Re: Problems with LAN Drive
Been a long time since I played with readyshare drives, but if memory serves me correctly then you should be able to enable "Anonymous" or "Guest" access for the shared drive. This will alleviate the need for the login credentials every time you (or Serviio) accesses the drive.
(Edit - just looking at your screen shots and it looks like you have it set up for that - but its not working...)
If this isn't possible (or is not desirable if you don't trust other LAN users) you can also enter the login credentials into Windows Credential Manager. Type "Windows Credential Manager" into your start menu (or Cortana) on the PC running Serviio and then select "Add a Windows Credential". This will once again alleviate the need for the login credentials every time you (or Serviio) accesses the drive (but only for the one PC, rather than all LAN users).
I don't think changing the user account for the Serviio service will work by itself, because even your user account needs to enter the credentials the way it is set up now. You may need to do this along with the Credential Manager to get it to work.
