Fewer movies "playable" by Sony XBR9 after upgrade to 0.5
kot
Post Sat Feb 05, 2011 4:42 pm
When I browse the Video->TItles offered by Serviio server, I still see a lot of first-characters, that ought to be available:
3
However, when I try to descend into many of them, the TV tells me, there is nothing to see there...
This was also a problem with release 0.4.2 -- the movie "300", for example, the sole entry under "3", never seemed acceptable to this TV... But now even some of the entries that the TV did accept before, aren't playable...
ffmpeg's details on the 300 MKV-file:
FFmpeg version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
  built on Dec 13 2010 02:00:11 with gcc 4.2.1 20070719  [FreeBSD]
  configuration: --prefix=/opt --mandir=/opt/man --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-a filter-lavf --enable-pthreads --enable-x11grab --enable-memalign-hack --cc=cc --extra-cflags=-msse -I/opt/include/vorbis -I/ pt/include --extra-ldflags=-L/opt/lib --extra-libs=-pthread --disable-debug --enable-libopencore-amrnb --enable-version3 --e able-libopencore-amrwb --enable-version3 --enable-libdirac --enable-libfaac --enable-nonfree --enable-libfaad --enable-libfa dbin --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora  -enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
[matroska @ 0x805652010]max_analyze_duration reached
[matroska @ 0x805652010]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (24000/1001)
Input #0, matroska, from '/green/movies/300.mkv':
    doctype         : matroska
    title           : -=HANSMER=-
  Duration: 01:56:32.57, start: 0.000000, bitrate: 384 kb/s
    Stream #0.0(eng): Video: h264, yuv420p, 1920x800, PAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
      title           : 300.2006.1080p.BluRay.x264
    Stream #0.1(rus): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
      title           : AC3, 6ch 384 kbps
    Stream #0.2(eng): Audio: dca, 48000 Hz, 6 channels, s16
      title           : DTS 5.1, 1536 kbps
    Stream #0.3(eng): Subtitle: 0x0000
FreeBSD port of Serviio is now in the tree. Please, try using it and share your experience.
Post Sun Feb 06, 2011 11:27 am
Re: Fewer movies "playable" by Sony XBR9 after upgrade to 0.
Do you have Bravia profile selected?
kot
Post Sun Feb 06, 2011 11:48 am
zip wrote:Do you have Bravia profile selected?
Do I have to explicitly select it? I thought, the player is automatically detected... Is that not the case?
Post Sun Feb 06, 2011 11:58 am
Yes, it should be. Just checking.
kot
Post Sun Feb 06, 2011 10:33 pm
zip wrote:Yes, it should be. Just checking.
No, the version 0.5 was using "Generic" profile... After I forced it to "Sony Bravia TV", more videos became available...
However, the movie "300" is still not available... If I go to the full list of titles, I see "3" as one of the first-letter virtual folders. But, when I try to descend into it, the TV says, there is nothing there... I already posted the ffmpeg-info for this one, below is the output of mediainfo -- just in case:
Complete name                    : /green/movies/300.mkv
Format                           : Matroska
File size                        : 11.2 GiB
Duration                         : 1h 56mn
Overall bit rate                 : 13.7 Mbps
Movie name                       : -=HANSMER=-
Encoded date                     : UTC 2008-01-08 15:33:43
Writing application              : mkvmerge v2.0.2 ('You're My Flame') built on Aug 15 2007 20:05:20
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Format profile                   : High@L5.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 8 frames
Muxing mode                      : Container profile=Unknown@5.1
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 56mn
Bit rate                         : 11.8 Mbps
Width                            : 1 920 pixels
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.321
Stream size                      : 9.39 GiB (84%)
Title                            : 300.2006.1080p.BluRay.x264
Writing library                  : x264 core 55 svn-663C
Encoding settings                : cabac=1 / ref=5 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=11806 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.3:15.0
Language                         : English
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1h 56mn
Bit rate                         : 384 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 320 MiB (3%)
Title                            : AC3, 6ch 384 kbps
Language                         : Russian
Audio #2
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 56mn
Bit rate                         : 1 510 Kbps
Bit depth                        : 24 bits
Stream size                      : 1.23 GiB (11%)
Title                            : DTS 5.1, 1536 kbps
Language                         : English
Text
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Language                         : English
Post Mon Feb 07, 2011 12:06 am
Can you get to the file via Folders category?
kot
Post Mon Feb 07, 2011 12:52 am
zip wrote:Can you get to the file via Folders category?
Nope... Not there either...
Post Mon Feb 07, 2011 9:23 am
Is the file there if you use AV Media Controller from Intel's tools?
kot
Post Mon Feb 07, 2011 3:22 pm
zip wrote:Is the file there if you use AV Media Controller from Intel's tools?
I guess, I'll have to try that Intel package, don't I... I wonder, if it will even work on FreeBSD... It may take me some time -- I'll get back to you.
But there are no other titles here, that begin with "3"... So, if the "3" is among the sub-folders under "Titles", then the file must be in the database...
kot
Post Mon Mar 28, 2011 3:43 am
kot wrote:However, the movie "300" is still not available...
I'm happy to report, that this -- and some other of my movies, that Bravia would not list before -- are now viewable and playable with 0.5.2. Thanks!
Post Mon Mar 28, 2011 7:22 am
Moderator: Topic moved to Sony
Does your "300.mkv" work with 0.5.2 version?
Because it is a H642 video with High@L5.1 profile.
Please, could you post your detailed Serviio logging (see signature) when you start transcoding this file ?
kot
Post Mon Mar 28, 2011 10:38 am
Illico wrote:Does your "300.mkv" work with 0.5.2 version?
Yes. There are other videos, that the TV refuses to list, but "300" is no longer among them. One "still bad" example is here (khm, are the dashes in the filename to blame?):
Complete name                    : /green/movies/Имя файла -заменено-.mkv
Format                           : Matroska
File size                        : 6.54 GiB
Duration                         : 1h 47mn
Overall bit rate                 : 8 737 Kbps
Encoded date                     : UTC 2009-08-14 13:00:04
Writing application              : mkvmerge v2.9.7 ('Tenderness') built on Jul  1 2009 18:43:35
Format profile                   : High@L4.1
Format settings, ReFrames        : 9 frames
Muxing mode                      : Container profile=Unknown@4.1
Duration                         : 1h 47mn
Bit rate                         : 7 227 Kbps
Width                            : 1 280 pixels
Height                           : 544 pixels
Display aspect ratio             : 2.35:1
Bits/(Pixel*Frame)               : 0.433
Stream size                      : 5.28 GiB (81%)
Title                            : Release for HDCLUB
Writing library                  : x264 core 68 r1183M f21daff
Encoding settings                : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_ochroma_qp_offset=-2 / threads=12 / nr=0 / decimate=0 / mbaff=0 / bframes=5 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=7227 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
Language                         : Russian
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 1h 47mn
Bit depth                        : 16 bits
Stream size                      : 1.13 GiB (17%)
Title                            : DTS 5.1 @ 1536 kbps
Language                         : Russian
Text
Format                           : UTF-8
Language                         : English
Do you still want the log-entries?
Post Mon Mar 28, 2011 3:55 pm
kot wrote:Do you still want the log-entries?
Yes please "300" is for the new serviio feature (higher profile detection) process verification.
And please also with your "still bad" example.
EDIT: Did you check that : viewtopic.php?f=6&t=1132 ?
kot
Post Tue Mar 29, 2011 4:34 am
Illico wrote:Yes please "300" is for the new serviio feature (higher profile detection) process verification.
Changing the logging configuration (to enable debug) would require a restart, which I can not do at the moment — grandparents are watching an operetta on their own TV, believe it or not... But here is, how the ffmpeg is launched for this movie by Serviio:
/opt/bin/ffmpeg -i /green/movies/300.2006.720p.BluRay.x264.Rus.mkv -y -threads 3 -vcodec mpeg2video -sameq -r 23.976 -g 15 -copyts -acodec copy -map 0:0 -map 0:1 -sn -f mpegts /fuji/Serviio/Serviio/transcoding-temp-17-MPEG2TS.stf
Can't do that, because the TV would not list these files — and so I can not even attempt to play them...
Well, my problem so far is not that the files would not play — it is that the TV would not even list them... So, I don't think, that tip applies to me, does it?
Thanks!
