[SOLVED] My TOSHIBA 48L5445DG and bad subtitle names
momchil
Post Sun Aug 02, 2015 10:53 am
SOLUTION >>>
Hi Serviio Team,
I have problem with subtitles from Serviio. My TOSHIBA 48L5445DG see SRT files but my TV see all SRT files with same name -> SUBTITLE.srt(see screenshot)
I have many movies with subtitles and my TV see all SRT files with same name -> SUBTITLE.srt
The names of the subtitles is same with names of the movie files in my hard drive.
The firmware of the TV is updated and TV is factory reset.
Serviio 1.5.2
In Profile "TOSHIBA REGZA 2012-" I put thеsе lines:
         <Video targetContainer="mpegts" targetACodec="aac" forceInheritance="true">
            <Matches container="mp4" />
            <Matches container="avi" />
            <Matches container="flv" />
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
      </Subtitles>
Burning subtitles is solution but I wish controlled subs directly from my TV(I wish big size and low CPU usage of the server).
P.S.: Sorry for my english.
momchil
Post Sun Aug 02, 2015 4:49 pm
Re: My TOSHIBA 48L5445DG and bad subtitle names
This is maybe Serviio bug.
In attached log I find there lines:
2015-08-02 18:41:08,161 DEBUG [ServiioHttpService] Incoming request from /192.168.1.110:46626: GET /resource/4500/SUBTITLE.srt HTTP/1.1, headers = [Range: bytes=173535-,Host: 192.168.1.120:8895,Accept: */*]]
2015-08-02 18:41:08,161 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.110
2015-08-02 18:41:08,162 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.110
2015-08-02 18:41:08,163 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.110, Profile=Toshiba REGZA 2012-'
2015-08-02 18:41:08,163 DEBUG [ResourceDeliveryProcessor] Request for resource 4500 and type 'SUBTITLE' received
2015-08-02 18:41:08,163 DEBUG [VideoDAOImpl] Reading a Video (id = 4500)
2015-08-02 18:41:08,163 DEBUG [MediaItemDAOImpl] Getting file of media item 4500
2015-08-02 18:41:08,165 DEBUG [SubtitlesService] Found external subtitle file: T:\Download-TS\Gemma.Bovery.2014.1080p.BluRay.x264-CiNEFiLE.srt
2015-08-02 18:41:08,165 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 4500
2015-08-02 18:41:08,165 DEBUG [DLNAProtocolHandler] Unsupported range request, sending back 416
Please, investigate this bug. Thank you!
serviio_logs.zip
(103.54 KiB) Downloaded 988 times
Post Wed Aug 05, 2015 6:43 pm
That's how subtitles are sent to the TV. The TV should not show them for browsing really.
momchil
Post Thu Aug 06, 2015 11:00 pm
I changed something of the profil for TOSHIBA REGZA 2012-
Added lines:
For PAUSE/FWD/RWD problem:
<ProtocolInfo>simple</ProtocolInfo>
For DTS/DTS-HD problem and MKV+AC3 problem:
   <Video targetContainer="mpegts" targetACodec="aac">
      <Matches container="*" aCodec="dts-hd" />
      <Matches container="*" aCodec="ac3" />
   </Video
For subtitle:
<Subtitles>
</Subtitles>
But my TV still find same subtitles > SUBTITLE.srt and I can't watch my movies with subtitles. :( Hardsubs is not a solution because I have problems with 3D movies.
Any chance for subtitles with their real names?
If I can change something for the subtitles please, write me!
momchil
Post Wed Aug 12, 2015 4:40 pm
I changed source code and now I have different subtitle names.
org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor
private static final Pattern URL_EXTENSION_REMOVAL_PATTERN = Pattern.compile("(\\.srt|\\.m3u8)");
To:
private static final Pattern URL_EXTENSION_REMOVAL_PATTERN = Pattern.compile("(-[0-9]{1,6}\\.srt|\\.m3u8)");
org.serviio.delivery.DefaultResourceURLGenerator
if (Resource.ResourceType.SUBTITLE == resourceType) {
   file.append(".srt");
To:
   file.append("-").append(resourceId.toString());
zip, I need help from you for real subtitle name.
momchil
Post Thu Aug 13, 2015 2:09 am
The problem is fixed. :)
    public RequestedResourceDescriptor(String requestUri) throws InvalidResourceRequestException {
        try {
            String[] requestFields = AbstractRequestHandler.getRequestPathFields(requestUri, "/resource", URL_EXTENSION_REMOVAL_PATTERN);
To:
        try {
           if(requestUri.indexOf(".srt") > -1) { [color=#40FF00]//if you have ".srt" in the URL[/color]
              String[] tempUri = requestUri.split("/"); [color=#40FF00]//split with "/"[/color]
              requestUri = "/" + tempUri[1] + "/" + tempUri[2] + "/SUBTITLE.srt"; [color=#40FF00]//change URL to this path + /SUBTITLE.srt[/color]
And in org.serviio.delivery.DefaultResourceURLGenerator
public class DefaultResourceURLGenerator
implements ResourceURLGenerator {
    public static final String RESOURCE_SEPARATOR = "-";
    @Override
    public String getGeneratedURL(HostInfo hostInfo, Resource.ResourceType resourceType, Long resourceId, MediaFormatProfile version, Integer protocolInfoIndex, DeliveryQuality.QualityType quality) throws InvalidResourceException {
        this.validate(resourceType, resourceId, version, protocolInfoIndex, quality);
        StringBuffer file = new StringBuffer();
        file.append(resourceId.toString());
        file.append("/").append(resourceType.toString());
        if (resourceType == Resource.ResourceType.MEDIA_ITEM || resourceType == Resource.ResourceType.MANIFEST) {
            file.append("/").append(version.toString());
            file.append("-").append(protocolInfoIndex);
            file.append("/").append(quality.toString());
To:
import org.serviio.db.dao.DAOFactory; [color=#40FF00]//attached DAOFactory class[/color]
import java.util.regex.Pattern; [color=#40FF00]//attached Regex Pattern class[/color]
    @Override
        file.append("/"); [color=#40FF00]//resourceType is removed[/color]
        if (Resource.ResourceType.SUBTITLE != resourceType) { [color=#40FF00]//if not a subtitle[/color]
           file.append(resourceType.toString()); [color=#40FF00]//attached resourceType[/color]
           String subsName = DAOFactory.getMediaItemDAO().getFile(resourceId).getName(); [color=#40FF00]//get video file name[/color]
           subsName = Pattern.compile("(\\.[A-Za-z0-9]{3}$)").matcher((CharSequence)subsName).replaceAll(""); [color=#40FF00]//this remove video file extention[/color]
           subsName = Pattern.compile("( )").matcher((CharSequence)subsName).replaceAll(".");[color=#40FF00] //replace intervals(spaces) with dots[/color]
            file.append(subsName).append(".srt"); [color=#40FF00]//append .srt extention to subs file[/color]
Work great! :D
momchil
Post Fri Sep 04, 2015 10:29 pm
Re: [SOLVED] My TOSHIBA 48L5445DG and bad subtitle names
This is my solution of the problem with subtitles for Toshiba TV's.
Tested on 48L5445DG(model 2014).
You need replace spaces(intervals) in file names with dots or whatever. If you have spaces(intervals) in the name of the subtitles will be replaced with dots!
The archive is too large for the forum.
I uploaded it in Google Drive. Modded files for Serviio 1.5.2 : https://drive.google.com/file/d/0B6o39p ... sp=sharing
Sorry for my english!
@zip, if you can, please, add these changes in official release.
momchil
Post Tue Apr 26, 2016 2:26 am
New version for 1.6.1 - Modded files for Serviio 1.6.1.zip
Unzip in Serviio root directory and set the profil to "TOSHIBA REGZA 2012-". Restart the service of Serviio or reboot computer!
Before: Subtitle name is 1234_SUBTITLE.srt or 7590_SUBTITLE.srt or four numbers and _SUBTITLE.srt
After this mod: Subtitle name is Name.of.the.film.srt ;)
@zip, please insert this code in Serviio. This is only 10 lines summary.
momchil
Post Mon Sep 12, 2016 11:32 pm
My new modification for Serviio 1.7: Modded files for Serviio 1.7.zip
In org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor
        try {
/* add START */
/* add END */
In org.serviio.delivery.DefaultResourceURLGenerator
/* add START */
/* add END */
    @Override
        file.append("/");
/* remove one IF((Resource.ResourceType.SUBTITLE == resourceType)) and one line(file.append(resourceType.toString());) after! */
/* add START */
/* add END */
/* add START */
            file.append(subsName);
/* add END */
        } else if (Resource.ResourceType.MANIFEST == resourceType || version != null && version.isManifestFormat()) {
/* add  START *
/* add END */
           file.append(".m3u8");
        return this.generateUrl(hostInfo, this.generatePath(hostInfo, file.toString()));
QuiGon
Post Thu Sep 29, 2016 2:53 am
Guys, has anyone encountered some problems with new version of Serviio. I made this work perfectly on last version but after updating it, it got broken. I saved profile entry and copied it to new profile file, but it's broken somehow. Even with entry i still have problem listing files as text.srt. I again see 5012_SUBTITLE; instead of s01e01.srt.
How can i fix it?
also there has been another problem. now while watching movies, my subs have wierd display at some characters..it should be ć č đ ž š; but it's showing some other symbols. Strange thing is both of my subtitles have è for č, as it should be so program would display it correcty. but on one sub it shows like it should, on other not. Anyone knows what triggers this?
QuiGon
Post Tue Oct 18, 2016 11:07 pm
zip wrote:That's how subtitles are sent to the TV. The TV should not show them for browsing really.
I have to disagree. TV shows them anyway, but wrongly..They're not automatically loaded, even if on computer they're called the same as video file, so that makes this reason useless. And above all if i have 10+ video files with subtitles not loaded automatically and not named properly, i have to throw a bean before i figure what subtitle to load.
Changing this option like in momchil's mod, not only it displays them correctly, it even loads them automaticlly. Why discard this then, when it's only positive stuff it brings.
QuiGon
Post Thu Oct 20, 2016 5:25 pm
hey momchil, if use moded files from 1.7 on 1.7.1 will they work with all updates from 1.7.1? or if i use this file i will also loose updates and use version 1.7 intruth?
momchil
Post Thu Oct 20, 2016 5:27 pm
May be no. Only with 1.7.
What is your TV?
QuiGon
Post Mon Oct 24, 2016 12:26 am
TELEFUNKEN. tell you all other mods were great from you. will you do mod for 1.7.1?
momchil
Post Mon Oct 24, 2016 5:45 pm
My new modification for Serviio 1.7.1.1: Modded files for Serviio 1.7.1.1.zip
Melih
Post Sun Dec 11, 2016 11:06 pm
momchil wrote:My new modification for Serviio 1.7.1.1: Modded files for Serviio 1.7.1.1.zip
Hello Momchil, are you planning to make modifications for the new version? That subtitle file name issue is annoying. I treid to edit them myself but i couldn't unfortunately :(
It would be awsome if you make it for 1.8
momchil
Post Sun Dec 11, 2016 11:09 pm
Melih wrote:I treid to edit them myself but i couldn't unfortunately :(
Maybe the code is changed. I don't know. I will check this the next week.
Melih
Post Sun Dec 11, 2016 11:16 pm
I coundn't because i don't know how to edit it.
Cheers, i will be waiting for the good news ;)
momchil
Post Sun Dec 11, 2016 11:17 pm
After Friday you can remind me here. ;)
momchil
Post Sun Dec 18, 2016 12:19 am
My new modification for Serviio 1.8: Modded files for Serviio 1.8.zip
Return to Toshiba
