Re: PACKAGE: Serviio 1.5.2 - Synology NAS, with HW transcodi
Six wrote:Should I uninstall old version before installing 1.6?
wojtas40 wrote:Six wrote:Should I uninstall old version before installing 1.6?
Exactly! Had a same problem, it helped.
patters wrote:Stop Serviio, remove any firewall rules you may have created specifically for Serviio. Reboot your NAS. It should then let you upgrade without you having to uninstall and recreate your library and online sources.
patters wrote:Odd. Well you could stop Serviio. Then connect as root via SSH:
Uninstall Serviio 1.5.2. Install Serviio 1.6 but don't start it. Then:
Start Serviio. Your library, licence key, and online sources will be preserved.
If you're running DSM 6.0 beta 2 you need to connect to SSH as admin (root no longer allowed). Once connected run "sudo -i" and use the admin password again to switch to root.
anachron wrote:Hello,
Just to add to my previous post, i have done a bit of testing and it seems that the transcoding stay on even if i uncheck the option. I got the exact same behavior with it on or off, and i was able to read an H.265 encoded movie on my ISP box which is not able to decode H.265, even with the option unchecked.
Is there any way to check the Serviio config files outside of the web console ?
Six wrote:You should log in as root not admin.
