Re: YouTube
stefana888 wrote:All official music videos are protected and doesn't show up....
in my case, even homemade videos (for example) don't show up...
Playlist
Use this URL as the resource URL:
https://www.googleapis.com/youtube/v3/p ... LAYLIST_ID
jhb50 wrote:The wiki is no longer correct since youtube has obsoleted V2 of its api.
Use the URL formats posted in the first post of this youtube plugin thread:Playlist
Supernova wrote:Two more questions:
1- How can I have the videos play in 4k? (of course the ones which are recorded in 4K). I have set the "preferred online content quality" to High in the GUI. But the max resolution I get is 1280x720
2- How to have all the videos in a playlist loaded and available ? For various playlist, it only loads different (random) number of videos but not all. I have set the "max. number of feed items to retrieve" to unlimited but to no avail.
stefana888 wrote:Supernova wrote:Two more questions:
This is not supported. 1. You can try add format codes to the plugin. 2. API page tokens can be used to retrieve more than 50 items.
2015-08-23 07:56:58,371 WARN [FeedUpdaterWorker] An error occured while parsing the online resource https://www.googleapis.com/youtube/v3/channels?id=UCmk5QB4JE-RT3ig4kvtVYxg, will try again soon: Unexpected error while invoking plugin (YouTube): The JSON input text should neither be null nor empty.
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (YouTube): The JSON input text should neither be null nor empty.
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:191)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
Caused by: java.lang.IllegalArgumentException: The JSON input text should neither be null nor empty.
at groovy.json.JsonSlurper.parseText(JsonSlurper.java:56)
at groovy.json.JsonSlurper$parseText.call(Unknown Source)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at YouTube.extractItems(Youtube.groovy:44)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
2015-08-23 07:45:01,697 WARN [FeedUpdaterWorker] An error occured while parsing the online resource https://www.googleapis.com/youtube/v3/videos?chart=mostPopular, will try again soon: Unexpected error while invoking plugin (YouTube): The JSON input text should neither be null nor empty.
at YouTube.extractItems(Youtube.groovy:52)
"kind": "youtube#channelListResponse",
"etag": "\"sGDdEsjSJ_SnACpEvVQ6MtTzkrI/Pj9gioMX35M57a5fJspKzUDnWlE\"",
"pageInfo": {
"totalResults": 1,
"resultsPerPage": 1
"items": [
"kind": "youtube#channel",
"etag": "\"sGDdEsjSJ_SnACpEvVQ6MtTzkrI/YtL95MY8HzCSDU1OdZtJiMn80a4\"",
"id": "UCmk5QB4JE-RT3ig4kvtVYxg",
"contentDetails": {
"relatedPlaylists": {
"likes": "LLmk5QB4JE-RT3ig4kvtVYxg",
"uploads": "UUmk5QB4JE-RT3ig4kvtVYxg"
"googlePlusUserId": "105728480187241807921"
