List of Internet Radio Stations
Paul C
Post Mon Jan 18, 2021 2:24 pm
Re: FLAC Radio streams on Serviio (in Version 28/29)
I have added a number of additional flac (CD quality) radio streams.
Paul C
Post Mon Jan 18, 2021 3:26 pm
Re: Improving Internet Radio Station performance
Want to make your radio stations start immediately. There is a current problem with Serviio transcoding.
Remove or disable the transcoding lines below from the generic profile - and bingo - radio stations play instantly like on other apps.
Solution 1: Disabling all the transcoding lines by adding <!-- and -->
<OnlineTranscoding>
<Audio targetContainer="mp3" aBitrate="320" forceInheritance="true">
<Matches container="flv"/>
<Matches container="asf"/>
<Matches container="rtp"/>
<Matches container="rtsp"/>
<Matches container="mp3"/>
<Matches container="mp4"/>
<Matches container="mpegts"/>
</Audio>
</OnlineTranscoding>
Solution 2: Disabling only the mp3 transcoding line by adding <!-- and -->
<OnlineTranscoding>
</Audio>
This option allows playing AAC and other file types if not supported natively.
Need to stop/restart Serviio after these changes.
Note The flac radio stations play OK as they are not part of the transcoding.
Post Mon Jan 18, 2021 8:50 pm
Re: Internet Radio Station streams on Serviio
Just remember that every Serviio update will replace the profiles.xml file, so your changes will be gone. It's not recommended to alter the generic profile, as that impacts virtually every other profile, but instead one should create a user profiles XML file and create a special profile for your device. I can't say 100% that it would remove the sections you've commented out from applying. Just something to remember.
Paul C
Post Tue Jan 19, 2021 11:54 am
atc98092 wrote:Just remember that every Serviio update will replace the profiles.xml file, so your changes will be gone. It's not recommended to alter the generic profile, as that impacts virtually every other profile, but instead one should create a user profiles XML file and create a special profile for your device. I can't say 100% that it would remove the sections you've commented out from applying. Just something to remember.
Dan is absolutely right about the generic profile and I have mine in a user profile which is selected on the status page of Serviio.
However if components do not have a fixed IP these user profiles often get lost by DHCP resetting which happen more often than Serviio updates.
To clarify the commented out sections ARE deactivated.
You will need to restart Serviio to use the changed profile.
Other inherited profiles may also benefit esp. by avoiding transcoding from mp3 to mp3 !
Paul C
Post Mon Feb 01, 2021 7:45 pm
Re: Internet Radio Statiions Version 31
Update version 31 with new stations, many corrections and removal of some sites no longer working.
Latest download see viewtopic.php?f=42&t=24378&p=116776#p116776
Paul C
Post Thu Feb 04, 2021 1:29 pm
Internet Radio Statiions Version 32
Radio stations regularly change - new ones emerge, others cease broadcasting and many streaming URL's change.
I have re-validated the stations to check they are currently working.
There are 244 stations in the current file.
Paul C
Post Thu Feb 18, 2021 12:56 pm
Internet Radio Statiions Version 33
Updated file with additional stations.
The FLAC files are currently at the end.
Paul C
Post Thu Mar 18, 2021 4:48 pm
Internet Radio Statiions Version 34
Updated file with additional stations, corrections etc.
Paul C
Post Mon Mar 29, 2021 12:10 pm
Internet Radio Statiions Version 35
A number of changed and more efficient thumbnails.
Please remove/replace your existing files.
Paul C
Post Wed Mar 31, 2021 12:27 pm
Internet Radio Statiions Version 36/37
All the BBC stations URL have ceased working as of two days ago.
The file has been updated with current working URLs.
Miro1001
Post Sat May 15, 2021 8:20 pm
Re: List of Internet Radio Station streams
Hi Paul,
Just to thank you for your great list of stations. Flack jazz sound quality is very impressive. Thank you again.
Paul C
Post Mon May 17, 2021 12:35 pm
Miro1001 wrote:Hi Paul,
You will find the non-flac stations load much better if you change the transcoding - see viewtopic.php?f=42&t=24378&start=40#p133036
Option 2 is usually the best.
The flac stations are OK as they are not transcoded.
Paul C
Post Tue Jan 04, 2022 1:55 pm
UPDATED List of Internet Radio Station streams
An updated file of Internet radio stations (version 38) has been posted today (4th Jan 2022).
There are a number of new stations (including Flac), stations with revised URLs, and others removed because they are defunct.
Most of the .flac stations are at the end (except Radio Paradise which is also in the correct genre).
There are 263 stations covering various genres.
The download file is at
viewtopic.php?f=42&t=24378#p116776
Paul C
Post Tue Jan 25, 2022 11:13 pm
UPDATED Internet Radio Station streams
An updated file of Internet radio stations (version 40) has been posted 28th Jan 2022.
There are a number of stations with revised URLs, and others removed because they are defunct. Also a number of artwork changes.
The .flac stations are now in their correct genres.
There are 259 stations covering the various genres.
Paul C
Post Tue Feb 08, 2022 4:42 pm
Re: Bauer/PlanetRadio Radio Station streams may cease
The Bauer/PlanetRadio group are indicating their streams may cease working shortly. These include
Absolute
Kiss
Magic (UK)
Planet
Hits
Greatest Hits Radio
Scala
JazzFM.
These will be removed if the URL is no longer accessible.
These stations are only available in the UK.
There are other stations with similar content and better SQ available.
Paul C
Post Mon Feb 21, 2022 12:24 pm
Re: WRTI 90.1 - changed URLs
WRTI 90.1 Jazz and Classical stations have changed URLs.
WRTI 90.1 Jazz
new URL https://playerservices.streamtheworld.c ... I_JAZZ.mp3
WRTI 90.1 Classical
new URL https://playerservices.streamtheworld.c ... SSICAL.mp3
Thesr are the preferred links in accordance with the WRTI recommendations.
Paul C
Post Fri Mar 04, 2022 12:19 pm
An updated file of Internet radio stations (version 41) has been posted 4th March 2022.
There are a number of new stations, stations with revised URLs, and others removed because they are defunct.
The download file is on the first page of this thread at
Paul C
Post Mon Mar 28, 2022 12:13 pm
Updated List of Internet Radio Station streams - 28/03/2022
An updated file of Internet radio stations (version 42) has been posted 28th March 2022.
Paul C
Post Sun Apr 03, 2022 11:49 am
Re: 104 Internet Radio working streams for Serviio
atc98092 wrote:I didn't try any of the ones you labeled UK Only. But I did leave in some that said UK, and the few I tried did work.
I just looked again, and I did leave in one that you labeled UK Only (Classical - Classic FM (aacPlus) [UK only?]) and it worked for me. But that's the only one I kept. Now I may need to try some of the others. :D
Sure would be nice if we had song titles and other metadata, but the streams must not contain them.
Paul C
Post Fri Apr 22, 2022 10:12 am
Re: List of Internet Radio Stations
An updated file of Internet radio stations (version 43) has been posted 22nd April 2022.
Return to Audio streams
