Serviio console not starting
rusold2day
Post Wed May 06, 2015 3:36 am
I just installed Serviio 1.5.2 on my HP p667c desktop. OS s windows 7 home prem 64 bit
the black window pops up and says "stopping service" and goes away.
I can see serviio on xbox and the smart TV but no console on my desktop.
I have checked for any and all updates that could be out there for my pc and I am all up to date
I have restarted my system.
I am running as the admin
I am not that computer literate so if I am not giving you all the info you need please request and I will try to comply.
I have seen in the other posts that a log should be posted with this question but I have no idea where I would find that.
I am sorry if this has been posted and resolved in another post. Every post that I came across did not have a solution.
Thank you for your kindness a patience :)
rusold
adielk
Post Wed May 06, 2015 4:50 am
Re: Serviio console not starting
First press "start seriio service" and then "serviio console". Probably not as easy as this but resolved error like that in the past with serviio 1.4 versions.
rusold2day
Post Wed May 06, 2015 4:54 am
yes I have done that. The black box pops up with the message that it has stopped and cleses
adielk
Post Wed May 06, 2015 7:44 pm
Other option is to uninstall and then reinstall. Worked for me once when I struggled to get serviio operating on hp n54l microserver
rusold2day
Post Wed May 06, 2015 10:21 pm
I have uninstalled rebooted and installed again. same issue
Post Thu May 07, 2015 8:02 pm
Is there a Serviio folder in your Start menu? There should be Serviio Console there.
Return to User experiences
