Page 1 of 1
Unable to play content [Win 7 Serv/PS3]
PostPosted: Wed Mar 12, 2014 10:39 pm
by aSystemOverload
Have been having problems playing 720 files lately, not all, just some. It will randomly crash with 'Unable to play content', but if I restart the file, fast forward to the same location, it is fine, for ten or so minutes...
Any Ideas?
Re: Unable to play content [Win 7 Serv/PS3]
PostPosted: Tue Apr 01, 2014 9:19 pm
by aSystemOverload
Sorry to chase, but does anyone know anything about this?
I've copied the below from serviio.log:
2014-04-01 22:17:29,894 WARN  [DiscoverySSDPMessageListener] Problem during DiscoverySSDPMessageListener, will try again
org.apache.http.ConnectionClosedException: Client closed connection
   at org.apache.http.impl.io.HttpRequestParser.parseHead(HttpRequestParser.java:104)
   at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:210)
   at org.serviio.upnp.protocol.http.HttpMessageParser.parseHttpRequest(HttpMessageParser.java:46)
   at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.listenForMulticastMessages(DiscoverySSDPMessageListener.java:132)
   at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:101)
   at java.lang.Thread.run(Unknown Source)
2014-04-01 22:17:29,895 WARN  [DiscoverySSDPMessageListener] Problem during DiscoverySSDPMessageListener, will try again
PostPosted: Tue Apr 15, 2014 5:41 pm
by aSystemOverload
c:\Program Files\Serviio\lib>ffmpeg.exe -i "c:\faulty.mkv"
Input #0, matroska,webm, from 'c:\faulty.mkv':
creation_time : 2014-04-02 18:48:02
Duration: 00:42:04.48, start: 0.000000, bitrate: 3678 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 2
3.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
