URL Errors - 404 Unknown & 500 Timeout
Post Sat Mar 03, 2012 5:21 pm
I'm a newbie with groovy and java.
When getting a URL
            String videohtml = new URL(videoUrl).getText()
I can first test to ensure it exists and avoid 404 errors using this code
   Boolean URLExists(URL fileURL){
      if(((HttpURLConnection) fileURL.openConnection()).getResponseCode() == 404){
         return false
      return true
But how do I avoid or catch 500 errors like this
Caught: java.net.ConnectException: Connection timed out: connect
        at HaHaSport.extractItems(HaHaSport.groovytest.txt:190)
        at HaHaSport$extractItems.call(Unknown Source)
        at HaHaSport.main(HaHaSport.groovytest.txt:1320)
I'd like to catch them and retry rather than get an exception.
Post Sat Mar 03, 2012 9:15 pm
Re: URL Errors - 404 Unknown & 500 Timeout
you can just wrap the code in try - catch block (http://groovy.codehaus.org/JN3035-Exceptions) and catch the timeout exception.
Not sure if re-try os the way to go though, depends if there is a chance it'll work the second time around, otherwise it'll take ages to add the items
Return to Plugin development
