USTREAM.tv
peje1873
Post Mon Sep 03, 2012 7:06 pm
Re: USTREAM.tv
Excellent, thanks again for your help jhb50. Sorry for the hassle.
Pete
Panasonic TX-P42GT30B
Panasonic DMR-HW120EBK
Panasonic DMP-BDT110EB
Custom Home Server: Intel DH77KC with i7-2600K, 8GB DDR3, 2TB System Drive, 7.5TB RAID5 array with hotspare.
S/W: W7 Ultimate, Serviio, SABnzbd, SickBeard, Couch Potato, Headphones & FileZilla Server.
peje1873
Post Tue Sep 04, 2012 10:41 am
Re: USTREAM.tv
Am I ok to post a troubleshooting query here or is there somewhere else it would go, like the Panasonic support section?
In a nutshell the NASA channel works sometimes but not others, the TV is bringing up a 'cannot read file error' or 'file type not supported'. If I keep trying it will sometimes work fine, playing well with very little judder. I will put up a section of the log once I know where it should go.
Thanks again,
Pete.
Post Tue Sep 04, 2012 1:14 pm
Re: USTREAM.tv
Since its intermittent, it could simply be that the NASA stream has gone offair since the webresource was last refreshed. Try a force refresh next time it happens. If NASA disappears from the folder it is offair.
prmadmax
Post Sat Sep 29, 2012 5:43 pm
Re: USTREAM.tv
While using this plugin I am not getting any audio from any streams put into this.
I am not getting any audio from any other streams either.
The video looks great just not getting any audio. This is on Bravia KDL-22EX320
Regards, MadMax
Serviio Beta Tester
Samsung Series 6 UE32H6400 (3D Full HD Smart TV)
Synology DS1512+ / 3GB Ram / 5x 3TB WD Red Edition HDDs with 5.2 firmware running Patters Serviio package for Synology NAS
CigDangle
Post Thu Oct 11, 2012 6:33 pm
Re: USTREAM.tv
I'm seeing the same problem on a PS3.
Here's the link I'm using: http://www.ustream.tv/channel/A-Mediocre-Time-with-Tom-and-Dan
The link does not work at all on my Sony BDP-S370.
Xbox 360 - PlayStation 3 - Sony BDP-S370 - HTC Evo V & HP TouchPad running CM9 (Android) - serviio 1.0.1 - Windows 2003 Server Standard x64 Edition
prmadmax
Post Tue Oct 30, 2012 11:47 pm
Re: USTREAM.tv
Is there any updates for this?
Regards, MadMax
Serviio Beta Tester
Post Wed Oct 31, 2012 4:43 am
Re: USTREAM.tv
Why? What's the problem?
prmadmax
Post Wed Oct 31, 2012 3:54 pm
Re: USTREAM.tv
prmadmax wrote:Hi,
I am still not getting any audio.
Regards, MadMax
Serviio Beta Tester
Post Wed Oct 31, 2012 7:24 pm
Re: USTREAM.tv
That indicates it has nothing to do with the plug-in.
prmadmax
Post Wed Oct 31, 2012 7:39 pm
Re: USTREAM.tv
The stream works if I add it manually the old way.
Regards, MadMax
Serviio Beta Tester
Post Thu Nov 01, 2012 1:05 am
Re: USTREAM.tv
What stream?
prmadmax
Post Thu Nov 01, 2012 1:43 am
Re: USTREAM.tv
http://www.ustream.tv/nasahdtv
Regards, MadMax
Serviio Beta Tester
CigDangle
Post Fri Nov 16, 2012 7:05 pm
Re: USTREAM.tv
CigDangle wrote:I'm seeing the same problem on a PS3.
I'm still seeing this issue. Anyone have any ideas? The link above is live right now...
prmadmax
Post Fri Nov 16, 2012 7:08 pm
Re: USTREAM.tv
Same here :?:
We need the plugin dev to look into this.
Regards, MadMax
Serviio Beta Tester
cool120
Post Mon May 27, 2013 10:40 am
Re: USTREAM.tv
None to dev. a new version ? USTREAM ffmpeg convert RTMP not functionally
Kneze2005
Post Sat Aug 10, 2013 8:24 am
Re: USTREAM.tv
piscui
Post Tue Sep 10, 2013 3:02 pm
Re: USTREAM.tv
Try again?
hake
Post Fri Sep 20, 2013 9:14 am
Re: USTREAM.tv
looks like it doesn't work anymore. i don't see "cdnStreamName" or "streamName" in amf file. something changed. there is no direct url to the video stream anymore, all information encapsulated in swf-player? any ideas?
myheeart
Post Sun Sep 22, 2013 10:55 pm
Re: USTREAM.tv
Kneze2005 wrote:http://piscui.webear.net/ustream.php
http://www.ustream.tv/ffrc
Error: Not a live feed.
WHY?
Serviio URL:
http://iphone-streaming.ustream.tv/ustreamVideo/2298576/streams/live/playlist.m3u8
ffmpeg command:
ffmpeg -i "http://iphone-streaming.ustream.tv/ustreamVideo/2298576/streams/live/playlist.m3u8"
hake
Post Mon Sep 23, 2013 4:13 pm
Re: USTREAM.tv
anyone can help in my case? thanks.
http://www.ustream.tv/nasajpl
http://iphone-streaming.ustream.tv/ustreamVideo/498663/streams/live/playlist.m3u8
404 Not Found
the same situation with
http://www.ustream.tv/nasajpl2
Return to Available plugins
