Post Sat Dec 23, 2023 7:30 pm
Copy VP9 stream and transcoding opus
I have some video files with VP9 video codec and opus as audio codec. My Sony UBP-X700 is not able to handle the Opus codec, so I would like to convert only the audio stream leaving the video stream intact. I tried with a very simple profile but it doesn't work. Is it possible to transcode the audio and copy the video stream as is?
<Profile id="UBP-X700" name="UBP-X700 " extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <ModelName>UBP-X700</ModelName>
         </UPnPSearch>
      </Detection>
            <Matches container="*" aCodec="opus" />
I found some warnings in the log
2023-12-23T19:55:31,826 WARN  [VideoDeliveryEngine] Cannot get media info for transcoded file "zzz.mkv": MPEG2TS video file zzz.mkv does not match any supported DLNA profile
2023-12-23T19:55:31,827 WARN  [ResourceDeliveryProcessor] Invalid request, sending back 500 error
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: No media description available for required version: MATROSKA
   at org.serviio.delivery.resource.AbstractDeliveryEngine.findMediaInfoForFileProfile(AbstractDeliveryEngine.java:224) ~[serviio.jar:?]
   at org.serviio.delivery.resource.transcode.AbstractAVTranscodingDeliveryEngine.retrieveTranscodedMediaInfoForVersion(AbstractAVTranscodingDeliveryEngine.java:161) ~[serviio.jar:?]
ffmpeg version is
fmpeg version 4.3.6-0+deb11u1 Copyright (c) 2000-2023 the FFmpeg developers
  built with gcc 10 (Debian 10.2.1-6)
  configuration: --prefix=/usr --extra-version=0+deb11u1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
  libavutil      56. 51.100 / 56. 51.100
  libavcodec     58. 91.100 / 58. 91.100
  libavformat    58. 45.100 / 58. 45.100
  libavdevice    58. 10.100 / 58. 10.100
  libavfilter     7. 85.100 /  7. 85.100
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  7.100 /  5.  7.100
  libswresample   3.  7.100 /  3.  7.100
  libpostproc    55.  7.100 / 55.  7.100
Thanks in advance.
