server doesn't appear on Samsung TV UE46C8700
I've a problem with servio 0.5.2. The server is not recognized by my TV, while there was no problem with 0.4.2 version. How can I do?
Thank you for your help
guimarc wrote:hi,
Sorry for the late answer to your reply. Where can I find the log? I'm not too familiar with this kind of things!
2011-04-27 15:21:16,703 INFO [MediaServer] ------------------------------------------------------------------------
2011-04-27 15:21:16,703 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-04-27 15:21:16,703 INFO [MediaServer] Petr Nejedly 2009-2011
2011-04-27 15:21:16,703 INFO [MediaServer] http://www.serviio.org
2011-04-27 15:21:16,703 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-04-27 15:21:16,703 INFO [MediaServer] OS Windows XP x86 5.1
2011-04-27 15:21:16,703 INFO [MediaServer] File encoding: windows-1252
2011-04-27 15:21:16,890 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-04-27 15:21:16,984 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-04-27 15:21:16,984 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-04-27 15:21:18,562 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-04-27 15:21:18,890 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-04-27 15:21:18,937 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-04-27 15:21:19,406 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-04-27 15:21:19,406 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-04-27 15:21:19,671 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-04-27 15:21:19,671 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-04-27 15:21:19,812 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-04-27 15:21:19,828 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-04-27 15:21:19,921 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-04-27 15:21:19,937 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-04-27 15:21:20,093 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-04-27 15:21:20,093 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-04-27 15:21:20,187 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-04-27 15:21:20,203 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-04-27 15:21:20,453 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-04-27 15:21:20,468 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-04-27 15:21:20,531 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-04-27 15:21:20,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-04-27 15:21:20,859 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-04-27 15:21:20,859 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-04-27 15:21:21,468 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-04-27 15:21:21,468 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-04-27 15:21:21,625 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-04-27 15:21:21,625 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-04-27 15:21:21,718 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-04-27 15:21:21,734 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-04-27 15:21:21,734 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-04-27 15:21:21,796 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-04-27 15:21:21,796 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-04-27 15:21:21,812 INFO [WebServer] Socket buffer set to 65535 bytes
2011-04-27 15:21:21,859 INFO [WebServer] WebServer starting on port 8895
2011-04-27 15:21:21,875 INFO [Device] Created UPnP Device with UUID: c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629, bound address: 192.168.0.10
2011-04-27 15:21:21,921 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-04-27 15:21:21,937 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-04-27 15:21:21,937 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-04-27 15:21:21,937 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-04-27 15:21:21,937 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-27 15:21:21,937 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-04-27 15:21:21,937 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1303910481937, LastAccessTime = 1303910481937, getTimeToLiveSeconds() = -1, createTime = 1303910481937 ]
2011-04-27 15:21:21,937 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-04-27 15:21:21,984 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-04-27 15:21:21,984 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-27 15:21:21,984 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-04-27 15:21:21,984 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-04-27 15:21:21,984 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-04-27 15:21:21,984 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-04-27 15:21:21,984 INFO [CompositeCacheConfigurator] Finished configuration in 47 ms.
2011-04-27 15:21:21,984 DEBUG [DiscoveryManager] UPNP device c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629 (192.168.0.10) is available
2011-04-27 15:21:21,984 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-04-27 15:21:21,984 INFO [EventDispatcher] Starting EventDispatcher
2011-04-27 15:21:21,984 INFO [RendererSearchSender] Searching for Renderer devices
2011-04-27 15:21:21,984 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-04-27 15:21:21,984 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-04-27 15:21:22,000 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Miniport d'ordonnancement de paquets) and address 192.168.0.10, timeout = 0
2011-04-27 15:21:22,187 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-04-27 15:21:22,203 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-04-27 15:21:32,203 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-04-27 15:21:42,234 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:27
2011-04-27 15:21:45,171 INFO [UpdateChecker] Checking if a new version is available
2011-04-27 15:21:46,000 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-04-27 15:21:46,562 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2011-04-27 15:21:48,671 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2011-04-27 15:21:48,703 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2011-04-27 15:21:50,781 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-04-27 15:21:50,796 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=serviio_media_library, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = null
2011-04-27 15:21:50,812 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,828 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,828 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,843 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,843 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,859 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,859 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,875 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-04-27 15:21:50,875 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,890 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,890 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,906 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:50,906 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,921 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,937 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-04-27 15:21:50,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2011-04-27 15:21:50,953 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-04-27 15:21:50,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:50,968 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-04-27 15:21:50,984 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,000 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-04-27 15:21:51,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,031 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,031 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,046 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-04-27 15:21:51,062 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,093 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,109 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,109 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,125 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-04-27 15:21:51,125 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,140 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,140 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,156 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,171 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,171 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,187 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,187 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,203 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2011-04-27 15:21:51,203 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2011-04-27 15:21:51,218 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-04-27 15:21:51,218 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,234 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-04-27 15:21:51,234 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2011-04-27 15:21:51,250 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-04-27 15:21:51,265 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,265 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,281 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,281 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,296 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,296 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,312 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,328 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,328 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,343 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,359 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,359 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,375 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,390 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-04-27 15:21:51,390 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-04-27 15:21:51,421 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-04-27 15:21:53,171 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-04-27 15:22:05,125 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2011-04-27 15:23:09,453 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:12
2011-04-27 15:23:14,015 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2011-04-27 15:24:22,406 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:03
2011-04-27 15:25:25,937 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:20
2011-04-27 15:26:46,218 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:06
2011-04-27 15:27:52,890 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:15
Cerberus wrote:This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
PaDeng wrote:Cerberus wrote:This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console.
"machine running Serviio" does this refer to the TV or the computer?
PaDeng wrote:Serviio still doesn't work for me. But thanks for the human response.
PaDeng wrote:I have restarted it, and refreshed everything also. I think the only thing I have not done is to re-boot the computer. The TV and computer/serviio still do not see one another.
I am sure I have done something stupid in the setup, but currently and obviously have no idea what it may be.
Users browsing this forum: Google [Bot] and 7 guests
