Post Wed Oct 27, 2021 10:21 am
Serviio V2.0 File Filtering - how to?
Hello Everyone,
I have been waiting for an update to Serviio that would allow filter type filtering and it has finally arrived :)
Now my problem is that I'm not sure I'm doing it correctly. I see that in the Advanced Features I can tell Serviio to ignore files with certain extensions. In my case, Nikon NEF files. I have tried entering the file extension in different forms - "*.NEF", ".NEF" and simply "NEF" (without the quotes). However, when I view pictures on my TV (via PlayStation 3) the NEF files still appear.
What is the correct way to put in the file extension? Do I need to use the dot before the extension, like ".NEF" or do I need to just put "NEF"? Also, if I wan to skip multiple extensions, do I separate them with a comma?
https://speedtest.vet/ https://vidmate.bid/
Also, since I have upgraded from version 1.x, do I need to rebuild my library to force it to skip the NEF files? If so, how can I do that?
Thanks to all who reply.
