Moving database onto another drive
BKKK
Post Sat Jun 09, 2018 11:43 pm
I am trying to use Serviio on a WHS V1 server which has only has a 20GB C drive partition. As I have about 2TB spare on my D drive I would like to move the database onto that.
I have found an old post about editing the services VMOPTIONS file and I was wondering if that is still current?
I would assume that I would need to stop serviio, move the database folder, edit the above file and than restart Serviio.
Note the database is already up to 6GB and hasn't finished indexing yet :(
bolzass
Post Sun Jun 10, 2018 9:46 am
Re: Moving database onto another drive
Sure!. It will work (-Dderby.system.home=/extdrive/serviio/library).
6GB for 2TB seems too much (unless all media are music files). I suggest finish migrating and then clean and compress database (there are some posts about that).
L.
Post Sun Jun 10, 2018 3:47 pm
I just checked the size of my Library folder (which contains the DB). It is at 209 MB, and this is for 3609 videos and 336 music files, spread across 16 TB of drive space. How many files do you have?
BKKK
Post Mon Jun 11, 2018 2:01 pm
I am trying to add my music collection of about 150,000 tracks
OK I moved the database and added the following to my vmoptions file
-DdbURL=jdbc:derby:D:/shares/Serviio
Serviio service starts runs for a few seconds then shuts down - no errors shown.
Anyone know what I am doing wrong?
Post Mon Jun 11, 2018 4:55 pm
Please upload your Serviio log here. It should have the error information.
BKKK
Post Tue Jun 12, 2018 11:07 am
OK I took the easy way out, I just reinstalled Serviio into my shared folder and it appears to be working fine.
Yes I will have to rescan all my folders but what the heck.
ps I did check the log and it would appear that it couldn't find the database?
Post Tue Jun 12, 2018 1:51 pm
BKKK wrote:OK I took the easy way out, I just reinstalled Serviio into my shared folder and it appears to be working fine.
Well, that explains why the Serviio service was stopping. Doesn't explain why it couldn't find the DB though. Anyway, glad you have it running again.
freaknik
Post Thu Jun 14, 2018 7:38 pm
BKKK wrote:Note the database is already up to 6GB and hasn't finished indexing yet :(
Bro mine is 750mb database for 2tb drive.
6gb seems way overkill, I bet there was some overlap or redundancy.
mjb
Post Fri Jun 15, 2018 1:42 am
On my Win7 box, I stopped the Serviio service, moved my library and log folders to another drive, and replaced them with symlinks:
c:
mkdir "F:\Serviio library & log"
cd "\Program Files\Serviio"
mv library "F:\Serviio library & log"
mv log "F:\Serviio library & log"
mklink /d library "F:\Serviio library & log\library"
mklink /d log "F:\Serviio library & log\log"
As far as Serviio knows, the folders are still in their original locations.
