looking for plugins
2012-03-27 08:36:42,482 WARN  [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2012-03-27 08:36:42,485 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-03-27 08:36:42,501 INFO  [WebServer] WebServer starting on port 8895
2012-03-27 08:36:42,504 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-27 08:36:42,504 INFO  [EventDispatcher] Starting EventDispatcher
2012-03-27 08:36:42,505 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-27 08:36:42,505 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface re0 (re0) and address 192.168.0.9, timeout = 0
2012-03-27 08:36:42,507 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-03-27 08:36:42,507 INFO  [RendererSearchSender] Searching for Renderer devices
2012-03-27 08:36:45,910 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-03-27 08:36:46,275 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-03-27 08:37:08,520 INFO  [FeedUpdaterThread] Started looking for information about online feeds
2012-03-27 08:37:08,520 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-27 08:37:08,524 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
