Serviio Service not automatically started
Jean-Max
Post Mon May 29, 2017 10:19 am
Serviio Pro 1.8 licensed
Windows 10 64 Creator update V 1703 Build 15063.250
Problem:
Once installed, Serviio pro 1.8 service doesn't automatically start when W10 launches
I am obliged to launch manually the service with link < "C:\Program Files\Serviio\bin\ServiioService.exe" -start >
No success by copying this link :
- In "C:\Users\My_Name\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup"
or
- in [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
-> Can you tell me the exact syntax to automatically launch the Serviio Service when Windows starts ?
Thanks for your help :-)
Best regards from France
PS : sme problem on Windows 7 32bit Home premium V 6.1 Build 7601 SP1
Jean-Max
Sherwood A+P-965 | Inwall JM-LAB | TV Samsung UE48HU7500 | Proj Sony sxrd W40 | Media Player Zbox AD10 | Dvb-T Panasonic DMR-BWT700 | Dvb-T HDHomerun Connect 2 | Nas Thecus N7700Pro | PC Windows 10 + Serviio Pro 1.9.1
Post Mon May 29, 2017 9:46 pm
Re: Serviio Service not automatically started
Delete everything you tried :-). Serviio runs as a service so you need to check how it is set there:
  • run services.msc
  • scroll down to the Serviio service. If it doesn't exist re-install Serviio
  • open it, and set it to run automatically.
Restart your PC and test. If it's still not working, try reinstalling (you can do so over-the-top of the current install). If still not, enable detailed logging, restart and test and then post the log file here.
Jean-Max
Post Tue May 30, 2017 5:49 pm
Thanks for your reply :)
Results of tests:
Services.msc -> Serviio service is : automatic but not started
Serviio Console -> Msg: "Cannot connect the server . It doesn't seem to be running"
Service starts and Serviio console Ok only when I do these 2 things:
Launch "Serviio.bat " (Java start) founded in /Serviio/Bin/
then,
Launch link with syntax "C:\Program Files\Serviio\bin\ServiioService.exe" -start
I reinstalled Serviio 1.8 pro 3 times
-> Same result : Serviio service is automatic but not started
In /Serviio/Log/ subdirectory , the last log file shows at its beginning:
2017-05-26 11:49:02,055 INFO [MediaServer] ------------------------------------------------------------------------
2017-05-26 11:49:02,056 INFO [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2017-05-26 11:49:02,056 INFO [MediaServer] Petr Nejedly 2009-2015
2017-05-26 11:49:02,056 INFO [MediaServer] http://www.serviio.org
2017-05-26 11:49:02,056 INFO [MediaServer] Java 1.8.0_91-Oracle Corporation x86
2017-05-26 11:49:02,056 INFO [MediaServer] OS Windows 10 10.0
2017-05-26 11:49:02,057 INFO [MediaServer] File encoding: windows-1252
2017-05-26 11:49:02,115 INFO [MediaServer] Headless mode enabled: true
2017-05-26 11:49:02,115 INFO [MediaServer] User: PC2-W10-64$
2017-05-26 11:49:02,115 INFO [MediaServer] User home dir: C:\WINDOWS\system32\config\systemprofile
2017-05-26 11:49:02,115 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2017-05-26 11:49:02,115 INFO [MediaServer] ------------------------------------------------------------------------
2017-05-26 11:49:02,162 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-05-26 11:49:02,183 INFO [DatabaseManager] Using DERBY database language
2017-05-26 11:49:03,778 INFO [DBSchemaUpdateExecutor] Updating DB schema
2017-05-26 11:49:08,452 INFO [DBSchemaUpdateExecutor] Dropping search index
2017-05-26 11:49:08,457 INFO [SearchManager] Starting up search engine
2017-05-26 11:49:08,743 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2017-05-26 11:49:08,932 INFO [WebServer] Socket buffer set to 65535 bytes
2017-05-26 11:49:08,933 INFO [Device] Created UPnP Device with UUID: 532c9f22-5c69-3539-8c33-ab7556091aba, bound address: 192.168.1.12
2017-05-26 11:49:09,178 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2017-05-26 11:49:09,200 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2017-05-26 11:49:09,343 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2017-05-26 11:49:09,347 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2017-05-26 11:49:09,347 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2017-05-26 11:49:09,348 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2017-05-26 11:49:09,427 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: java.io.IOException: Unable to establish loopback connection
java.lang.RuntimeException: java.io.IOException: Unable to establish loopback connection:
-> Any idea ?
Thanks for all
Jean-Max
Post Tue May 30, 2017 7:39 pm
Go back into the Services app and change it from Automatic to Delayed Start. It sounds like Serviio is trying to start before the necessary networking pieces have been started.
Jean-Max
Post Wed May 31, 2017 6:10 pm
Thank s :D
That's it !
With <Automatic Delayed Start> , the Serviio service starts OK when W10 boots !
Many thanks for all :D
Jean-Max
Post Wed May 31, 2017 11:39 pm
Strange that it was necessary, but glad it solved it. :D
Jean-Max
Post Thu Jun 01, 2017 2:12 pm
Hi Dan,
YES: it's curious .. but they talk about some reasons to prefer "delayed automatic start" in this thread :
<serviio startup with windows>
viewtopic.php?p=40166
Jean-Max
Return to User experiences
