COMPETITION: Win Sony SMP-N100 netbox (EU only)
Post Tue Oct 18, 2011 3:14 pm
The rules are simple: comment on this topic with the single feature you are missing the most in Serviio currently.
The competition will run until October 24th 1:00 PM BST and the winner will be picked randomly from all the commenters. Make sure you only add single comment, users with multiple entries in this topic will be removed from the competition. Also only apply if you live in the EU (sorry about this).
This competition is sponsored by the very cool people at Sony Europe.
ortner
Post Tue Oct 18, 2011 3:28 pm
Re: COMPETITION: Win Sony SMP-N100 netbox (EU only)
The abillity to stream from RAR archives.
freespirit
Post Tue Oct 18, 2011 3:36 pm
Hey zip! Thanks for opportunity! Ask for a feature + chance of a prize it's a win-win situation ;)
I would love to have implemented a "sort by" feature in each folder, or if not possible several subfolders (each of them sorted by a field).
I'm mainly looking for a "sort by creation date DESC" feature, in order to see file list starting from last created file to first one (all files not just 10 like in "Last Added"), but i believe that if you could select from various fields (date, name, size, type...) will be amazing ;)
Thank you so much for your work,
Nicola
nickmax1
Post Tue Oct 18, 2011 3:37 pm
Ability to organise online feeds
(love it though!)
WorldOfHurt
Post Tue Oct 18, 2011 3:38 pm
Ability to interoperate with a mythtv backend as standard would be cool.
norrgrd
Post Tue Oct 18, 2011 3:48 pm
ortner wrote:The abillity to stream from RAR archives.
I second that
animaleyes76
Post Tue Oct 18, 2011 3:50 pm
Definitely online feeds.. Does that count as it's coming soon?? :D
Keep up the great work, Serviio is amazning :D
Soralan
Post Tue Oct 18, 2011 3:58 pm
The ability to start a video from a set time as forwarding mkv files cause syncing issues.
SeeR
Post Tue Oct 18, 2011 4:02 pm
Parental control for specific folders
  • Mark in library some folder that it should use parental control
  • Set some 4 digit PIN in settings.
  • When connecting to the server from TV you will see folder called "Parental Control" which initially shows only "PIN" folder
  • This "PIN" folder will contain subfolders named 0,1,2,3,4,5...9
  • Each sub folder will have another 10 subfolders and the whole tree is 4 levels deep
  • Only if you choose correct folder(PIN) combination protected folders apeear in "Parental Control" folder
  • You must enter the PIN every time TV closes the connection (turn off TV, switch in TV menu from DLNA to other input source),
    eventually there is another subfolder in "PIN" called "Invalidate"
This feature is based on assumption that there is something like session in DLNA.
Evostance
Post Tue Oct 18, 2011 4:04 pm
The ability to stream from a TV card (useful for portable devices and players without an aerial input)
blouk
Post Tue Oct 18, 2011 4:15 pm
Ability to organize the data base ourself throught a webinterface ...
mbailey
Post Tue Oct 18, 2011 4:20 pm
Better visability of what the server is doing. For example when refreshing media or adding folders, it is impossible to tell how far is is through the process.
Nugstar
Post Tue Oct 18, 2011 4:27 pm
Automatic extraction/conversion of subtitles. Would be nice to be able to play subtitled mkv files without having to rip/convert subs to srt.
iSparK
Post Tue Oct 18, 2011 4:32 pm
The abillity to be able to stream/playback .ios files, I myself have created a library of all my DVD/B-Ray's so this feature would be amazing... :D
rezyn
Post Tue Oct 18, 2011 4:41 pm
Hability to setup folders on the main view that are already shared by a top folder hierarchy.
PS: thank you very much for all the work.
swiiney
Post Tue Oct 18, 2011 4:53 pm
Ability to create playlists that are seen as folder frome the DLNA player. So we could be able to create virtual folders.
Korumera
Post Tue Oct 18, 2011 4:56 pm
The ability to stream from Rar Archives (as mentioned by others)
lentus
Post Tue Oct 18, 2011 4:57 pm
more advanced subtitle support.
martyn
Post Tue Oct 18, 2011 4:59 pm
ability to stream videos from any site ( legally of course )
mhenkka
Post Tue Oct 18, 2011 5:05 pm
parental control setting for selected folders
Return to Announcements / News
