Fri Mar 16, 2012 9:46 am by scrissti
I got this in the logs, and at that time when there should be no activty (TV is off, cache is set to 24 hours)
- Code:
2012-03-16 11:42:43,571 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (sri): no protocol: tml PUBLIC
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:169)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
Caused by: java.net.MalformedURLException: no protocol: tml PUBLIC
at java.net.URL.<init>(Unknown Source)
at sun.reflect.GeneratedConstructorAccessor1899.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.codehaus.groovy.reflection.CachedConstructor.invoke(CachedConstructor.java:77)
at org.codehaus.groovy.runtime.callsite.ConstructorSite$ConstructorSiteNoUnwrapNoCoerce.callConstructor(ConstructorSite.java:102)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callConstructor(AbstractCallSite.java:190)
at Seriale.getMovieRealURL(serialepenet.groovy:115)
at Seriale$getMovieRealURL.callCurrent(Unknown Source)
at Seriale.extractItems(serialepenet.groovy:86)
at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
From the TV it seems that some times it works some times it doesn't.
And yes I don't care about different qualities.
