Page 1 of 1
Serviio still alive?
PostPosted: Sun May 07, 2017 4:46 pm
by Rhialto
Just curious what to expect. New here, posted a feature request a week ago and now I look around a bit more and don't see much activity. Seems there is nothing new since 1.8 was released.
Re: Serviio still alive?
PostPosted: Sun May 07, 2017 7:15 pm
by zip
yes, 1.9 should go to beta quite soon
PostPosted: Sun May 07, 2017 9:01 pm
by Rhialto
Good! Any chance for this?
PostPosted: Sun May 07, 2017 9:32 pm
by zip
no, sorry, 1.9 is feature locked now
PostPosted: Sun May 07, 2017 10:13 pm
by Rhialto
:-( and for next one will it be added? I see it was asked a while ago and it is still not in 1.9 so I wonder. Is there a new version every 6 months or so? Because as soon as you start beta testing 1.9.x or 2.0.x I can test MPO for you.
PostPosted: Wed May 10, 2017 10:34 pm
by Rhialto
Still waiting for an answer. I can even alpha test if needed. BTW glad you are working with QNAP because it's the brand I have. Hope all this will be good.
PostPosted: Thu May 11, 2017 3:25 pm
by zip
You can see tickets, and their planned versions here: https://bitbucket.org/xnejp03/serviio/i ... tatus=open
PostPosted: Thu May 11, 2017 4:31 pm
by Rhialto
Nice that https://bitbucket.org/xnejp03/serviio/i ... -3d-images priority is set to major! That's some good news, unless it is set to major for the last 2 years? :?
Can't wait...
Oh and the suggestion here, is it added to that list by you or I need to sign up there and post it?
Thanks!
PostPosted: Mon May 29, 2017 5:43 am
by mariad
How long is it gonna be more?
PostPosted: Wed May 31, 2017 11:27 pm
by Rhialto
Still waiting for an answer to my question about the suggestion in my last post.
Also I can tell you that issue #616 is not resolved. New NAS trying Serviio and the first MKV I DLNAed to my Panasonic TV GT50 (2012) had that ratio problem too, until I read to use the Generic Profile. Since there is a specific profile for my TV I was expecting it to be perfect in the sense that it should knows all the parameters of my TV so I guess there is still something wrong in it.
The MKV was DTS and while it began playing fine there was a problem with the sond every few minutes and after searching on the subjet I found out TV does not support DTS so I ended up converting the file on the PC first. I had hope it would be transcoded on the fly without problem.
Like I previsously said I was quite happy to find out you work with QNAP, also that Serviio presentation is nice and that you seem open to add .MPO support but I have no clue if it will happen and when. I'm out of luck with 1.9 yet to be in beta so I know I need to wait for next version for that but have no idea when it could happen. Is there usually a single update a year or it's twice a year or? I read the 1.8 annoucement but there is no date in your news so no clue when it happened. I could have tried to extrapolate from that.
Thanks for reading.
PostPosted: Thu Jun 01, 2017 7:48 am
by zip
1.9 is in testing. I'd expect 1.10 sometime in autumn
PostPosted: Wed Jun 14, 2017 10:39 pm
by Rhialto
zip wrote:1.9 is in testing. I'd expect 1.10 sometime in autumn
Cool! But what about my other subjects? My suggestion and Bug #616?
When you will start working on 1.10 and if it's the good one for .MPO support, are you interested that I test for you? Being a french speaker I can also have a look at translation if you need.
Thanks!
PostPosted: Fri Jun 23, 2017 11:31 am
by MSGBen
Autumn of this year right? I am still using 1.8
PostPosted: Mon Jun 26, 2017 9:12 am
by zip
1.9 should be out soon now. Will see how quickly I get to work on 1.10 over the summer.
