Serviio not running (java update) [solved]
This afternoon has been updated java and shortly after I was about to run serviio not work, not if you have something to do, use xp and try to start the service and the console and does nothing or a warning or anything.
I reinstalled serviio and does not work, will not start.
Any solution?
pd.: I reinstalled the latest update of java and now everything works, it seems that the automatic update failed.
Any solution?
