[SOLVED] Video File that does not play
Kids on my case about a TV show that won't play. (That's my story and I'm sticking to it
renderer
ffmpeg information
mediainfo information
serviio log (what I believe is relevant)
renderer
- Code:
2012-06-30 11:59:21,901 DEBUG [WebServer] Incoming connection from /192.168.0.216:43335
2012-06-30 11:59:21,902 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.216:
2012-06-30 11:59:21,902 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.216
2012-06-30 11:59:21,906 DEBUG [ContentDirectory] Browse() called for renderer UN46D8000 (profile 7) with parameters: objectID = V_F^FOL_R6$F1128, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 30, count = 30, sortCriteria =
ffmpeg information
- Code:
root@box:/media/share1/Kids TV Shows/My Little Pony Friendship is Magic# ffmpeg -i "My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv"
FFmpeg version SVN-r0.5.9-4:0.5.9-0ubuntu0.10.04.1, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --extra-version=4:0.5.9-0ubuntu0.10.04.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
built on Jun 12 2012 16:27:59, gcc: 4.4.3
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 24.00 (24/1)
Input #0, matroska, from 'My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv':
Duration: 00:22:01.38, start: 0.000000, bitrate: N/A
Stream #0.0: Video: h264, yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 24 tbr, 1k tbn, 47.95 tbc
Stream #0.1(eng): Audio: aac, 24000 Hz, 5.1, s16
- Code:
root@box:/media/share1/Kids TV Shows/My Little Pony Friendship is Magic# mediainfo "My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv"
Unique ID : 239996763093622065058409002902059281582 (0xB48DB1FC8BDE2A39A460E16C9AA0ECAE)
Complete name : My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv
Format : Matroska
Format version : Version 2
File size : 253 MiB
Duration : 22mn 1s
Overall bit rate : 1 603 Kbps
Encoded date : UTC 2011-08-29 12:54:49
Writing application : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 22mn 1s
Nominal bit rate : 1 410 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.028
Writing library : x264 core 115 r1995 c1e60b9
Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1410 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=17500 / vbv_bufsize=14000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Format : AAC
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 22mn 1s
Channel(s) : 6 channels
Sampling rate : 48.0 KHz / 24.0 KHz
Compression mode : Lossy
Language : English
Default : Yes
Forced : No
- Code:
2012-06-30 11:59:21,324 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.216:
2012-06-30 11:59:21,324 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.216
2012-06-30 11:59:21,333 DEBUG [ContentDirectory] Browse() called for renderer UN46D8000 (profile 7) with parameters: objectID = V_F^FOL_R6$F1128, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 30, sortCriteria =
- Code:
2012-06-30 11:59:21,333 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 1128
2012-06-30 11:59:21,334 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1128 (from=0, count=30)
2012-06-30 11:59:21,383 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2012-06-30 11:59:21,385 DEBUG [VideoDAOImpl] Reading a Video (id = 29774)
2012-06-30 11:59:21,386 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 29774 and profile Samsung TV / player (C/D-series)
2012-06-30 11:59:21,386 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv: MPEG_TS_SD_EU_ISO
2012-06-30 11:59:21,386 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv: MPEG_TS_SD_NA_ISO
2012-06-30 11:59:21,386 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv: MPEG_TS_SD_KO_ISO
- Code:
2012-06-30 11:59:27,044 DEBUG [VideoDAOImpl] Reading a Video (id = 29774)
2012-06-30 11:59:27,044 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 29774, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2012-06-30 11:59:27,044 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv
2012-06-30 11:59:27,045 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv: MPEG_TS_SD_EU_ISO
2012-06-30 11:59:27,045 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv: MPEG_TS_SD_NA_ISO
2012-06-30 11:59:27,045 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv: MPEG_TS_SD_KO_ISO
2012-06-30 11:59:27,046 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-06-30 11:59:27,046 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sat, 30 Jun 2012 18:59:27 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-06-30 11:59:27,051 DEBUG [WebServer] Incoming connection from /192.168.0.216:52523
2012-06-30 11:59:27,052 DEBUG [ResourceTransportRequestHandler] GET /resource/29774/MEDIA_ITEM/MPEG_TS_SD_KO_ISO*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: xxx.xxx.xxx.xxx:8895]]
2012-06-30 11:59:27,052 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.216
2012-06-30 11:59:27,052 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.216, Profile=Samsung TV / player (C/D-series)'
2012-06-30 11:59:27,053 DEBUG [ResourceTransportRequestHandler] Request for resource 29774 and type 'MEDIA_ITEM' received
2012-06-30 11:59:27,053 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 29774 (local)
2012-06-30 11:59:27,054 DEBUG [VideoDAOImpl] Reading a Video (id = 29774)
2012-06-30 11:59:27,054 DEBUG [VideoDeliveryEngine] Delivering item '29774' for client 'IPAddress=/192.168.0.216, Profile=Samsung TV / player (C/D-series)'
2012-06-30 11:59:27,054 DEBUG [VideoDeliveryEngine] Delivering file 'My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv' using transcoding
2012-06-30 11:59:27,055 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.0.216, Profile=Samsung TV / player (C/D-series)'
2012-06-30 11:59:27,058 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /media/share1/Kids TV Shows/My Little Pony Friendship is Magic/My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv
2012-06-30 11:59:27,058 DEBUG [ProcessExecutor] Starting ffmpeg -i /media/share1/Kids TV Shows/My Little Pony Friendship is Magic/My Little Pony Friendship is Magic [1X01] Friendship is Magic Mare in the Moon (1).mkv -y -threads 1 -async 1 -vcodec mpeg2video -b 20000k -maxrate 20000k -bufsize 20000k -r 24 -g 15 -copyts -acodec ac3 -ab 192k -ar 48000 -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-29774-MPEG2TS.stf
2012-06-30 11:59:27,213 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-06-30 11:59:27,213 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-06-30 11:59:27,559 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:129)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:96)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
