sony KDL-40ex403, win 7 64bit, Home Media Network Hard Drive
werdas
Post Tue Jan 04, 2011 1:37 pm
Hi guys,
I want to stream video from my nas-Home Media Network Hard Drive to my sony kdl--40ex403, but no files found , as later I have found out that avi, divx files suported only form usb, so googled and got to serviio,
downloaded, intsalled, had some problems with java, so had to install both 32bit and 64bit versions,
but still can not stream xvideo to my sony,
the instructions on serviio website is not clear enough for me.
can someone help me please?
Post Tue Jan 04, 2011 1:56 pm
Re: sony KDL-40ex403, win 7 64bit, Home Media Network Hard Drive
- Do you have media added to the serviio library, check the serviio log file for that, or use INTEL TOOLS (AV Media Controller) to browse serviio library.
- When media are shared from network hard Drive, check the write access, see FAQ My files (on remote drive) are not scanned
werdas
Post Tue Jan 04, 2011 2:42 pm
I have added a network drive letter to media library
when tv navigates to network drive letter V:\ I'm getting -there are no items to display
what is , and how to use INTEL TOOLS (AV Media Controller?
where can I find serviio log file?
how to check the write access?
Post Tue Jan 04, 2011 4:56 pm
werdas wrote:I have added a network drive letter to media library
I think UNC path is better, something like \\Share\Video\...
Look at this: viewtopic.php?f=5&t=1113&p=5632&hilit=UNC#p5632
werdas wrote:what is , and how to use INTEL TOOLS (AV Media Controller)?
These are tools for UpnP/DLNA debugging, with AV Media Controller, you can see information on UpnP/DLNA device: Media Renders (your TV, BluRay,etc) and Content Directories (Server like Serviio)
werdas wrote: where can I find serviio log file?
Do you read viewtopic.php?f=5&t=7&start=0
werdas wrote: how to check the write access?
For windows users, look at serviio service write access: viewtopic.php?t=1113&p=5281#p5281
werdas
Post Wed Jan 05, 2011 11:33 am
not sure how to add unc path
http://img408.imageshack.us/img408/7418/project1em.jpg
http://img43.imageshack.us/img43/1253/project2f.jpg
when i try to access \\192.168.0.184\movies from my bravia, I can see only one folder (and some of the videos in it) and no videos in a root directory
why?>
werdas
Post Wed Jan 05, 2011 11:44 am
I do not have any account on my win 7, so not sure how do I set up :
'Make sure the user that runs Serviio server/service has got access to the shared folders. If you are on Windows, check that the user running the Windows service has got access. To run the service as a different user go to Services (from the Windows Control Panel → Administrative Tools or typing "Services.msc" in the Run command on Start menu), select Serviio, right-click -> Properties, Log On tab, enter user's details and restart the service.'
http://img20.imageshack.us/i/project3l.jpg
when I try to log on as administrator, with no password, on restart windows comes with error 1069, windoes could not start serviio service on local computer, due to logon failure
werdas
Post Wed Jan 05, 2011 11:46 am
how to set same credentials on the NAS?
Accessing a NAS device: the exact same set of credentials must be created on the NAS device. The Windows credentials must be a local user and not a domain user. The user must have "Run As Service" rights. The remote path must be entered as a UNC path in the Serviio Console (mapped drive letters will not work since user running the Serviio service is not aware of your mapped drives).
Post Wed Jan 05, 2011 12:54 pm
You can also try to stop the serviio service and run serviio.bat instead, see if it makes any difference.
werdas
Post Wed Jan 05, 2011 1:47 pm
added each folders individually, tv now can see the video files, but how can I make it work when my pc is turned off?
Post Wed Jan 05, 2011 1:59 pm
werdas wrote:but how can I make it work when my pc is turned off?
????? you need serviio server to deliver media to your TV so PC turned ON.
werdas
Post Wed Jan 05, 2011 2:00 pm
oh, I see, so pc must be turned on .. shame...
thank you very much
Return to General discussion
