Every time I close Serviio I can´t run it again
Posted:
Sun Sep 27, 2015 10:01 pm
by jor1980
Hi.
I have windows 10 and I am using Serviio. Every time I close it when I trie to run it again I get the error "Cannot connect to Serviio server, it does not seem to be running. Exiting...". If I unninstall it then I can run it again. How can I solve this?
Re: Every time I close Serviio I can´t run it again
Posted:
Sun Sep 27, 2015 10:27 pm
by DenyAll
How are you stopping and starting it.
Post a
detailed log showing Serviio starting (or attempting to start) for the time it fails.
Posted:
Sun Sep 27, 2015 11:33 pm
by atc98092
Remember there are two pieces to Serviio: the service and the console. The error you list is usually when you attempt to start the console without the service running. You don't have to have the console running to use Serviio, just the service.
If you right-click the Serviio icon in the Notification area, you have the option to "Exit Serviio Console" or "Exit Serviio". If you exit Serviio, you've stopped the service. Is this the method you use to close Serviio? If so, you've closed the service as well.
There are three ways to restart the service: reboot the computer, use the Services console to start the Serviio service, or use the icon in the Start Menu under Serviio that says "Start Serviio service". The fastest method is of course using the Start menu icon.
