How to configure Toshiba Ragza to watch any movie
arekkul
Post Tue Jul 12, 2011 6:59 pm
hi,
I'd like to ask how to configure my Toshiba Regza TV to watch any video from my PC which has been conected with TV via Talk Talk router/hub.
I have installed Serviio on my PC, I have chosen Rendering Profile to Toshiba Ragza and I have configured my TV according manual guide and I don't know how can I watch on my TV any video from my PC.
can anybody help me please ?
cheers,
Arek :?:
Post Tue Jul 12, 2011 7:09 pm
Re: How to configure Toshiba Ragza to watch any movie
Have you added your video folders to serviio console so serviio can see them?
Can you post your serviio log?
arekkul
Post Tue Jul 12, 2011 7:19 pm
hi,
yes, I have added my video folders and serviio sees it but the main problem is why my TV can't connect with serviio ?
where can I find serviio log ?
cheers,Arek
Post Tue Jul 12, 2011 7:28 pm
it is in the directory that you installed serviio in under the log folder.
What is the IP address of the computer running serviio. What is the IP address of the TV you are trying to use serviio with?
arekkul
Post Tue Jul 12, 2011 7:31 pm
the log is :
2011-07-12 19:31:52,913 INFO [MediaServer] ------------------------------------------------------------------------
2011-07-12 19:31:52,914 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-07-12 19:31:52,914 INFO [MediaServer] Petr Nejedly 2009-2011
2011-07-12 19:31:52,914 INFO [MediaServer] http://www.serviio.org
2011-07-12 19:31:52,915 INFO [MediaServer]
2011-07-12 19:31:52,915 INFO [MediaServer] Java 1.6.0_03-Sun Microsystems Inc.
2011-07-12 19:31:52,915 INFO [MediaServer] OS Windows Vista x86 6.0
2011-07-12 19:31:52,915 INFO [MediaServer] File encoding: windows-1252
2011-07-12 19:31:52,915 INFO [MediaServer] ------------------------------------------------------------------------
2011-07-12 19:31:53,208 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-12 19:31:53,379 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-12 19:31:59,689 INFO [DBSchemaUpdateExecutor] Updating DB schema
2011-07-12 19:32:05,689 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-12 19:32:06,279 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-12 19:32:06,575 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-12 19:32:06,793 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-12 19:32:06,889 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-12 19:32:07,104 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-12 19:32:07,179 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-12 19:32:07,458 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-12 19:32:07,585 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-12 19:32:07,977 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-12 19:32:08,665 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-12 19:32:08,799 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-12 19:32:08,966 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-12 19:32:12,492 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-12 19:32:12,523 INFO [WebServer] Socket buffer set to 65535 bytes
2011-07-12 19:32:12,846 INFO [WebServer] WebServer starting on port 8895
2011-07-12 19:32:13,314 INFO [Device] Created UPnP Device with UUID: 83403509-60a4-3ac0-bae1-94340baf2344, bound address: 192.168.1.2
2011-07-12 19:32:13,439 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-12 19:32:13,447 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-12 19:32:13,451 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-12 19:32:13,452 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-12 19:32:13,454 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-12 19:32:13,454 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-12 19:32:13,454 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1310495533454, LastAccessTime = 1310495533454, getTimeToLiveSeconds() = -1, createTime = 1310495533454 ]
2011-07-12 19:32:13,456 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-12 19:32:13,477 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-12 19:32:13,477 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-12 19:32:13,477 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-12 19:32:13,477 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-12 19:32:13,477 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-12 19:32:13,477 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-12 19:32:13,477 INFO [CompositeCacheConfigurator] Finished configuration in 27 ms.
2011-07-12 19:32:13,482 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-12 19:32:13,489 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-12 19:32:13,489 INFO [EventDispatcher] Starting EventDispatcher
2011-07-12 19:32:13,504 INFO [RendererSearchSender] Searching for Renderer devices
2011-07-12 19:32:13,504 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-12 19:32:13,563 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Intel(R) PRO/Wireless 3945ABG Network Connection) and address 192.168.1.2, timeout = 0
2011-07-12 19:32:14,480 INFO [RendererManager] Stored a new renderer: uuid='3753b7bb-0021-4928-8fe7-8e9f17fda9ff', name = 'Unrecognized device', ipAddress='192.168.1.4', profile = '1'
2011-07-12 19:32:15,175 INFO [RendererManager] Stored a new renderer: uuid='7728bbf4-a04d-11de-9850-e89d87f18dd8', name = '40RV753', ipAddress='192.168.1.4', profile = '1'
2011-07-12 19:32:24,687 INFO [ServiioConsole] Starting Serviio Console
2011-07-12 19:32:27,949 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-12 19:32:29,406 INFO [Messages] Loaded console message bundle for locale: en
2011-07-12 19:32:30,296 INFO [Messages] Loaded console message bundle for locale: en
2011-07-12 19:32:30,415 INFO [UpdateChecker] Checking if a new version is available
2011-07-12 19:32:36,862 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-12 19:32:37,851 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-07-12 19:32:39,828 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-12 19:32:39,829 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-12 19:33:25,060 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-12 19:33:25,068 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-12 19:33:25,070 INFO [WebServer] WebServer shutting down
2011-07-12 19:33:25,070 INFO [EventDispatcher] Leaving EventDispatcher
2011-07-12 19:33:26,017 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-12 19:33:26,027 INFO [WebServer] WebServer starting on port 8895
2011-07-12 19:33:26,030 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-12 19:33:26,033 INFO [RendererSearchSender] Searching for Renderer devices
2011-07-12 19:33:26,033 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-12 19:33:26,031 INFO [EventDispatcher] Starting EventDispatcher
2011-07-12 19:33:26,089 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Intel(R) PRO/Wireless 3945ABG Network Connection) and address 192.168.1.2, timeout = 0
2011-07-12 19:33:28,507 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-07-12 19:34:04,344 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-12 19:34:04,584 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-12 19:34:04,586 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-12 19:34:05,735 INFO [LibraryAdditionsCheckerThread] Added file '215218_220645944616032_168820343131926_976386_7783335_n.jpg' (title: 215218_220645944616032_168820343131926_976386_7783335_n) to Library
2011-07-12 19:34:05,948 INFO [LibraryAdditionsCheckerThread] Added file '221987_220645551282738_168820343131926_976363_4987469_n.jpg' (title: 221987_220645551282738_168820343131926_976363_4987469_n) to Library
2011-07-12 19:34:06,109 INFO [LibraryAdditionsCheckerThread] Added file '222765_10150610430425607_895780606_18721335_978998_n.jpg' (title: 222765_10150610430425607_895780606_18721335_978998_n) to Library
2011-07-12 19:34:06,436 INFO [LibraryAdditionsCheckerThread] Added file '226331_10150610430120607_895780606_18721333_3553598_n.jpg' (title: 226331_10150610430120607_895780606_18721333_3553598_n) to Library
2011-07-12 19:34:06,602 INFO [LibraryAdditionsCheckerThread] Added file '226400_220645744616052_168820343131926_976375_5150953_n.jpg' (title: 226400_220645744616052_168820343131926_976375_5150953_n) to Library
2011-07-12 19:34:07,300 INFO [LibraryAdditionsCheckerThread] Added file '243794_10150610433935607_895780606_18721357_3552411_o.jpg' (title: 243794_10150610433935607_895780606_18721357_3552411_o) to Library
2011-07-12 19:34:07,464 INFO [LibraryAdditionsCheckerThread] Added file '258754_246317178715575_168820343131926_1111577_7482990_o.jpg' (title: 258754_246317178715575_168820343131926_1111577_7482990_o) to Library
2011-07-12 19:34:07,537 INFO [LibraryAdditionsCheckerThread] Added file 'folder.jpg' (title: folder) to Library
2011-07-12 19:34:53,410 INFO [ServiioConsole] Leaving Serviio Console
2011-07-12 19:35:00,733 INFO [LibraryAdditionsCheckerThread] Added file 'lpn.px264-gos.mkv' (title: lpn.px264-gos) to Library
2011-07-12 19:35:03,410 INFO [ServiioConsole] Starting Serviio Console
2011-07-12 19:35:03,600 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-12 19:35:04,481 INFO [Messages] Loaded console message bundle for locale: en
2011-07-12 19:35:05,303 INFO [Messages] Loaded console message bundle for locale: pl
2011-07-12 19:35:05,420 INFO [UpdateChecker] Checking if a new version is available
2011-07-12 19:35:47,458 INFO [LibraryAdditionsCheckerThread] Added file 'POTC.At.World's.End.2007.PL.720p.BluRay.x264-F35.mkv' (title: Pirates of the Caribbean: At World's End) to Library
2011-07-12 19:35:55,114 INFO [LibraryAdditionsCheckerThread] Added file 'Rio.2011.PLDUB.R5.MD.XviD.AC3-J25.avi' (title: Rio) to Library
2011-07-12 19:36:52,773 INFO [LibraryAdditionsCheckerThread] Added file 'Kod Niesmiertelnosci.mkv' (title: Source Code) to Library
2011-07-12 19:37:30,968 INFO [LibraryAdditionsCheckerThread] Added file 'Transformens.720p.mkv' (title: Transformens.720p) to Library
2011-07-12 19:37:31,496 INFO [LibraryAdditionsCheckerThread] Added file 'Unknown Artist - Track 5.mp3' (title: Unknown Artist - Track 5) to Library
2011-07-12 19:37:31,578 INFO [LibraryAdditionsCheckerThread] Added file 'Unknown Artist - Track 9.mp3' (title: Unknown Artist - Track 9) to Library
2011-07-12 19:37:31,893 INFO [LibraryAdditionsCheckerThread] Added file '01. The Carpenter And The Dainty Bride.mp3' (title: The Carpenter and the Dainty Bride) to Library
2011-07-12 19:37:32,033 INFO [LibraryAdditionsCheckerThread] Added file '02. Pilcher's Squad.mp3' (title: Pilcher's Squad) to Library
2011-07-12 19:37:32,159 INFO [LibraryAdditionsCheckerThread] Added file '03. Mary The Ice Cube.mp3' (title: Mary the Ice Cube) to Library
2011-07-12 19:37:32,333 INFO [LibraryAdditionsCheckerThread] Added file '04. The Last Superpower Rapscallion.mp3' (title: The Last Superpower aka Rapscallion) to Library
2011-07-12 19:37:32,458 INFO [LibraryAdditionsCheckerThread] Added file '05. My Friend Fats.mp3' (title: My Friend Fats) to Library
2011-07-12 19:37:32,522 INFO [LibraryAdditionsCheckerThread] Added file 'AlbumArtSmall.jpg' (title: AlbumArtSmall) to Library
2011-07-12 19:37:32,600 INFO [LibraryAdditionsCheckerThread] Added file 'AlbumArt_{9E6A74CF-63C2-4801-808C-096A62606E7A}_Large.jpg' (title: AlbumArt_{9E6A74CF-63C2-4801-808C-096A62606E7A}_Large) to Library
2011-07-12 19:37:32,641 INFO [LibraryAdditionsCheckerThread] Added file 'AlbumArt_{9E6A74CF-63C2-4801-808C-096A62606E7A}_Small.jpg' (title: AlbumArt_{9E6A74CF-63C2-4801-808C-096A62606E7A}_Small) to Library
2011-07-12 19:37:32,712 INFO [LibraryAdditionsCheckerThread] Added file 'Folder.jpg' (title: Folder) to Library
2011-07-12 19:37:32,862 INFO [LibraryAdditionsCheckerThread] Added file 'front.jpg' (title: front) to Library
2011-07-12 19:37:38,054 INFO [LibraryAdditionsCheckerThread] Added file 'Akademia Pana Kleksa CD1.avi' (title: Akademia Pana Kleksa CD1) to Library
2011-07-12 19:37:43,950 INFO [LibraryAdditionsCheckerThread] Added file 'Akademia Pana Kleksa CD2.avi' (title: Akademia Pana Kleksa CD2) to Library
2011-07-12 19:38:29,878 INFO [LibraryAdditionsCheckerThread] Added file 'AVATAR_720p_x264_BluRay.mkv' (title: Avatar) to Library
2011-07-12 19:38:34,563 INFO [LibraryAdditionsCheckerThread] Added file 'Barbie w swiecie mody 2010.avi' (title: Barbie w swiecie mody 2010) to Library
2011-07-12 19:38:39,851 INFO [LibraryAdditionsCheckerThread] Added file '[HellTorrents.com]-Dziewczyna.mojego.kumpla.PL.DVDRip.XviD.avi' (title: [HellTorrents.com]-Dziewczyna.mojego.kumpla.PL.DVDRip.XviD) to Library
2011-07-12 19:38:42,320 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_01_0.VOB' (title: Gulliver's Travels) to Library
2011-07-12 19:38:56,066 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_01_1.VOB' (title: Gulliver's Travels) to Library
2011-07-12 19:39:07,366 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_01_2.VOB' (title: Gulliver's Travels) to Library
2011-07-12 19:39:19,028 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_01_3.VOB' (title: Gulliver's Travels) to Library
2011-07-12 19:39:30,262 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_01_4.VOB' (title: Gulliver's Travels) to Library
2011-07-12 19:39:31,973 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_02_1.VOB' (title: Gulliver's Travels) to Library
2011-07-12 19:39:35,330 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_07_1.VOB' (title: Gulliver's Travels) to Library
2011-07-12 19:39:36,574 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_08_1.VOB' (title: Gulliver's Travels) to Library
2011-07-12 19:39:38,349 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_11_1.VOB' (title: Gulliver's Travels) to Library
2011-07-12 19:39:39,320 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_03_0.VOB' (title: VTS_03_0) to Library
2011-07-12 19:39:50,544 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_03_1.VOB' (title: VTS_03_1) to Library
2011-07-12 19:40:01,522 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_03_2.VOB' (title: VTS_03_2) to Library
2011-07-12 19:40:13,963 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_03_3.VOB' (title: VTS_03_3) to Library
2011-07-12 19:40:24,855 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_03_4.VOB' (title: VTS_03_4) to Library
2011-07-12 19:40:44,639 INFO [LibraryAdditionsCheckerThread] Added file 'VTS_03_5.VOB' (title: VTS_03_5) to Library
2011-07-12 19:40:47,769 INFO [LibraryAdditionsCheckerThread] Added file 'seven.jpg' (title: seven) to Library
2011-07-12 19:41:00,864 INFO [LibraryAdditionsCheckerThread] Added file 'Siedem - Lektor Pl..avi' (title: Siedem - Lektor Pl.) to Library
2011-07-12 19:41:14,481 INFO [LibraryAdditionsCheckerThread] Added file 'Season.of.the.Witch.2011.PL.480p.BRRip.XviD.AC3-ELiTE.avi' (title: Season of the Witch) to Library
2011-07-12 19:41:33,869 INFO [LibraryAdditionsCheckerThread] Added file 'The.Chronicles.Of.Riddick.2004.PL.TC.720p.BRRip.XviD.AC3-DustnWind.avi' (title: The Chronicles of Riddick) to Library
2011-07-12 19:42:16,778 INFO [LibraryAdditionsCheckerThread] Added file 'The.Kings.Speech.2010.720p.BluRay.X264-AMIABLE.mkv' (title: The King's Speech) to Library
2011-07-12 20:06:38,001 INFO [RendererManager] Stored a new renderer: uuid='d0b26f17-dd3d-46f1-876f-b06bcd769568', name = 'Windows Media Player', ipAddress='192.168.1.2', profile = '1'
2011-07-12 20:14:54,653 INFO [LibraryManager] Forcing metadata update for 'VIDEO' media files
2011-07-12 20:15:41,839 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-12 20:15:42,043 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-12 20:15:42,048 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-12 20:15:56,219 INFO [LibraryUpdatesCheckerThread] Updated 'Rio' (E:\DOWNLOADS\Rio.2011.PLDUB.R5.MD.XviD.AC3-J25.avi) in Library
2011-07-12 20:16:49,466 INFO [LibraryUpdatesCheckerThread] Updated 'lpn.px264-gos' (E:\DOWNLOADS\lpn.px264-gos.mkv) in Library
2011-07-12 20:17:34,050 WARN [LibraryManager] Cannot read metadata of file E:\DOWNLOADS\piraci3-f35\POTC.At.World's.End.2007.PL.720p.BluRay.x264-F35.mkv via extractor ONLINE_VIDEO_SOURCES. Message: Cannot retrieve movie search results: Server returned HTTP response code: 503 for URL: http://api.themoviedb.org/2.1/Movie.sea ... s+end+2007
2011-07-12 20:17:34,329 INFO [LibraryUpdatesCheckerThread] Updated 'Pirates of the Caribbean: At World's End' (E:\DOWNLOADS\piraci3-f35\POTC.At.World's.End.2007.PL.720p.BluRay.x264-F35.mkv) in Library
2011-07-12 20:18:27,963 INFO [LibraryUpdatesCheckerThread] Updated 'Source Code' (E:\DOWNLOADS\Source.Code.2011.PPV.720p.HDTV.x264-MOMENTUM.by.s202\Kod Niesmiertelnosci.mkv) in Library
2011-07-12 20:19:06,388 INFO [LibraryUpdatesCheckerThread] Updated 'Transformens.720p' (E:\DOWNLOADS\Transformens.720p\Transformens.720p.mkv) in Library
2011-07-12 20:19:12,124 INFO [LibraryUpdatesCheckerThread] Updated 'Akademia Pana Kleksa CD1' (E:\FILMY\Akademia Pana Kleksa CD1.avi) in Library
2011-07-12 20:19:20,013 INFO [LibraryUpdatesCheckerThread] Updated 'Akademia Pana Kleksa CD2' (E:\FILMY\Akademia Pana Kleksa CD2.avi) in Library
2011-07-12 20:20:05,269 INFO [LibraryUpdatesCheckerThread] Updated 'Avatar' (E:\FILMY\AVATAR_720p_x264_BluRay.mkv) in Library
2011-07-12 20:20:09,447 INFO [LibraryUpdatesCheckerThread] Updated 'Barbie w swiecie mody 2010' (E:\FILMY\Barbie w swiecie mody 2010.avi) in Library
2011-07-12 20:20:25,803 INFO [LibraryUpdatesCheckerThread] Updated 'The Chronicles of Riddick' (E:\FILMY\The.Chronicles.Of.Riddick.2004.PL.TC.720p.BRRip.XviD.AC3-DustnWind.avi) in Library
2011-07-12 20:21:12,991 INFO [LibraryUpdatesCheckerThread] Updated 'The King's Speech' (E:\FILMY\The.Kings.Speech.2010.720p.BluRay.X264-AMIABLE.mkv) in Library
2011-07-12 20:21:18,042 INFO [LibraryUpdatesCheckerThread] Updated '[HellTorrents.com]-Dziewczyna.mojego.kumpla.PL.DVDRip.XviD' (E:\FILMY\Dziewczyna.mojego.kumpla.PL.DVDRip.XviD\[HellTorrents.com]-Dziewczyna.mojego.kumpla.PL.DVDRip.XviD.avi) in Library
2011-07-12 20:21:20,214 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's Travels' (E:\FILMY\Gullivers.Travels.2010.PAL.DUBBING.PL.DVD5\VIDEO_TS\VTS_01_0.VOB) in Library
2011-07-12 20:21:30,872 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's Travels' (E:\FILMY\Gullivers.Travels.2010.PAL.DUBBING.PL.DVD5\VIDEO_TS\VTS_01_1.VOB) in Library
2011-07-12 20:21:42,274 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's Travels' (E:\FILMY\Gullivers.Travels.2010.PAL.DUBBING.PL.DVD5\VIDEO_TS\VTS_01_2.VOB) in Library
2011-07-12 20:21:53,138 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's Travels' (E:\FILMY\Gullivers.Travels.2010.PAL.DUBBING.PL.DVD5\VIDEO_TS\VTS_01_3.VOB) in Library
2011-07-12 20:22:04,239 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's Travels' (E:\FILMY\Gullivers.Travels.2010.PAL.DUBBING.PL.DVD5\VIDEO_TS\VTS_01_4.VOB) in Library
2011-07-12 20:22:05,672 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's Travels' (E:\FILMY\Gullivers.Travels.2010.PAL.DUBBING.PL.DVD5\VIDEO_TS\VTS_02_1.VOB) in Library
2011-07-12 20:22:08,118 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's Travels' (E:\FILMY\Gullivers.Travels.2010.PAL.DUBBING.PL.DVD5\VIDEO_TS\VTS_07_1.VOB) in Library
2011-07-12 20:22:09,465 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's Travels' (E:\FILMY\Gullivers.Travels.2010.PAL.DUBBING.PL.DVD5\VIDEO_TS\VTS_08_1.VOB) in Library
2011-07-12 20:22:10,916 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's Travels' (E:\FILMY\Gullivers.Travels.2010.PAL.DUBBING.PL.DVD5\VIDEO_TS\VTS_11_1.VOB) in Library
2011-07-12 20:22:11,291 INFO [LibraryUpdatesCheckerThread] Updated 'VTS_03_0' (E:\FILMY\Love\DVD\DVD5\VTS_03_0.VOB) in Library
2011-07-12 20:22:22,641 INFO [LibraryUpdatesCheckerThread] Updated 'VTS_03_1' (E:\FILMY\Love\DVD\DVD5\VTS_03_1.VOB) in Library
2011-07-12 20:22:33,302 INFO [LibraryUpdatesCheckerThread] Updated 'VTS_03_2' (E:\FILMY\Love\DVD\DVD5\VTS_03_2.VOB) in Library
2011-07-12 20:22:44,210 INFO [LibraryUpdatesCheckerThread] Updated 'VTS_03_3' (E:\FILMY\Love\DVD\DVD5\VTS_03_3.VOB) in Library
2011-07-12 20:22:55,491 INFO [LibraryUpdatesCheckerThread] Updated 'VTS_03_4' (E:\FILMY\Love\DVD\DVD5\VTS_03_4.VOB) in Library
2011-07-12 20:23:06,373 INFO [LibraryUpdatesCheckerThread] Updated 'VTS_03_5' (E:\FILMY\Love\DVD\DVD5\VTS_03_5.VOB) in Library
2011-07-12 20:23:12,442 INFO [LibraryUpdatesCheckerThread] Updated 'Siedem - Lektor Pl.' (E:\FILMY\Se7en - Lektor Pl\Siedem - Lektor Pl..avi) in Library
2011-07-12 20:23:21,487 INFO [LibraryUpdatesCheckerThread] Updated 'Season of the Witch' (E:\FILMY\Season.of.the.Witch.2011.PL.480p.BRRip.XviD.AC3-ELiTE\Season.of.the.Witch.2011.PL.480p.BRRip.XviD.AC3-ELiTE.avi) in Library
2011-07-12 20:23:32,233 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-12 20:23:32,237 INFO [EventDispatcher] Leaving EventDispatcher
2011-07-12 20:23:32,237 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-12 20:23:32,264 INFO [WebServer] WebServer shutting down
2011-07-12 20:23:33,190 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-12 20:23:33,198 INFO [WebServer] WebServer starting on port 8895
2011-07-12 20:23:33,199 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-12 20:23:33,206 INFO [RendererSearchSender] Searching for Renderer devices
2011-07-12 20:23:33,206 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-12 20:23:33,209 INFO [EventDispatcher] Starting EventDispatcher
2011-07-12 20:23:33,265 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Intel(R) PRO/Wireless 3945ABG Network Connection) and address 192.168.1.2, timeout = 0
2011-07-12 20:23:49,482 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-12 20:23:49,482 INFO [EventDispatcher] Leaving EventDispatcher
2011-07-12 20:23:49,482 INFO [WebServer] WebServer shutting down
2011-07-12 20:23:49,482 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-12 20:23:50,764 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-12 20:23:58,929 INFO [WebServer] WebServer starting on port 8895
2011-07-12 20:23:58,935 INFO [RendererSearchSender] Searching for Renderer devices
2011-07-12 20:23:58,935 INFO [EventDispatcher] Starting EventDispatcher
2011-07-12 20:23:58,936 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-12 20:23:58,936 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-12 20:23:58,967 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Intel(R) PRO/Wireless 3945ABG Network Connection) and address 192.168.1.2, timeout = 0
the IP address is the same in both devices 192.168.1.4 .
cheers.
Arek
Post Tue Jul 12, 2011 7:46 pm
It looks like your computer IP address is 192.168.1.2 and your TV's IP address is 192.168.1.4. Serviio does see your TV. And it has accepted JPG, MP3 and videos files into the library.
Did you
My device doesn't see Serviio
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
From here http://www.serviio.org/component/content/article/21#q1
You can make sure that your ports are open by running the following command from a command prompt.
You can show your open ports by running the command on this page . You run the following command from the command line and it will show the computers open ports.
netstat -an |find /i "listening"
Post the results of the netstat command here.
arekkul
Post Tue Jul 12, 2011 8:33 pm
moltra wrote:It looks like your computer IP address is 192.168.1.2 and your TV's IP address is 192.168.1.4. Serviio does see your TV. And it has accepted JPG, MP3 and videos files into the library.
Did you
ACTIVE CONNECTIONS
Protokól Adres lokalny Obcy adres Stan
TCP 0.0.0.0:135 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:445 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:554 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:2869 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:8895 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:10243 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:49152 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:49153 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:49154 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:49155 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:49156 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:49159 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:55555 0.0.0.0:0 NASLUCHIWANIE
TCP 0.0.0.0:59696 0.0.0.0:0 NASLUCHIWANIE
TCP 127.0.0.1:9000 0.0.0.0:0 NASLUCHIWANIE
TCP 127.0.0.1:22347 0.0.0.0:0 NASLUCHIWANIE
TCP 127.0.0.1:23423 0.0.0.0:0 NASLUCHIWANIE
TCP 127.0.0.1:23423 127.0.0.1:49177 USTANOWIONO
TCP 127.0.0.1:49158 0.0.0.0:0 NASLUCHIWANIE
TCP 127.0.0.1:49173 0.0.0.0:0 NASLUCHIWANIE
TCP 127.0.0.1:49177 127.0.0.1:23423 USTANOWIONO
TCP 127.0.0.1:49223 127.0.0.1:49224 USTANOWIONO
TCP 127.0.0.1:49224 127.0.0.1:49223 USTANOWIONO
TCP 127.0.0.1:49225 127.0.0.1:49226 USTANOWIONO
TCP 127.0.0.1:49226 127.0.0.1:49225 USTANOWIONO
TCP 127.0.0.1:49276 127.0.0.1:23423 CZAS_OCZEKIWANIA
TCP 127.0.0.1:49277 127.0.0.1:23423 CZAS_OCZEKIWANIA
TCP 192.168.1.2:139 0.0.0.0:0 NASLUCHIWANIE
TCP 192.168.1.2:8895 192.168.1.4:33747 USTANOWIONO
TCP 192.168.1.2:44331 0.0.0.0:0 NASLUCHIWANIE
TCP 192.168.1.2:44332 0.0.0.0:0 NASLUCHIWANIE
TCP 192.168.1.2:49191 91.214.237.53:443 USTANOWIONO
TCP 192.168.1.2:49227 194.72.186.52:80 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49228 74.125.230.118:443 USTANOWIONO
TCP 192.168.1.2:49231 194.72.186.52:80 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49237 194.72.186.52:80 USTANOWIONO
TCP 192.168.1.2:49238 194.72.186.52:80 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49239 194.72.186.52:80 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49240 194.72.186.52:80 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49241 194.72.186.52:80 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49242 194.72.186.52:80 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49243 2.18.124.20:80 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49254 209.85.146.138:80 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49257 209.85.227.132:443 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49258 74.125.230.118:443 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49259 74.125.230.118:443 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49260 74.125.230.127:443 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49261 74.125.230.118:443 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49262 74.125.230.118:443 USTANOWIONO
TCP 192.168.1.2:49263 209.85.227.104:443 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49264 74.125.230.127:443 CZAS_OCZEKIWANIA
TCP 192.168.1.2:49267 74.125.230.125:443 CZAS_OCZEKIWANIA
TCP [::]:135 [::]:0 NASLUCHIWANIE
TCP [::]:445 [::]:0 NASLUCHIWANIE
TCP [::]:554 [::]:0 NASLUCHIWANIE
TCP [::]:2869 [::]:0 NASLUCHIWANIE
TCP [::]:10243 [::]:0 NASLUCHIWANIE
TCP [::]:49152 [::]:0 NASLUCHIWANIE
TCP [::]:49153 [::]:0 NASLUCHIWANIE
TCP [::]:49154 [::]:0 NASLUCHIWANIE
TCP [::]:49155 [::]:0 NASLUCHIWANIE
TCP [::]:49156 [::]:0 NASLUCHIWANIE
TCP [::]:49159 [::]:0 NASLUCHIWANIE
TCP [::1]:49160 [::]:0 NASLUCHIWANIE
UDP 0.0.0.0:123 *:*
UDP 0.0.0.0:500 *:*
UDP 0.0.0.0:1900 *:*
UDP 0.0.0.0:4500 *:*
UDP 0.0.0.0:5004 *:*
UDP 0.0.0.0:5005 *:*
UDP 0.0.0.0:5355 *:*
UDP 0.0.0.0:22000 *:*
UDP 0.0.0.0:39046 *:*
UDP 0.0.0.0:57725 *:*
UDP 127.0.0.1:1900 *:*
UDP 127.0.0.1:55845 *:*
UDP 127.0.0.1:57494 *:*
UDP 127.0.0.1:57724 *:*
UDP 127.0.0.1:62557 *:*
UDP 127.0.0.1:64868 *:*
UDP 192.168.1.2:137 *:*
UDP 192.168.1.2:138 *:*
UDP 192.168.1.2:1900 *:*
UDP 192.168.1.2:62556 *:*
UDP [::]:123 *:*
UDP [::]:500 *:*
UDP [::]:5004 *:*
UDP [::]:5005 *:*
UDP [::]:5355 *:*
UDP [::1]:1900 *:*
UDP [::1]:62554 *:*
UDP [fe80::100:7f:fffe%9]:1900 *:*
UDP [fe80::100:7f:fffe%9]:62555 *:*
UDP [fe80::984:ca35:37c:b70%8]:1900 *:*
UDP [fe80::984:ca35:37c:b70%8]:62553 *:*
UDP [fe80::c989:cb59:ef8:cadd%10]:1900 *:*
UDP [fe80::c989:cb59:ef8:cadd%10]:62552 *:*
arekkul
Post Tue Jul 12, 2011 8:40 pm
Did you
ACTIVE CONNECTIONS
UDP 0.0.0.0:123 *:*
UDP 0.0.0.0:500 *:*
UDP [::]:123 *:*
UDP [::]:500 *:*
UDP [::]:5004 *:*
UDP [::]:5005 *:*
UDP [::]:5355 *:*
UDP [::1]:1900 *:*
UDP [::1]:62554 *:*
see that one : TCP 192.168.1.2:8895 192.168.1.4:33747 USTANOWIONO - means connected ;-)
Post Wed Jul 13, 2011 1:54 am
It looks like everything should be working right. What does is say when you try to select a DLNA server on your TV?
arekkul
Post Wed Jul 13, 2011 5:16 pm
moltra wrote:It looks like everything should be working right. What does is say when you try to select a DLNA server on your TV?
hi,
problem is - my TV doesn't see DLNA server - i don't know why.
Internet settings are OK, TV has internet connection ....i'm confused.
Post Wed Jul 13, 2011 6:24 pm
Searching around on the internet.
Toshiba Regza 40RV753 and DLNA
I’ve been a proud own of one of these babies for a week now. Fantastic TV that’s got loads of feature and a cracking picture. However, I’ve having a spot of bother with regards to playing files with the inbuilt media player; the only files I appear to be able to play are VOB files. Does anyone…
our service is updated everyday, come again
found this link to what it should play.
http://certification.dlna.org/certs/REG10125777.pdf
Found the user manual on this page.
http://www.toshiba-om.net/
this is the one that I am looking at.
RV753-323740-English-Specific.pdf
http://www.toshiba-om.net/LCD/PDF/English/Country_Specific/RV753-323740-English-Specific.pdf
Are you following the instructions starting on page 44 of the manual?
Also make sure that you have followed everything in the manual about setting up a network, it looks like it requires you to setup a password, before you can access the network???
Return to Toshiba
