Post Wed Jun 19, 2019 9:46 am
MacBook - "Turn display off after"
Hey
Newbie here. I’ve signed up because I have a question I’d be grateful for some assistance with
I recently purchased a new MacBook Air, and installed Serviio.
The first time I used it, to stream video from my MacBook to my Samsung TV, the MacBook display switched off yet the stream was uninterrupted.
Please note that the MacBook did not go to sleep, the settings state that only the display had turned off
The second time, and every time since, this has not been the case. Now, then the MacBook’s display goes off, the stream is interrupted
I have used Amphetamine as a workaround, however; it seems strange that this was not needed in the first instance
Any advice is welcome
Many thanks
Rex
