Sony W5500 incorrect display.
rav4cas
Post Sat Oct 02, 2010 12:29 pm
Anyone help with problem transcoding from PC to Sony W5500 tv, video files on PC are 16:9 widescreen (Black bars top & bottom) when streamed to Sony TV they appear as full screen.
The transcoding seems to be enlarging the picture, with the TV displaying a stretched ouput. Had the same problem went i was testing Mezzmo server. Thought i would try Serviio
but no difference. The TV is set to 16:9 display, have tried it with all the different display options but no luck. Do not know much about transcoding, but i assume the problem lies
in the transcoding parameters. Anybody who can help me? Help would be greatly appreciated.
Gerro
Post Thu Oct 07, 2010 5:49 am
Re: Sony W5500 incorrect display.
I have the same problem, when I play a mkv file the aspect ratio isn't respected. When I play mkv through Other dlna server like Wild Media Server or PS3MS the file is reproduced in the correct way (with black bar on top and bottom); when I play mkv using Serviio I don't see the black bar, the video is streched to fit 16:9 tv. How I can solve the problem? Thank you.
Post Thu Oct 07, 2010 8:43 am
can you post ffmpeg -i <file> of the file that is not played properly?
Gerro
Post Thu Oct 07, 2010 9:05 am
This is the information of mkv file with problem:
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
built on May 3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldflags=-L/static/lib --extra-cflags=-I/static/include
libavutil 50.15. 0 / 50.15. 0
libavcodec 52.66. 0 / 52.66. 0
libavformat 52.62. 0 / 52.62. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
[matroska @ 013ecf60]max_analyze_duration reached
[matroska @ 013ecf60]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1) -> 500.00 (500/1)
Input #0, matroska, from 'Notte folle a Manhattan.mkv':
Duration: 01:37:27.08, start: 0.000000, bitrate: 384 kb/s
Chapter #0.0: start 0.000000, end 266.200000
title : 1. Chapter 1
Chapter #0.1: start 266.200000, end 520.520000
title : 2. Chapter 2
Chapter #0.2: start 520.520000, end 829.640000
title : 3. Chapter 3
Chapter #0.3: start 829.640000, end 1070.920000
title : 4. Chapter 4
Chapter #0.4: start 1070.920000, end 1365.080000
title : 5. Chapter 5
Chapter #0.5: start 1365.080000, end 1675.680000
title : 6. Chapter 6
Chapter #0.6: start 1675.680000, end 2052.080000
title : 7. Chapter 7
Chapter #0.7: start 2052.080000, end 2242.800000
title : 8. Chapter 8
Chapter #0.8: start 2242.800000, end 2456.120000
title : 9. Chapter 9
Chapter #0.9: start 2456.120000, end 2617.680000
title : 10. Chapter 10
Chapter #0.10: start 2617.680000, end 2704.280000
title : 11. Chapter 11
Chapter #0.11: start 2704.280000, end 2981.360000
title : 12. Chapter 12
Chapter #0.12: start 2981.360000, end 3371.760000
title : 13. Chapter 13
Chapter #0.13: start 3371.760000, end 3868.920000
title : 14. Chapter 14
Chapter #0.14: start 3868.920000, end 4052.320000
title : 15. Chapter 15
Chapter #0.15: start 4052.320000, end 4332.680000
title : 16. Chapter 16
Chapter #0.16: start 4332.680000, end 4471.680000
title : 17. Chapter 17
Chapter #0.17: start 4471.680000, end 4594.520000
title : 18. Chapter 18
Chapter #0.18: start 4594.520000, end 4834.840000
title : 19. Chapter 19
Chapter #0.19: start 4834.840000, end 5121.480000
title : 20. Chapter 20
Chapter #0.20: start 5121.480000, end 5302.040000
title : 21. Chapter 21
Chapter #0.21: start 5302.040000, end 5439.680000
title : 22. Chapter 22
Chapter #0.22: start 5439.680000, end 5549.320000
title : 23. Chapter 23
Chapter #0.23: start 5549.320000, end 5847.082000
title : 24. Chapter 24
Stream #0.0: Video: h264, yuv420p, 716x432 [PAR 1:1 DAR 179:108], PAR 223:157 DAR 39917:16956, 500 tbr, 1k tbn, 50 tbc
title : Notte Folle a Manhattan (Date Night)
Stream #0.1(ita): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
title : Italian AC3 5.1
Stream #0.2(eng): Audio: aac, 48000 Hz, stereo, s16
title : English AAC-LC 2.0 VBR (Q=0.4)
Stream #0.3(ita): Subtitle: 0x0000
title : Italian Forced Caption
Stream #0.4(ita): Subtitle: 0x0000
title : Italian Normal Caption
Stream #0.5(eng): Subtitle: 0x0000
title : English Normal Caption
Post Thu Oct 07, 2010 9:26 am
can you take a picture of the TV and how is the video stretched?
Gerro
Post Thu Oct 07, 2010 9:50 am
The video fit all tv screen 16:9. My TV is Sony KDL-40HX800. When I return home I take the picture.
With this file I have another problem: the audio track streamed to TV is English track instead of the italy one. I resolved the problem removing the english track, there is a way to set as default language audio the italian?
Post Thu Oct 07, 2010 10:18 am
Gerro wrote:there is a way to set as default language audio the italian?
Not yet
Gerro
Post Thu Oct 07, 2010 4:42 pm
This is the picture of Serviio streaming:
http://img834.imageshack.us/i/serviio.jpg/
This is the picture of WildMediaServer streaming
http://img837.imageshack.us/i/wildmediaserver.jpg/
moviejack
Post Thu Nov 04, 2010 12:44 am
What I use is just a 5meter Hdmi cable from my pc to the tv, and play Mkv files on Media Player by extending the screen. The videocard has 2 outputs a dvi and hdmi so i can always do 2 things at one time.
The file plays fine in full screen, you can change language and stuff in the right bottom of the desktop, on that green arrow or something.
I used to stream files through xbox 360, but i found just conecting a extra hdmi from the pc to tv works a lot better.
You do need to download the shark codec pack for media player.(windows 7)
Or If you have not pressed HOME on your remote, and go all the way to the left, you can go to Screen adjustment, and maybe play around with the settings there it might work, as my pc didnt fit the screen, and i didnt know where to change it and accidently stumbled acros the right setting there.
tombert
Post Fri Nov 26, 2010 8:15 pm
For my point of view the serviio.jpg looks fine ...
Your TV is 16:9 and the video is 16:9 - so it should fit - I think wildm is doing it wrong.
tombert
Post Sat Nov 27, 2010 6:57 am
tombert wrote:For my point of view the serviio.jpg looks fine ...
Have to correct myself. There is really something I don't understand ... I converted an HD movie to aspect 4:3 and serviio displays it fully on TV 16:9, the windows thumbs are displayed 4:3 ... when I convert the same video to 16:9 it is streched (black bars on top and bottom).
Is my assumption correct that a 16:9 movie should fit on a 16:9 TV?
