ffmpeg arrrgh!
WildRushSykes
Post Fri Sep 23, 2011 11:48 pm
ffmpeg arrrgh!
Having massive issues now ffmpeg is crashing every time it starts now i keep getting a string of errors in the logs any advice...
2011-09-24 00:40:58,752 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b014rbnb_1315580311.mp4,iplayerstream/secure_auth/1500kbps/MP/b014rbnb_1315579679.mp4,iplayerstream/secure_auth/480kbps/MP/b014rbnb_1315580400.mp4,iplayerstream/secure_auth/400kbps/b014rbnb_1315580297.mp4&et=1316828372&fmta-token=42575482558885da65d719f360c0ca50e4f58d90e39d93513268f456584eee27 tcUrl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b014rbnb_1315580311.mp4,iplayerstream/secure_auth/1500kbps/MP/b014rbnb_1315579679.mp4,iplayerstream/secure_auth/480kbps/MP/b014rbnb_1315580400.mp4,iplayerstream/secure_auth/400kbps/b014rbnb_1315580297.mp4&et=1316828372&fmta-token=42575482558885da65d719f360c0ca50e4f58d90e39d93513268f456584eee27 playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b014rbnb_1315579679.mp4 swfUrl=http://www.bbc.co.uk/emp/10player.swf swfVfy=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
... 1 more
all like that!
Java 7 Windows 8 and Serviio 0.6 if that helps
Post Sat Sep 24, 2011 12:12 am
Re: ffmpeg arrrgh!
are you running the service with a normal user (not Local Account)?
WildRushSykes
Post Sat Sep 24, 2011 12:20 am
Re: ffmpeg arrrgh!
its under my admin account using my name and password its just the bbc iplayer feeds according to the log. i took the bbci feeds out as windows error reporting was flicking up every 2 seconds :lol: and ffmpeg hasnt crashed since why would it cause it to crash when its parsing the iplayer feeds. Although its logged in i have noticed that windows has changed my password in the logon tab in the services menu to something 15 characthers long and mine is only 8 :lol: serviio is running though......
Last edited by WildRushSykes on Sat Sep 24, 2011 12:29 am, edited 1 time in total.
Post Sat Sep 24, 2011 12:28 am
Re: ffmpeg arrrgh!
It has new libraries linked to it to support these online sources. Try to get a static FFmpeg build from here: http://ffmpeg.zeranoe.com/builds/
WildRushSykes
Post Sat Sep 24, 2011 12:31 am
Re: ffmpeg arrrgh!
Ok i grabbed the latest static 32 bit build what do i do with it? :lol: ffmpeg NOOB. Im assuming you overwrite the serviios ffmpeg with the new one then restart serviio??? Wild prepares to press the self destruct button............ :lol:
Post Sat Sep 24, 2011 2:13 pm
Re: ffmpeg arrrgh!
WildRushSykes wrote:Ok i grabbed the latest static 32 bit build what do i do with it? :lol: ffmpeg NOOB. Im assuming you overwrite the serviios ffmpeg with the new one then restart serviio??? Wild prepares to press the self destruct button............ :lol:
pleaase dont you will make a mess on the carpet and it a bugger to get out blood :P
Return to General discussion
