Hulu (US only)
josiok
Post Sat Feb 02, 2013 6:20 pm
Re: Hulu (US only)
I've been using Serviio for some the past couple years and love it. Works great with my Samsung TV and Sony BluRay.
Lately I'm having trouble with some online feeds. They used to work perfectly, but now I'm seeing "No content available" on some feeds.
For example- I am using 'http://www.hulu.com/feed/show/902/episodes' as my feed for The Daily Show with Jon Stewart. It looks fine when I put it in my browser and used to work fine with Serviio.
When I look in the serviio.log file (debug mode), I see the following lines-
2013-02-02 09:41:46,457 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: The Daily Show with Jon Stewart - s18 | e51 - Mon, Jan 28, 2013
2013-02-02 09:41:46,457 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item The Daily Show with Jon Stewart - s18 | e51 - Mon, Jan 28, 2013: Cannot invoke method getText() on null object
This is repeated for each program in the Daily Show feed. Note that other Hulu feeds (e.g. Colbert) work fine.
Any ideas on where my problem lies and how to fix it? Thanks!
Post Mon Feb 04, 2013 1:26 pm
Re: Hulu (US only)
Is that content free or Hulu Plus only?
josiok
Post Mon Feb 04, 2013 10:04 pm
Re: Hulu (US only)
zip wrote:Is that content free or Hulu Plus only?
It's a free Hulu feed.
I checked today and the feed is working again. I've seen this issue on other feeds, too, though I'm not sure if it is only a problem with Hulu feeds, since I primarily use the online feeds to watch Stewart and Colbert. Forcing a refresh doesn't seem to make a difference, either.
Xmantium
Post Sun Feb 24, 2013 10:33 pm
Re: Hulu (US only)
Hello HULU users (one im not :( )
To make adding hulu feeds easier, ive adding the most popular shows to http://www.serviidb.com/plugin-api-name/hulu-us
Quickest way adding them, use 3rd party apps in my signature below, they all use ServiiDB.com integration
You can pm me of any shows you want added to the database or join the site to add it yourself ;)
hwmonkey
Post Sun Mar 10, 2013 11:51 pm
Re: Hulu (US only)
I am trying to work around the hulu limit to the number of videos returned. I figure that if I can determine how to control the sort order to be DATE in ASCENDING order, I can then create multiple searches somehow using that as criteria.
1. Has anyone already found a solution?
2. Anyone know how to sort by date? I have tried keywords I am seeing like 'original_premiere_date' and 'normal' but not having luck
3. Anyone know how to change the order? I have tried asc and desc but I am not having success
An example url:
http://www.hulu.com/feed/search?query=s ... pe=episode
THANKS!!
bmn
Post Thu Mar 14, 2013 9:36 pm
Re: Hulu (US only)
Hulu is not working for me. I added a feed, it works in my browser so I know the feed address is good. I then add it to servio but when i go to access it, I get not listings.
WildRushSykes
Post Thu Mar 14, 2013 11:57 pm
Re: Hulu (US only)
Might be an idea to post your device and maybe some detailed log files as just stating that they are not showing isn't going to help us identify your problem :lol:
Post Sun Mar 17, 2013 8:52 pm
Re: Hulu (US only)
and the feed URL
rubbles88
Post Thu Mar 21, 2013 3:59 am
Re: Hulu (US only)
The hulu plugin does not play the ad and this worked nicely until recently. I noticed that hulu stream will play until the first ad where at this point the stream disconnects and serviio loads the next video in the feed. I could no longer view any video from hulu in its entirety. Any solution to this? I'm wondering if letting the ads play will allow viewing hulu videos in its entirety again.
slyguy42o
Post Tue Mar 26, 2013 4:34 pm
Re: Hulu (US only)
Does Hulu not always post shows to their feed URL that they have posted on the site?
When I hit hulu.com I can see a new episode posted, but when I hit the feed URL, there isn't any shows listed.
for example
http://www.hulu.com/feed/show/6290/episodes
shows nothing, yet when I hit
http://www.hulu.com/watch/471296
there is a new ep available.
slyguy42o
Post Tue Mar 26, 2013 10:09 pm
Re: Hulu (US only)
slight edit, I posted the wrong URL in. Overall 98% of shows seem to update correctly, but some like the example above don't get their feeds updated for some reason.
HayDegha0917
Post Sun Apr 07, 2013 5:15 pm
Re: Hulu (US only)
Hulu RSS feeds seem to lag behind the Hulu queue. It can take up to 3-4 days for a new episode to post to the feed.
Seems like Hulu is trying to get rid of the RSS feeds.
rubbles88
Post Mon May 06, 2013 8:02 am
Re: Hulu (US only)
Does the hulu plugin still work? All of a sudden, my hulu feed is empty. Did hulu do something which caused this problem or is there anything in my settings, which I doubt because I haven't changed anything in the settings.
Luscombag
Post Fri May 10, 2013 3:36 am
Re: Hulu (US only)
rubbles88 wrote:Does the hulu plugin still work? All of a sudden, my hulu feed is empty. Did hulu do something which caused this problem or is there anything in my settings, which I doubt because I haven't changed anything in the settings.
I am having the same problem. 3 days ago my Hulu feeds were fine, but now they are gone. The last time they were working I was running Serviio 1.0.1 and upgraded today to version 1.2.1.
It may be coincidence, but did something change with 1.2.1 to eliminate Hulu?
[b]Serviio 1.5.2 | Sony PS3 Slim | Sony PS4 | Sony BDP-BX57 BD Player | Windows 7 I AMD Octa-Core
slyguy42o
Post Fri May 10, 2013 4:19 pm
Re: Hulu (US only)
plugin is definitely working.. My wife was watching shows last night.
Liton
Post Thu May 16, 2013 4:23 am
Re: Hulu (US only)
I was wondering if someone could help with the Hulu feeds. First let me say that I have several Hulu feeds already setup working fine using the following format - http://www.hulu.com/feed/show/2309/episodes
Where my problem comes in is that I wanted to setup a new feed and the feed was for Warehouse 13. I used the following feed URL - http://www.hulu.com/feed/show/2231/episodes and it worked however it is missing the last 2 eposides. So then I searched the forum and found a new link to try so I try the following URL's:
http://www.hulu.com/#!search?q=warehouse+13+season+4
and
http://www.hulu.com/feed/search?fs=0&qu ... pe=episode
Neither of these will render any videos. Can someone please tell me the proper URL format to use to get feeds to work using the search URL format? I also want to explain that the above is just an example I can't get anything (duck dynasty, Star Trek Next Generation, Warehouse 13, Star Trek Enterprise, etc...) to work when using the search format for the URL.
anjilslaire
Post Sat May 25, 2013 2:57 am
Re: Hulu (US only)
I'm sure I've missed it somewhere, but how do we find new RSS feeds for Hulu? I've been using a list from here http://www.paulscomputerservice.com/art ... php?ID=259 but it's not updated.
Specifically, I'm looking for Motive
http://www.hulu.com/motive
How do we translate that into something like http://www.hulu.com/feed/show/****** to put it into Serviio?
anjilslaire
Post Sat May 25, 2013 8:18 am
Re: Hulu (US only)
Found it.
I checked the page source and found the show id. Do a search for
var rawData = {"id":
andput the subsequent id # into the url as
http://www.hulu.com/feed/show/*****/episodes
Thanks, and keep up the great work on the plugin :)
misterbkh
Post Sun Jun 02, 2013 1:44 am
Re: Hulu (US only)
i'm having trouble adding shows that disappeared from online feeds, haven't used hulu in awhile but the site is different
which page do i look for show id, from a page an episode is playing or from the main show page where you choose which season or episode
and what is the string in page source to look for.
also optimal settings to use on feed expiry and quality that work.
thanks
Brian
Spaceboy64
Post Wed Jun 19, 2013 2:10 am
Re: Hulu (US only)
I have been watching Defiance on Hulu via Serviio now for a couple of weeks.
This is the URL that has been working:
http://www.hulu.com/feed/show/11241/episodes
Now there should be a new episode available, Defiance - s1 | e9 - If I Ever Leave This World Alive
It shows up in my web browser, but on my TV, the latest episode is Defiance - s1 | e8 - I Just Wasn't Made for These Times
Any idea why it doesn't show up? Is there a way to specify a certain episode in the URL?
Sometimes this happens with shows I've downloaded on my hard drive, but a refresh eventually fixes it.
Return to Available plugins
Users browsing this forum: No registered users and 74 guests
