issues starting server on Raspberry PI 3B on Raspbian Stretc
Posted: Thu Dec 14, 2017 10:07 pm
I'm pretty savvy with Linux but not so much with Java (not my fav language)
I've installed 1.9
i've installed openjdk-8-jdk & openjdk-8-jre and the other drivers i need but still getting an issue with SOAP
below is an excerpt from the log file where i'm getting the issue, any assistance would be greatly appreciated.
I've installed 1.9
- Code:
2017-12-14 21:52:31,046 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: javax.xml.soap.SOAPException
java.lang.NoClassDefFoundError: javax/xml/soap/SOAPException
at org.serviio.upnp.webserver.WebServer$RequestListenerThread.<init>(WebServer.java:122)
at org.serviio.upnp.webserver.WebServer.start(WebServer.java:76)
at org.serviio.MediaServer.startServer(MediaServer.java:207)
at org.serviio.MediaServer.main(MediaServer.java:158)
Caused by: java.lang.ClassNotFoundException: javax.xml.soap.SOAPException
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:582)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:185)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:496)
... 4 more
