Hulu and using a proxy
jhb50 wrote:How does one create a vpn connection for the TV? Wouldn't it have to be done in the router?
hiviking wrote: Is it possible to login via a plugin?
WildRushSykes wrote:I have a proxy setup just for watching hulu from the uk and was wondering if its possible to use it with serviio without having to tunnel all my traffic through it like normal internet browsing and if so how
Harry123 wrote:I would suggest if you want to stream then Kodi might be your first choice as i am using Kodi for streaming since very long.
I had installed the setup of VPN for Kodi to make my streaming safe from this guide: https://relaska.com/setup/
From now onwards i do have a freedom of streaming access with the help of Kodi all over the world.
You can watch those stuff on Kodi as well which is available on Hulu.
