youtube video stop playing after some seconds
Hi guys,
Using YoutubeDL plugin I used serviio to play videos from youtube in Samsung TV serie D.
But some videos start playing and stop after immediately after some seconds with this exception:
I´m running Serviio 2.0 on Linux Server.
Anyone had the same problem?
- Code:
2019-09-11 00:34:40,948 INFO [PlaybackEventsManager] Playback of media item 1000000140005925 (Relaxing Waves For Home or Office - Calming Ocean Sounds to Brighten your Day [https://r4---sn-ovn-apnl.googlevideo.com/videoplayback?expire=1568159404&ei=TOJ3XaTnL6-NmLAP7uyeuAk&ip=79.169.121.250&id=o-APcni8kZuTfuNXCmj0TtnKFicL3v4_OsrhzhjQgaucEh&itag=22&source=youtube&requiressl=yes&mm=31%2C26&mn=sn-ovn-apnl%2Csn-25ge7nsl&ms=au%2Conr&mv=m&mvi=3&pl=22&initcwndbps=921250&mime=video%2Fmp4&ratebypass=yes&dur=28869.021&lmt=1564688586427558&mt=1568137688&fvip=4&c=WEB&txp=4432432&sparams=expire%2Cei%2Cip%2Cid%2Citag%2Csource%2Crequiressl%2Cmime%2Cratebypass%2Cdur%2Clmt&sig=ALgxI2wwRAIgMT7cOcMWMKOPalEyNGEKMvPZWhgtQkyF_mVJQTid714CICNRhRy09zFrAV88T0FrAD0O6Yhhk2fTO3X0S2KhnnlD&lsparams=mm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Cinitcwndbps&lsig=AHylml4wRQIhANdPH2z3Mc_awJu9kiM2lxzdtFFrFQgq7L2GyYlFkubjAiAVcC06CUSiI3rEtDP97f9OvgdApqSdqin0H9OYtj3cPg%3D%3D]) has stopped at 0% on Identifier=192.168.0.88, Profile=Samsung TV / player (C/D-series), Name=UE40D6500
2019-09-11 00:34:41,605 WARN [ServiioStatusService] PersistenceException occurred. Returning error code 500 to the REST layer. Message: Cannot read CoverImage with id = 1000000140005925
org.serviio.db.dao.PersistenceException: Cannot read CoverImage with id = 1000000140005925
at org.serviio.library.dao.CoverImageDAOImpl.read(CoverImageDAOImpl.java:104)
at org.serviio.library.dao.CoverImageDAOImpl.read(CoverImageDAOImpl.java:1)
at org.serviio.library.local.service.MediaService.getCoverImage(MediaService.java:70)
at org.serviio.ui.resources.server.RetrieveThumbnailServerResource.deliver(RetrieveThumbnailServerResource.java:50)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:524)
at org.restlet.resource.ServerResource.get(ServerResource.java:743)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:618)
at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:679)
at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:357)
at org.serviio.restlet.AbstractServerResource.doConditionalHandle(AbstractServerResource.java:49)
at org.restlet.resource.ServerResource.handle(ServerResource.java:1014)
at org.restlet.resource.Finder.handle(Finder.java:246)
at org.restlet.routing.Filter.doHandle(Filter.java:159)
at org.restlet.routing.Filter.handle(Filter.java:206)
at org.restlet.routing.Router.doHandle(Router.java:431)
at org.restlet.routing.Router.handle(Router.java:648)
at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:155)
at org.restlet.engine.CompositeHelper.handle(CompositeHelper.java:211)
at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:84)
at org.restlet.Application.handle(Application.java:384)
at org.restlet.Component.handle(Component.java:406)
at org.restlet.Server.handle(Server.java:516)
at org.restlet.engine.connector.ServerHelper.handle(ServerHelper.java:72)
at org.restlet.engine.adapter.HttpServerHelper.handle(HttpServerHelper.java:152)
at org.restlet.ext.simple.internal.SimpleContainer.handle(SimpleContainer.java:80)
at org.simpleframework.http.core.Dispatcher.dispatch(Dispatcher.java:121)
at org.simpleframework.http.core.Dispatcher.run(Dispatcher.java:103)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Caused by: java.sql.SQLDataException: The resulting value is outside the range for the data type INTEGER.
at org.apache.derby.impl.jdbc.EmbedResultSet.noStateChangeException(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.setLong(Unknown Source)
at org.serviio.library.dao.CoverImageDAOImpl.read(CoverImageDAOImpl.java:100)
... 53 more
Caused by: ERROR 22003: The resulting value is outside the range for the data type INTEGER.
at org.apache.derby.iapi.types.DataType.outOfRange(Unknown Source)
at org.apache.derby.iapi.types.SQLInteger.setValue(Unknown Source)
... 55 more
