serviigo Server
glda19
Post Sun May 05, 2024 5:27 pm
serviigo Server
Hi
In serviiogo on mij tabelet or androidox i have to add a server.
I add two server twice the same sever but with different username.
But i have to give in a password, how can i make that when i want to connect to the second server i have to fill in the password. Not hat is saved
Post Tue May 07, 2024 1:26 am
Re: serviigo Server
I don't use ServiiGo, so can only make a guess about how to choose your server. Are you saying you have two different Serviio servers running, or are you just trying to use ServiiGo with two different user names?
If you have two different servers, you can name each server differently on line 13 of the profiles.xml file. I have two, and I label one as "Test Serviio" as it's the one I use for testing profiles. So they are both visible on the network but are named differently so I know which one I'm connecting to.
If you're simply trying to use a different login name, you'd need to ask the ServiiGo developer. That is not the same person that created Serviio. I don't know if ServiiGo offers a way to contact the developer through the app, but there is a ServiiGo sub-group here in the Serviio forum: viewtopic.php?f=17&t=6803
Users browsing this forum: No registered users and 50 guests
