Mon Dec 10, 2018 5:16 pm by Meelis
DenyAll wrote: Can you please post MediaInfo (see my signature) for 4-5 files that don't work (I note the two you did post have True HD Audio in common - is that actually supported by your TV?).
- Code:
Unique ID : 240942372843767763558755833017931442086 (0xB543D0258FE7CC9D7EDE852BC928A7A6)
Complete name : C:\serviio\John Wick (2014).mkv
Format : Matroska
Format version : Version 4
File size : 29.9 GiB
Duration : 1 h 41 min
Overall bit rate : 42.3 Mb/s
Movie name : John Wick (2014)
Encoded date : UTC 2018-12-03 20:33:24
Writing application : mkvmerge v29.0.0 ('Like It Or Not') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Cover : Yes
Attachments : cover.jpg / Poster.jpg / cover.jpg
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 41.7 Mb/s
Width : 3 840 pixels
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.283
Stream size : 29.5 GiB (98%)
Writing library : x265 2.2+22-20217c8af8ac:[Windows][GCC 6.2.0][64 bit] 10bit
Encoding settings : cpuid=1173503 / frame-threads=5 / numa-pools=14,14 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=145546 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=3.50 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=16.0 / qcomp=0.60 / qpstep=1 / stats-write=0 / stats-read=0 / ipratio=1.10 / pbratio=1.00 / aq-mode=0 / aq-strength=0.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=64 / rc-grain / qpmax=69 / qpmin=0 / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 4 ms
Stream size : 463 MiB (2%)
Title : AC3 5.1 @ 640 kbps
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 40 min
Bit rate : 16.6 kb/s
Count of elements : 1757
Stream size : 12.0 MiB (0%)
Title : Anglais Complets PGS
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Duration : 14 min 0 s
Bit rate : 1 765 b/s
Count of elements : 24
Stream size : 181 KiB (0%)
Title : Anglais Forces PGS
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 33 min
Bit rate : 21 b/s
Count of elements : 554
Stream size : 14.9 KiB (0%)
Language : English
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 30 b/s
Count of elements : 854
Stream size : 22.8 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 22 b/s
Count of elements : 524
Stream size : 15.4 KiB (0%)
Title : Eesti Keel
Language : Estonian
Default : Yes
Forced : Yes
Menu
00:00:00.000 : en:00:00:00.000
00:04:57.506 : en:00:04:57.506
00:12:21.866 : en:00:12:21.866
00:17:07.735 : en:00:17:07.735
00:26:25.167 : en:00:26:25.167
00:32:40.250 : en:00:32:40.250
00:36:24.599 : en:00:36:24.599
00:42:16.033 : en:00:42:16.033
00:45:33.272 : en:00:45:33.272
00:55:02.507 : en:00:55:02.507
00:59:27.564 : en:00:59:27.564
01:06:13.428 : en:01:06:13.428
01:14:15.910 : en:01:14:15.910
01:19:13.040 : en:01:19:13.040
01:27:29.786 : en:01:27:29.786
01:32:24.789 : en:01:32:24.789
I removed HD audio and i have only that movie in windows machine due not enough hdd space.
DenyAll wrote: I'm curious - did you try Option 2 from viewtopic.php?f=27&t=24775&start=20#p119493 on your Windows PC. That may be better option (assuming your PC has the grunt to do it).
Now i tried. It didn't worked at all with this one....
