Profile Samsung HDR UHD 4K 43RU7405 [UE43RU7405UXXC]
ruiseixas
Post Sat Feb 22, 2020 11:31 am
On this TV, some videos only have sound when the Samsung TV (A-Series) is selected despite being a R-Series! The "Downmix to stereo" is activated.
The audio stream in question was:
  • Codec: DTS Audio (dts )
  • Channels: 3F2M/LFE
  • Sample rate: 48000 Hz
  • Bits per sample: 32
The server works well in detecting Video codecs, but for Audio ones it fails frequently.
Best regards and thanks
Post Sat Feb 22, 2020 5:47 pm
Re: Profile Samsung HDR UHD 4K 43RU7405 [UE43RU7405UXXC]
Try the NU profile that I created. It will be included in the next update of Serviio, but I don't know when that will happen. In the meantime, copy that file into the settings folder for your Serviio install. Under Windows, that would be C:\Program Files\Serviio\config
viewtopic.php?f=10&t=24892&start=20#p126633
Primary server: Intel i5-6400, 8 gig ram, Windows 10 Pro, 22 TB hard drive space | Test server Windows 10 Pro, AMD Phenom II X4 965, 8 gig ram
Users browsing this forum: Google [Bot] and 1 guest
