ServiiDroid (Android Console) - Get it on Google Play
Post Fri Nov 07, 2014 7:43 pm
Re: ServiiDroid (Android Console) - Get it on Google Play
I've now finished the conversion from ActionbarSherlock to AppCompat and have uploaded 3.0 Beta 2. There is potential for a number of graphical issues on older devices, so please do try it out.
==== 3.0 Beta 2 ====
*Requires Android 2.3.3+
*Replaced ActionBarSherlock with AppCompat
*Updated themes to better match official material design guidelines
Also let me know if you have any ideas of what I could do to make the status view a little more interesting...
Post Sun Nov 09, 2014 8:24 am
Small update to the production channel.
==== 2.2.2 ====
*Fixed crash when connecting to Serviio 1.5 Beta 1/2
Post Sat Nov 15, 2014 10:00 am
I'm please to announce that ServiiDroid 3.0 is now out. I've still got some changes that I want to make, but I want to get feedback from more users first, so they will come in 3.1.
==== 3.0 ====
*New Material design
*Improved first run and add server workflow
*Improved license upload workflow
*Added support for Serviio 1.5 Beta
*Moved the 'Advanced' tab to the left for easier access
*Added an action to delete all unrecognised devices
*Simplified app preferences
*Added Google Analytics to help track app usage (e.g Server versions, common actions, Android version)
*Re-wrote Serviio API client to use OkHttp
*Replaced cling with android-dlna for server discovery
*Lots of bug fixes and improvements
Post Sat Nov 15, 2014 1:32 pm
Small update, not sure how I missed that one...
==== 3.0.1 ====
*Fixed crash on 10" tablets when viewing Presentation options
spudy12
Post Sun Nov 16, 2014 4:54 pm
Love the new UI. Great work :)
Post Sun Dec 14, 2014 9:19 am
New beta time. I will just do a quick check and then release it to everyone else next weekend. After this I'm going to go back to focusing on ServiiGo for a while.
==== 3.1 Beta 1 ====
*Add full support for Serviio 1.5
*Various design tweaks
*Removed support for ServiiDB.com as the site has been shutdown
*Improved protection against invalid server addresses
*Added an 'Advertise service' action
*Update build tools and libraries
himbrr
Post Sun Dec 14, 2014 12:37 pm
The "Advertise Service" action is working fine! Thank you for implementing it!
Post Sun Dec 21, 2014 9:58 am
I've just uploaded 3.1 to Google Play, this is basically the same as the last beta + updated translations and some very minor fixes.
As a reminder, translations are done by the community via http://www.getlocalization.com/serviidroid/, so if you wish to help please sign up and get translating.
==== 3.1 ====
Post Sat Feb 28, 2015 4:25 pm
I've just uploaded a small update to Google Play.
==== 3.1.1 ====
*Add full support for Serviio 1.5.1
*Updated translations
Post Sat Aug 08, 2015 1:56 pm
It's been a while, but time for a new update. Feature wise it's a minor update, the version jump is because it now required Android 4.0.3+
=== 3.2 ===
*Requires Android 4.0.3+
*Removed support for re-ordering online sources on Serviio 0.6.x/1.0.x
*Add full support for Serviio 1.5.2
*Updated SDK, build tools and libraries
Google have recently changed the beta program options, so I've changed ServiiDroid's to use the open program where all you have to do is go to https://play.google.com/apps/testing/com.serviidroid to opt-in, no need to join the group first.
Oh and I didn't get a chance to annouce it because I was on holiday, but ServiiDroid has now been downloaded over 100,000 times!
Xmantium
Post Sun Aug 09, 2015 11:53 pm
will wrote:Oh and I didn't get a chance to annouce it because I was on holiday, but ServiiDroid has now been downloaded over 100,000 times!
Thanks for keeping this great app alive and kicking!
Post Wed Aug 12, 2015 5:18 pm
Nice one, Will.
Post Sat Nov 21, 2015 11:18 am
New beta time (see first post for signup link if you aren't already a beta tester), will make it available for everyone in a week or so assuming nothing major comes up
=== 3.3 Beta 1 ===
*Initial support for Serviio 1.6 Beta 2
*Various minor bug fixes
Jorgensen
Post Sat Nov 21, 2015 7:54 pm
Even if this question might be very simple, I was not able to find a proper answer spending hours.
What is the syntax to be adhered to while placing "local" or "path" determinations for the library to the app? I tried a couple of options, not successfull yet. Serviio is sitting on a NAS in my LAN/wireless. Usually I would go with:
\\JCHK_NAS_DS212P\video
being translated by the app to something like /usr/syno/...\\JCHK_NAS_DS212P\video. And no, no files added to the library from there.
I also tried /JCHK_NAS_DS212P/video. Nope.
Thanks for your help!
Post Sat Nov 21, 2015 8:39 pm
you need to enter the local path on the NAS, ie the way the server process sees it. Not the network name.
Post Sat Nov 21, 2015 8:47 pm
Jorgensen wrote:Even if this question might be very simple, I was not able to find a proper answer spending hours.
If Serviio is running on your NAS, then you will want the path to your media from the view of your NAS, something like /volume1/video from what I can find on Google. Does that help?
Jorgensen
Post Sun Nov 22, 2015 11:59 am
Thanks folks,
your proposed solution ( /volume1/video ) works perfectly.
Post Sat Dec 12, 2015 8:53 am
New beta.
=== 3.3 Beta 2 ===
* New add folder with Serviio 1.6
* Various minor bug fixes
skiaccianos
Post Fri Dec 18, 2015 9:21 pm
Hi Will, first testing attempt goes right.
=== 3.3 (with latest serviio beta, ndA)===
*Full support for Serviio 1.6 ----OK
**Browse for a folder to add to the library -----OK: works on my Linux server, usefull feature/improvements, makes things more easy.
**Enhanced status view ----OK: added library files counter, as I can see
**Subtitle settings changes ---language sub set trough ServiiDroid has always been not working here: now I can set lang. trough SD, but if I set it trough serviio console SD show an empty field; other times SD and the console completely ignore each other settings. I don't know, Will....
**New stacking settings ----OK: enabling and disabling works, but I have no files to try this....
That's all, I guess. Regards
Running Serviio - for several years now - on Debian and Win boxes.
R850R biker, sysadmin & DBA, FOSS and Linux enthusiast (desktop_is_home_dir)
Post Sat Dec 19, 2015 8:07 am
skiaccianos wrote:**Subtitle settings changes ---language sub set trough ServiiDroid has always been not working here: now I can set lang. trough SD, but if I set it trough serviio console SD show an empty field; other times SD and the console completely ignore each other settings. I don't know, Will....
Yeah I found that first issue in testing. I don't use subtitles so never noticed. Will investigate the second issue when I get a chance.
