Post Tue Dec 11, 2018 2:21 pm
Does PIA VPN Support Netflix?
I have been using Private Internet Access for quite long. A few days back, I was connecting this VPN for unblocking Netflix but the error is occurred. I searched a lot and found a blog "removed by moderator". The blog shows the VPN does not support Netflix whereas very few of blogs show that Netflix works with this VPN. I'm little confused, what should I do in this moment. Can any experienced guy suggest me best solution.
