Serviio still runs after delete - MacBook
interalian
Post Wed Feb 20, 2019 4:53 am
Hi, I installed Serviio a couple of years ago when I started serving music to my Yamaha NP-S2000 media player. I was simply playing my iTunes library, along with other files this way. I upgraded to a separate NAS and am now running another Media Server and UPnP app.
Serviio was deleted from my MacBook but is still one of the possible DLNA options on mconnect or other UPnP. I've searched the entire system and it isn't showing up.
Any tips as to what's going on here?
interalian
Post Mon Feb 25, 2019 4:21 pm
Re: Serviio still runs after delete - MacBook
Lots of views, no replies. Here's a screenshot from my mconnect app showing Servio as a local server, along with my iPhone and Plex NAS. Any love?
https://i.imgur.com/wM1JJjB.jpg
And here's the result of a spotlight search on my Mac.
https://i.imgur.com/vMNgQ7a.png
Mr. Roarke
Post Thu Apr 01, 2021 10:40 pm
interalian wrote:Lots of views, no replies. Here's a screenshot from my mconnect app showing Servio as a local server, along with my iPhone and Plex NAS. Any love?
I'm having the exact same issue. Removed it, but it still shows up, and still streams my songs. Was your issue resolved? If so, how did you do it?
Post Fri Apr 02, 2021 1:54 pm
I have no experience with a Mac, but with any computer program if the app is removed, it can't be running. If it's still running, it must still be on the computer somewhere. If it's still running after rebooting the computer, then the program is still on the hard drive somewhere. Again, I have no knowledge of MacOS, so I can't tell you how to determine what's running and where it's located. But there must be some sort of tool within the OS that allows tracking running programs.
