QNAP hardware transcoding?
I've picked up a TS-251D with a Gemini Lake Intel CPU on the basis that it supports H.265 decode in hardware.
Now, it looks like the CPU has enough grunt (just) to decode in software on the fly, but I'm running 98% CPU at that point. From what I've seen, if the hardware decode is in use omegle xender I should expect that to be around 60%.
I've had a look around the forums, and I've seen many references to "If you look around the forums you'll find the flags you need for ffmpeg", but I haven't actually found the post that those posts refer to. Even if I did, I suspect it may be out of date. Can anyone help me out with this?
