[SOLVED] Jerky Pano Bluray playback
freaknik
Post Sat Feb 25, 2017 2:26 am
Hi all,
I use serviio 1.8
Some files are stuttering when I play them on my bluray, very jerky playback.
Here is a log from serviio in attachment from when I play the movie and the mediainfo for the movie that stutters I last tried:
Complete name               : C:\Users\Office\Desktop\The Sunchaser\The Sunchaser.ts
Format                      : MPEG-TS
File size                   : 1.16 GiB
Duration                    : 2h 2mn
Overall bit rate mode       : Variable
Overall bit rate            : 1 359 Kbps
Menu ID                     : 1 (0x1)
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : High@L3.1
Format settings, CABAC      : Yes
Format settings, ReFrames   : 4 frames
Codec ID                    : 27
Duration                    : 2h 2mn
Width                       : 1 280 pixels
Height                      : 544 pixels
Display aspect ratio        : 2.35:1
Frame rate mode             : Variable
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Writing library             : x264 core 146 r2538 121396c
Encoding settings           : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Menu ID                     : 1 (0x1)
Format                      : AAC
Format/Info                 : Advanced Audio Codec
Format version              : Version 4
Format profile              : LC
Muxing mode                 : ADTS
Codec ID                    : 15
Duration                    : 2h 2mn
Bit rate mode               : Variable
Channel(s)                  : 2 channels
Channel positions           : Front: L R
Sampling rate               : 48.0 KHz
Compression mode            : Lossy
Delay relative to video     : -21ms
Menu
Menu ID                     : 1 (0x1)
Duration                    : 2h 2mn
List                        : 256 (0x100) (AVC) / 257 (0x101) (AAC)
Service name                : Service01
Service provider            : FFmpeg
Service type                : digital television
I am using the Panasonic Bluray profile.
Thanks guys, still working great on chromecast but the bluray in is my room, would love to have movies going in there. :mrgreen:
Post Sat Feb 25, 2017 3:24 am
Re: Jerky Pano Bluray playback
That file should play easily, based on what I see there. How is your player connecting to the Serviio computer, wired or wireless?
I examined the Pano BD profile, and I can't tell for sure if it's being transcoded or not. I wouldn't think it would be necessary. Try using the Generic profile and see if it a) plays and b) stutters.
freaknik
Post Sat Feb 25, 2017 11:37 am
It's on a wired connection.
Switching to general fixes it from jerking and fixes the aspect ratio (no more letter box).
Thanks!
freaknik
Post Sat Feb 25, 2017 2:02 pm
In Russia, ad sells you!
Post Sat Feb 25, 2017 4:13 pm
So the Pano BD Player profile is doing something that isn't necessary. Unfortunately, that's extremely difficult for Zip to determine and adjust (he'd have to have every make/model player, and that's unreasonable), so comments like yours should assist him with changes if possible.
freaknik
Post Sat Feb 25, 2017 7:47 pm
OK cool here are some notes:
On this movie The Sunchaser it stutters immediately with Panasonic Blu-ray profile. Under general it played fine except the last 10 minutes were stuttering. It's a two hour movie.
But the aspect ratio fits my TV perfectly with general.
I know it's not possible for one guy to know every device in existence and mine is old so glad to have any support.
I don't know if it's the length of the movie or the strength of my network or some other problem.
Had been bullet proof for TV shows, mostly mp4's, 20-30 minutes long, any file size no stutter.
This is the first time I've tried to watch a full length movie in a while. I'll try more of them to see if the problem persists.
Post Sat Feb 25, 2017 9:38 pm
Well, by the info you posted above, the average bitrate is only around 1.4 Mbps, which is minimal. It's higher resolution than a DVD rip, but an uncompressed DVD file can still see average bitrates more than triple that.
I asked a question earlier that you overlooked. How is the Serviio computer and the Panasonic player connected? Are they both wired, or is one or the other wireless? If you are using wireless somewhere in the chain, you might be experiencing interference, just enough to impact your higher resolution streams.
Lastly, what sort of hardware are you running Serviio on? Serviio doesn't seem to care much about RAM, but CPU speed and core count can certainly impact performance. Which OS?
freaknik
Post Sat Feb 25, 2017 10:00 pm
Both wired, Win 7 32 bit, dual core 2.7 Ghz intel, 4gb ram.
Post Sun Feb 26, 2017 2:31 am
freaknik wrote:Both wired, Win 7 32 bit, dual core 2.7 Ghz intel, 4gb ram.
Good for wired. Your computer is about what my test server was before I updated it. Being 32 bit, Windows doesn't quite see all 4 gig of your ram, and adding more does nothing. You'd have to install Windows 64 bit to use more ram.
That said, for files that don't require transcoding you have plenty pf power. Even transcoding into H.264 (which takes the most power) would be OK if you're only streaming to a single player.
So if the Generic profile is working for you, stick with it. If you discover a small number of videos that won't play, it would probably be easier/faster to convert them into a playable format.
freaknik
Post Sun Feb 26, 2017 6:28 pm
I tried a different movie with a higher bitrate on general profile and it was stuttering bad :(
Here's mediainfo:
Complete name               : E:\mo gnar gnar\Deja Vu.ts
Format                      : MPEG-TS
File size                   : 795 MiB
Duration                    : 39mn 58s
Overall bit rate            : 2 779 Kbps
Menu ID                     : 1 (0x1)
Format                      : AVC
Codec ID                    : 27
Duration                    : 39mn 58s
Height                      : 720 pixels
Display aspect ratio        : 16:9
Color space                 : YUV
Bit depth                   : 8 bits
Writing library             : x264 core 142 r2431 a5831aa
Encoding settings           : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=72 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / stitchable=1 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=90 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=5 / qpmax=69 / qpstep=4 / vbv_maxrate=2750 / vbv_bufsize=7500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Color range                 : Limited
Color primaries             : BT.709
Transfer characteristics    : BT.709
Matrix coefficients         : BT.709
Menu ID                     : 1 (0x1)
Format                      : AAC
Format profile              : LC
Muxing mode                 : ADTS
Codec ID                    : 15
Duration                    : 39mn 58s
Delay relative to video     : -66ms
The Serviio pc has 47 processes and is over 50% cpu usage (not from serviio from other stuff). I am going to wait until the computer has more resources free.
I think that is the problem, not having enough cpu when the pc is multitasking.
Here is mediainfo for a show that does stream without interruption or stutter:
Complete name               : E:\cartoons\Simpsons\S08x21.mp4
Format                      : MPEG-4
Codec ID                    : M4V
File size                   : 74.4 MiB
Duration                    : 20mn 33s
Overall bit rate mode       : Constant
Overall bit rate            : 506 Kbps
Encoded date                : UTC 1969-12-31 16:00:00
Tagged date                 : UTC 1969-12-31 16:00:00
Writing application         : 3GP_Converter051103 www.nurs.or.jp/~calcium FFmpeg2.40b((51<<16)+(6<<8)+0)
Comment                     : QuickTime 6.0 or greater
Format                      : MPEG-4 Visual
Format profile              : Simple@L3
Format settings, BVOP       : No
Format settings, QPel       : No
Format settings, GMC        : No warppoints
Format settings, Matrix     : Default (H.263)
Codec ID                    : 20
Duration                    : 20mn 33s
Bit rate mode               : Constant
Bit rate                    : 450 Kbps
Width                       : 320 pixels
Height                      : 240 pixels
Display aspect ratio        : 4:3
Frame rate mode             : Constant
Frame rate                  : 30.000 fps
Color space                 : YUV
Bit depth                   : 8 bits
Bits/(Pixel*Frame)          : 0.195
Stream size                 : 64.5 MiB (87%)
Language                    : English
Format                      : AAC
Format profile              : LC
Codec ID                    : 40
Duration                    : 20mn 33s
Bit rate                    : 64.0 Kbps
Nominal bit rate            : 128 Kbps
Sampling rate               : 24.0 KHz
Stream size                 : 9.41 MiB (13%)
Language                    : English
So it seems the higher the bitrate the more my panasonic has a hard time.
Post Sun Feb 26, 2017 7:46 pm
I'm beginning to suspect the Pano player just can't handle higher bitrate video over DLNA. I know that Panasonic seems to have discontinued offering DLNA support in their later players, or at least downplays it so much it's tough to determine what they do support. Looking at their current web site it seems only the expensive 4K Blu Ray player supports DLNA.
Or there's just something wrong with the Pano. I can't see any reason for those files not to play. Only other thing I can think of is running Serviio with the Debug logging turned on and see if there are any answers there.
freaknik
Post Fri Mar 10, 2017 7:37 am
You're right it won't play this without jerky time the whole way because it's 3.2 mbps bit rate:
Complete name               : E:\aint you seen my movies\24 Hour War.ts
Format                      : MPEG-TS
File size                   : 2.26 GiB
Duration                    : 1h 39mn
Overall bit rate            : 3 247 Kbps
Menu ID                     : 1 (0x1)
Format                      : AVC
Format profile              : High@L4
Codec ID                    : 27
Duration                    : 1h 39mn
Width                       : 1 920 pixels
Height                      : 1 080 pixels
Color space                 : YUV
Bit depth                   : 8 bits
Menu ID                     : 1 (0x1)
Format                      : AAC
Format profile              : LC
Muxing mode                 : ADTS
Codec ID                    : 15
Duration                    : 1h 39mn
Delay relative to video     : -81ms
Menu
Menu ID                     : 1 (0x1)
Duration                    : 1h 39mn
Low res plays fine. Thanks for figuring it out. Kind of a bummer though I don't think there is any solution other than purchasing a more compatible device.
Post Fri Mar 10, 2017 2:29 pm
3.2 Mbps is nothing. I have DVD rips that exceed that easily. There's no excuse for your Pano not playing that smoothly. I don't think I ever asked what model of Panasonic you have. But my 6 year old Panasonic ST30 TV doesn't have any problem with files like this. Although I rarely use the Pano DLNA player anymore. I have a Roku 4 connected to that set and use it instead. BTW, a Roku player should play that file without transcoding, and I've seen my Roku players handle files with average bitrates over 30 Mbps without stutter or buffering.
freaknik
Post Sun Mar 12, 2017 6:29 pm
I watched the same flic on chromecast and generic profile and it transcoded to ~450 kbps ts files that played beautifully without interruption.
With the pano profile selected, playing on the pano bluray, it transcodes an 8.2 gb 11.3 mbps stf file that is hurky jerky, even if played locally on vlc on serviio host pc.
The player is BDT230 and I got it three years ago and I think it was used or refurbished or something like that when I got it, 2013 model.
Time to get roku then I suppose.
I even did factory reset to stock firmware and no dice, same weird playback.
While on dlna of over 1 mbps bitare you can see the counter of the movie runtime double back:
00:01....00:02.....00:003....00:04......00:05......00:06.........00:03.......00:04.......00:05.........00:06........00:04...........00:05...........00:06...........00:07
There is a lot of things like that with dlna that technically work just not as well as advertised. I guess the pano bluray is one such device. Oh well I could pawn it or something once I get the roku.
freaknik
Post Wed Mar 15, 2017 3:02 am
The log shows that in 12 seconds it says streaming then I/O error 14 times, as if it feverishly is attempting to stream and failing over and over.
2017-03-14 22:23:30,261 DEBUG [VideoDeliveryEngine] Delivering item '22496' for client 'Identifier=192.168.0.11, Profile=Generic DLNA profile, Name=NFLC SDK v1.5'
2017-03-14 22:23:30,264 DEBUG [VideoDeliveryEngine] Delivering file 'The 24 Hour War.ts' in native format
2017-03-14 22:23:30,265 DEBUG [MediaItemDAOImpl] Getting file of media item 22496
2017-03-14 22:23:30,266 DEBUG [GETMethodProcessor] Stream entity has length: 2413632736
2017-03-14 22:23:30,267 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 2413632736,Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Content-Range: bytes 0-2413632735/2413632736,Date: Wed, 15 Mar 2017 02:23:30 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.8,transferMode.dlna.org: Streaming]]
2017-03-14 22:23:30,319 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2017-03-14 22:23:30,366 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2017-03-14 22:23:32,022 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2017-03-14 22:23:32,023 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2017-03-14 22:23:32,023 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2017-03-14 22:23:33,301 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2017-03-14 22:23:33,315 DEBUG [ServiioHttpService] Incoming request from /192.168.0.11:40964: GET /resource/22496/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.0.2:8895,transferMode.dlna.org: Streaming,RANGE: bytes=0-2413632735]]
2017-03-14 22:23:33,315 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2017-03-14 22:23:33,317 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2017-03-14 22:23:33,337 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2017-03-14 22:23:33,338 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.11, Profile=Generic DLNA profile, Name=NFLC SDK v1.5'
2017-03-14 22:23:33,338 DEBUG [ResourceDeliveryProcessor] Request for resource 22496 and type 'MEDIA_ITEM' received
2017-03-14 22:23:33,338 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 22496 (local)
2017-03-14 22:23:33,338 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 22496)
2017-03-14 22:23:33,339 DEBUG [VideoDAOImpl] Reading a Video (id = 22496)
2017-03-14 22:23:33,341 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 22496, format AVC_TS_MP_HD_AAC_MULT5_ISO and profile Generic DLNA profile
2017-03-14 22:23:33,344 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 22496 (local)
2017-03-14 22:23:33,344 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 22496)
2017-03-14 22:23:33,345 DEBUG [VideoDAOImpl] Reading a Video (id = 22496)
2017-03-14 22:23:33,347 DEBUG [VideoDeliveryEngine] Delivering item '22496' for client 'Identifier=192.168.0.11, Profile=Generic DLNA profile, Name=NFLC SDK v1.5'
2017-03-14 22:23:33,350 DEBUG [VideoDeliveryEngine] Delivering file 'The 24 Hour War.ts' in native format
2017-03-14 22:23:33,350 DEBUG [MediaItemDAOImpl] Getting file of media item 22496
2017-03-14 22:23:33,352 DEBUG [GETMethodProcessor] Stream entity has length: 2413632736
2017-03-14 22:23:33,352 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 2413632736,Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Content-Range: bytes 0-2413632735/2413632736,Date: Wed, 15 Mar 2017 02:23:33 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.8,transferMode.dlna.org: Streaming]]
2017-03-14 22:23:36,150 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2017-03-14 22:23:36,151 DEBUG [ServiioHttpService] Incoming request from /192.168.0.11:40965: GET /resource/22496/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.0.2:8895,transferMode.dlna.org: Streaming,RANGE: bytes=0-2413632735]]
2017-03-14 22:23:36,151 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2017-03-14 22:23:36,152 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2017-03-14 22:23:36,153 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2017-03-14 22:23:36,154 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.11, Profile=Generic DLNA profile, Name=NFLC SDK v1.5'
2017-03-14 22:23:36,154 DEBUG [ResourceDeliveryProcessor] Request for resource 22496 and type 'MEDIA_ITEM' received
2017-03-14 22:23:36,154 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 22496 (local)
2017-03-14 22:23:36,154 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 22496)
2017-03-14 22:23:36,156 DEBUG [VideoDAOImpl] Reading a Video (id = 22496)
2017-03-14 22:23:36,157 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 22496, format AVC_TS_MP_HD_AAC_MULT5_ISO and profile Generic DLNA profile
2017-03-14 22:23:36,160 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 22496 (local)
2017-03-14 22:23:36,160 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 22496)
2017-03-14 22:23:36,161 DEBUG [VideoDAOImpl] Reading a Video (id = 22496)
2017-03-14 22:23:36,163 DEBUG [VideoDeliveryEngine] Delivering item '22496' for client 'Identifier=192.168.0.11, Profile=Generic DLNA profile, Name=NFLC SDK v1.5'
2017-03-14 22:23:36,175 DEBUG [VideoDeliveryEngine] Delivering file 'The 24 Hour War.ts' in native format
2017-03-14 22:23:36,175 DEBUG [MediaItemDAOImpl] Getting file of media item 22496
2017-03-14 22:23:36,176 DEBUG [GETMethodProcessor] Stream entity has length: 2413632736
2017-03-14 22:23:36,176 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 2413632736,Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Content-Range: bytes 0-2413632735/2413632736,Date: Wed, 15 Mar 2017 02:23:36 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.8,transferMode.dlna.org: Streaming]]
2017-03-14 22:23:42,381 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2017-03-14 22:23:42,385 DEBUG [ServiioHttpService] Incoming request from /192.168.0.11:40966: GET /resource/22496/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.0.2:8895,transferMode.dlna.org: Streaming,RANGE: bytes=0-2413632735]]
2017-03-14 22:23:42,385 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2017-03-14 22:23:42,386 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
2017-03-14 22:23:42,387 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.11
Does this support your theory that the pano can't handle bitrate or is this evident of some kind of networking bottleneck at the host pc?
Not really sure what socket write error is but thats the only error in the log and it appears whenever I try to watch bitrate over 1000 kbps on panasonic dmp-bdt230.
freaknik
Post Wed Mar 15, 2017 3:52 am
WOOHOO! Solved!
I figured it out finally it was a network problem.
If you have jerky playback and are getting the connection reset by peer socket write error, this is how I fixed it:
Backup, uninstall, and delete the windows driver for your gigabit ethernet on your server. Reinstall and reboot, then enjoy high def streaming like a boss!
Thanks for trying to help me bro, so happy to be streaming clean finally! :mrgreen:
Post Wed Mar 15, 2017 12:32 pm
I have to say I never considered a driver issue on the server. Have to keep that in my toolbox. Thanks for reporting your solution. :D
