V2.0 .sob Online Sources files incompatible with Version 1
Users should be aware that the .sob Online Sources export files are not backwards compatible between Serviio version 2.0 and earlier Serviio versions 1 due to Serviio format changes that include a userIds field.
i.e. A .sob file exported from Serviio V2.0 will fail when being imported by users still using versions 1.
Users should be aware of this if they are experimenting and moving between the different versions.
For example, the Internet Radio Stations .sob file Version 21 is only compatible with Serviio V2. Users on versions 1 should therefore use the older Version 20 .sob file. see viewtopic.php?f=42&t=24378#p116776
