WARN [UserDataUpdater] There was an error updating user data
norm
Post Tue Sep 19, 2017 6:33 pm
Hi All
Should I be worried about the following in the serviio.log:
2017-09-19 18:22:34,282 INFO  [UserDataUpdater] Updating user data
2017-09-19 18:22:54,882 WARN  [UserDataUpdater] There was an error updating user data
java.net.SocketTimeoutException: connect timed out
        at java.net.PlainSocketImpl.socketConnect(Native Method)
        at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
        at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
        at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
        at java.net.SocksSocketImpl.connect(Unknown Source)
        at java.net.Socket.connect(Unknown Source)
        at sun.net.NetworkClient.doConnect(Unknown Source)
        at sun.net.www.http.HttpClient.openServer(Unknown Source)
        at sun.net.www.http.HttpClient.<init>(Unknown Source)
        at sun.net.www.http.HttpClient.New(Unknown Source)
        at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
        at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(Unknown Source)
        at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
        at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
        at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
        at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
        at java.net.HttpURLConnection.getResponseCode(Unknown Source)
        at org.serviio.util.HttpClient.retrieveStreamFromConnection(HttpClient.java:173)
        at org.serviio.util.HttpClient.getStreamFromURL(HttpClient.java:103)
        at org.serviio.util.HttpClient.retrieveTextFileFromURL(HttpClient.java:42)
        at org.serviio.upnp.service.contentdirectory.rest.access.TuqPortCheckerProvider.isPortOpen(TuqPortCheckerProvider.java:20)
        at org.serviio.upnp.service.contentdirectory.rest.access.PortMappingChecker.isPortOpen(PortMappingChecker.java:39)
        at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.isSSLPortOpen(UserDataUpdater.java:178)
        at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.doUpdateUserData(UserDataUpdater.java:101)
        at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.access$200(UserDataUpdater.java:32)
        at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater$UserDataUpdaterRunner.run(UserDataUpdater.java:193)
        at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
        at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
        at java.lang.Thread.run(Unknown Source)
I haven't noticed it previously. Should I be worried?
Running serviio 1.9 on an ARM based nas box. Thanks
Post Tue Sep 19, 2017 10:45 pm
Re: WARN [UserDataUpdater] There was an error updating user
no that is fine
sutrus
Post Mon Sep 25, 2017 7:01 pm
I have the same problem. This is not fine.
NAS still wakes the HDD out of sleep and that's a problem.
How can I remove this warning from the log?
Post Tue Sep 26, 2017 9:23 am
I will look into it for 1.9.1
sutrus
Post Tue Sep 26, 2017 3:07 pm
Ok. Thanks
Post Wed Sep 27, 2017 7:51 am
Are you sure it's this warning that wakes the HDD?
sutrus
Post Wed Sep 27, 2017 8:11 pm
Yes. Warning every hour, as well as NAS HDD wakes up. I also tested various times of HDD sleep.
Everything probably started after updating on JRE 8.144.
My NAS is QNAP TS-420 RAM only 512MB
2017-09-27 19:19:06,096 INFO  [UserDataUpdater] Updating user data
2017-09-27 19:19:26,867 WARN  [UserDataUpdater] There was an error updating user data
   at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
   at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
2017-09-27 20:19:06,096 INFO  [UserDataUpdater] Updating user data
2017-09-27 20:19:26,967 WARN  [UserDataUpdater] There was an error updating user data
2017-09-27 21:19:06,096 INFO  [UserDataUpdater] Updating user data
2017-09-27 21:19:26,847 WARN  [UserDataUpdater] There was an error updating user data
Full last Log warning
2017-09-27 22:19:06,096 INFO  [UserDataUpdater] Updating user data
2017-09-27 22:19:26,857 WARN  [UserDataUpdater] There was an error updating user data
   at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
   at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
   at java.net.Socket.connect(Socket.java:589)
   at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
   at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
   at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
   at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
   at sun.net.www.http.HttpClient.New(HttpClient.java:339)
   at sun.net.www.http.HttpClient.New(HttpClient.java:357)
   at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1202)
   at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
   at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
   at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:966)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
   at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
   at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
   at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
   at java.lang.Thread.run(Thread.java:748)
Post Thu Sep 28, 2017 1:00 pm
So there are no other entries in the log between these that could also wake it up?
You could try to add this to the log4j.xml file
<category name="org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater">
      <priority value="ERROR"/>
   </category>
sutrus
Post Thu Sep 28, 2017 1:25 pm
I watched over night +- 8h. NAS activity is none (NAS log samba, ftp, http) and HDD was awakened 6x.
Serviio log has no other records except warnings.
log4j edited and restarting serviio. I will watch and send the result.
Thank you
sutrus
Post Fri Sep 29, 2017 7:05 am
Hi zip,
Last night all OK. NAS slept as a baby 8-)
Thank you for help
Post Tue Oct 03, 2017 9:07 am
good stuff
