Updating library data using REST API and Cli
smmortazavi
Post Sat Mar 31, 2012 5:23 pm
First of all I should express my gratuitousness towards zip, for this great piece of software. Secondly, I hope I haven't spammed here with a duplicate question but I really could not find a similar question.
I need to update library data using REST API. I used curl :
curl -v -H "Content-Type: application/xml"  -X PUT --data @repos http://127.0.0.1:23423/rest/repository
which sends a PUT request with the body data from file named "repos". This is the content of this file:
<?xml version="1.0" encoding="UTF-8" ?>
<repository>
  <sharedFolders/>
  <searchHiddenFiles>false</searchHiddenFiles>
  <searchForUpdates>true</searchForUpdates>
  <automaticLibraryUpdate>true</automaticLibraryUpdate>
  <automaticLibraryUpdateInterval>5</automaticLibraryUpdateInterval>
  <onlineRepositories>
    <onlineRepository>
      <id>116</id>
      <repositoryType>FEED</repositoryType>
      <contentUrl>http://gdata.youtube.com/feeds/api/users/lengas32/uploads?v=2&amp;max-result=150</contentUrl>
      <fileType>VIDEO</fileType>
      <repositoryName>Seconds From Disaster</repositoryName>
      <enabled>true</enabled>
    </onlineRepository>
    <onlineRepository>
      <id>117</id>
      <contentUrl>http://gdata.youtube.com/feeds/api/users/aircrashuploader/uploads?v=2&amp;max-result=150</contentUrl>
      <repositoryName>Air-Crash</repositoryName>
    </onlineRepository>
  </onlineRepositories>
  <maxNumberOfItemsForOnlineFeeds>-1</maxNumberOfItemsForOnlineFeeds>
  <onlineFeedExpiryInterval>2</onlineFeedExpiryInterval>
  <onlineContentPreferredQuality>HIGH</onlineContentPreferredQuality>
</repository>
The problem is that serviio receives this request but does not add the items. I see these lines in the log after the request is sent:
2012-03-31 20:14:53,499 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-03-31 20:14:58,258 DEBUG [RepositoryServerResource] Updating repository with values: OnlineRepository [repoType=FEED, fileType=VIDEO, repositoryUrl=http://gdata.youtube.com/feeds/api/users/lengas32/uploads?v=2&max-result=150, repositoryName=Seconds From Disaster, thumbnailUrl=null]
2012-03-31 20:14:58,258 DEBUG [RepositoryServerResource] Updating repository with values: OnlineRepository [repoType=FEED, fileType=VIDEO, repositoryUrl=http://gdata.youtube.com/feeds/api/users/aircrashuploader/uploads?v=2&max-result=150, repositoryName=Air-Crash, thumbnailUrl=null]
2012-03-31 20:14:58,259 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-03-31 20:14:58,261 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 116)
but I receive this response from the server :
<html>
<head>
   <title>Status page</title>
</head>
<body style="font-family: sans-serif;">
<p style="font-size: 1.2em;font-weight: bold;margin: 1em 0px;">Internal Server Error</p>
<p>The server encountered an unexpected condition which prevented it from fulfilling the request</p>
<p>You can get technical details <a href="http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.5.1">here</a>.<br>
Please continue your visit at our <a href="/">home page</a>.
</p>
</body>
</html>
and the library does not get updated. I'm on serviio version 0.6.2 windows.
Any ideas?
Thanks in advance.
Post Sat Mar 31, 2012 6:09 pm
Re: Updating library data using REST API and Cli
When adding items do not specify an id. Also I believe you must load the whole repository, not just the new items, else the repository will only have the new items and the old ones will be lost.
smmortazavi
Post Sat Mar 31, 2012 9:29 pm
jhb50 wrote:When adding items do not specify an id. Also I believe you must load the whole repository, not just the new items, else the repository will only have the new items and the old ones will be lost.
Thanks a lot!!!!!
It worked like a charm when I removed IDs. You are right about sending the whole repository, I should send a GET first and add the new items without the IDs.
