Permission denied
hard66
Post Tue Mar 05, 2019 7:54 pm
Permission denied
Thank you for your efforts to solve my problem.
I have DSM 6.2.1-23824 Update 6 (Synology DS218j), Java 8 SE Embedded, Serviio 1.9.2 (Package from your repository on PCLoadLetter.co.uk).
I tried reinstalling Java and Serviio without success.
Unable to run Serviio - it is stopped immediately.
Here's the log. Thank you for your advice.
2019-03-03 11: 22: 37,000 Starting Serviio
/var/packages/Serviio/scripts/start-stop-status.sh: line 60: /var/packages/Serviio/target/bin/serviio.sh: Permission denied
Meelis
Post Wed Mar 06, 2019 10:16 pm
Re: Permission denied
Maybe a Java issue. I am not sure... I use another java. You can try this java, for me it works.
viewtopic.php?f=14&t=24819
hard66
Post Sat Mar 09, 2019 10:19 am
I reinstalled Java 7, Java 8 (Synology Packages), Java 8 SE (PCLoadLetter). Same Problem with older version 1.6.1
hard66
Post Sun Mar 10, 2019 12:13 pm
It' s possible, that Serviio is stopped, because one of the HDD volume is full?
Meelis
Post Sun Mar 10, 2019 1:07 pm
I don't think so but make a try. Make some space...
