Tune In radio
As the first post says, search was added in Feb/14, and looking at the post for that time viewtopic.php?f=20&t=5096&start=60#p87638 you can see the details, and the subsequent post where the author incorporated the change.
Re: Tune In radio
Well yes, I guess I read those posts wrong. I thought the change fixed the /search thing. In fact neither
nor
currently work. Actually, as far as I can see, nothing with a ?query= stands a chance of working.
nor
Re: Tune In radio
Ok folks. After playing with TuneIn Radio long enough now, it's clear that the only URLs that work are those obtained by drilling down their [Location] menu. The only URLs that work are those with the format.
Note the nnnnnn number MUST be preceded by the character "r" (lowercase R). I don't know why.
Re: Tune In radio
Maca wrote:zip, I have been using this plugin quite a lot on my Sony Bravia (2011) and it seems a bit hit and miss whether the stream will start, often I have to return and press play again until it starts.
Grabbed the log output...
This was using 1.3 beta 3 and the recent RC1
Works ok, but would be great if it worked first go.
Just wondering if anyone had any help for this symptom posted my Maca? Same symptom on by KDL-48W600B (2014).
Re: Tune In radio
jhb50 wrote:Try this V8 Beta, and post the URLs that do not work.
WOW. Don't know how you did it, but the following
ALL WORK. And the style still works also.
Thanks!
Mostly all stations require at least one false start however. All stations will either not start, or play 0.5 seconds and stop, or occasionally crash the Sony Media Player. After several attempts, they stream forever. Verry acceptable though.
Re: Tune In radio
Thanks! It's work
Re: Tune In radio
Thanks much. All looks good to me. I've tried several URLs, with and without "/search" etc.. The plugin seems to work just as before, multiple false starts and all. No more "No items..." though.
Now maybe I can compare the two .groovy files and maybe learn something1
Sorry for the slight delay. I never got the notification of the reply.
Re: Tune In radio
Today is April 5, 2016 and all Tunein URLs return "No items to display" Example: http://tunein.com/search/?query=doowop They all work fine in the browser.
Re: Tune In radio
Thanks. I'll try it as soon as i get 1.5.2 re-installed. 1.6.1 isn't a valid w32 application.
Any idea who's bell i can ring to see what's going on with CBS?
Re: Tune In radio
I reinstalled 1.5.2 and TuneIn seems to be working like a Charm.
Thank you.
Thank you.
Re: Tune In radio
fidmas wrote:Thanks. I'll try it as soon as i get 1.5.2 re-installed. 1.6.1 isn't a valid w32 application
Re: Tune In radio
Yeah, except i just found out the console isn't 32bit compatible. I'll play more tomorrow.
Re: Tune In radio
jhb50 wrote:Here is V10 fixed.
Thanks jhb50 works really well.
Sent from my HTC One M9 using Tapatalk
Re: Tune In radio
I forgot to reply on this thread. TuneIn works great now. Thanks again.
Re: Tune In radio
Found a problem with this Radio Station... http://tunein.com/radio/Capital-London-958-s16534/ Doesn't seem to work. Log entry below...
- Code:
2016-04-24 07:03:41,907 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://tunein.com/radio/Capital-London-958-s16534/, will try again$
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (Tune In): The operation took more than 30000 ms and has been $
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:197)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.RuntimeException: The operation took more than 30000 ms and has been cancelled.
at org.serviio.library.online.PluginExecutionProcessor.execute(PluginExecutionProcessor.java:64)
at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:34)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:76)
... 5 more
Re: Tune In radio
I couldn't get the plugin to see it either, but http://tunein.com/search/?query=capital%20london finds and plays it.
