How to add plugins in Apple Mac OS
sheikh73
Post Fri Aug 31, 2012 11:39 pm
I Installed Serviio on my Mac Book. I added the video feeds but nothing was working then I realized that it is missing plugins.. But I couldnt find any folder where I can add plugins.. Any body can guide me where I can find the folder for serviio and then add plugins to that folder.. I am new to Mac OS... Thanks
frankly
Post Mon Sep 03, 2012 7:56 am
Re: How to add plugins in Apple Mac OS
Hi, Open the serviio-folder in your applications-map. Right-click on Serviio.app and select " Show Contents-Package" (or something).
Open Contents-folder, then Resources, Java and there it is.
Good Luck!
sheikh73
Post Wed Sep 05, 2012 2:59 am
frankly wrote:Hi, Open the serviio-folder in your applications-map. Right-click on Serviio.app and select " Show Contents-Package" (or something).
Good Luck!
Well I couldn't find Serviio Folder anywhere on the hard drive. But Serviio is running and i can see the consol.... Ill try to check it again tomorrow.. Thanks Frank
tech.mikhail
Post Fri Mar 13, 2015 9:01 pm
Hello. Where do I need to put the plug-ins in ver 1.5.1?
Post Fri Mar 13, 2015 9:56 pm
It's under Serviio installation ditrectory (not the console): http://serviio.org/component/content/article?id=21#q18
tech.mikhail
Post Sat Mar 14, 2015 8:46 am
zip wrote:It's under Serviio installation ditrectory (not the console): http://serviio.org/component/content/article?id=21#q18
Thnx it was: /Library/Application Support/Serviio/Plugins
Return to Video streams
