Impossible to stream some online sources
loscar
Post Sun Jun 10, 2018 11:09 am
Dear all,
I'm using Serviio for more than a year, to stream movies & music from my computer to my Sony Bravia 2011 TV, and it works like a charm !
Recently, I saw Serviio is able to stream online contents, so I'm giving a try. After having solved the "no sound" issue, I'm now faced with a big issue... some contents are not streaming and others are. I even have contents who never stream, others always stream, and some stream sometimes... It's going to make me crazy !
I've activated the debug log file (servio.log), and below are an example of one working stream, and one non working stream (I've replaced URL by "http://path_to_online_stream").
OK STREAM:
2018-06-10 12:21:19,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2018-06-10 12:21:29,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2018-06-10 12:21:36,897 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:45602: HEAD /resource/1000002020001359/MEDIA_ITEM/AVC_TS_HP_HD_MPEG1_L2_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:21:36,897 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:36,898 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:36,899 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:36,899 DEBUG [ResourceDeliveryProcessor] Request for resource 1000002020001359 and type 'MEDIA_ITEM' received
2018-06-10 12:21:36,899 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:36,900 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000002020001359, format AVC_TS_HP_HD_MPEG1_L2_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:21:36,902 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:21:36 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:21:36,917 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:45603: GET /resource/1000002020001359/MEDIA_ITEM/AVC_TS_HP_HD_MPEG1_L2_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:21:36,917 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:36,918 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:36,919 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:36,919 DEBUG [ResourceDeliveryProcessor] Request for resource 1000002020001359 and type 'MEDIA_ITEM' received
2018-06-10 12:21:36,919 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:36,920 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000002020001359, format AVC_TS_HP_HD_MPEG1_L2_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:21:36,921 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:36,922 DEBUG [VideoDeliveryEngine] Delivering item '1000002020001359' for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:36,923 DEBUG [VideoDeliveryEngine] Delivering file 'http://path_to_online_stream/1847.ts' in native format
2018-06-10 12:21:36,925 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-06-10 12:21:36,925 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:21:36 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:21:36,925 INFO [PlaybackEventsManager] Playback of media item 1000001010001166 (http://path_to_online_stream/360.ts [http://path_to_online_stream/360.ts]) has stopped at 0% on Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:21:36,926 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2018-06-10 12:21:36,927 INFO [PlaybackEventsManager] Playback of media item 1000002020001359 (http://path_to_online_stream/1847.ts [http://fpath_to_online_stream/1847.ts]) has started at 0% on Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:21:36,995 DEBUG [OnlineInputStream] 302 returned, redirecting to http://path_to_online_stream/1847.ts?to ... 5HUVcBDhEe
2018-06-10 12:21:36,995 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2018-06-10 12:21:37,125 DEBUG [OnlineInputStream] Byte range not supported for http://path_to_online_stream/1847.ts?to ... 5HUVcBDhEe, returning the whole stream
2018-06-10 12:21:39,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2018-06-10 12:21:40,497 DEBUG [OnlineInputStream] Closing stream
2018-06-10 12:21:40,498 DEBUG [WebServer] I/O error: Broken pipe (Write failed)
2018-06-10 12:21:40,501 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:45604: GET /resource/1000002020001359/MEDIA_ITEM/AVC_TS_HP_HD_MPEG1_L2_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:21:40,501 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:40,502 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:40,502 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:40,502 DEBUG [ResourceDeliveryProcessor] Request for resource 1000002020001359 and type 'MEDIA_ITEM' received
2018-06-10 12:21:40,503 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:40,503 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000002020001359, format AVC_TS_HP_HD_MPEG1_L2_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:21:40,504 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:40,505 DEBUG [VideoDeliveryEngine] Delivering item '1000002020001359' for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:40,506 DEBUG [VideoDeliveryEngine] Delivering file 'http://path_to_online_stream/1847.ts' in native format
2018-06-10 12:21:40,506 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-06-10 12:21:40,506 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:21:40 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:21:40,506 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2018-06-10 12:21:40,555 DEBUG [OnlineInputStream] 302 returned, redirecting to http://path_to_online_stream/1847.ts?to ... 5HUVcBDhEe
2018-06-10 12:21:40,555 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2018-06-10 12:21:40,639 DEBUG [OnlineInputStream] Byte range not supported for http://path_to_online_stream/1847.ts?to ... 5HUVcBDhEe, returning the whole stream
2018-06-10 12:21:43,921 DEBUG [TimeoutStreamDelegator] Closing piped input stream and closing related feeder process
2018-06-10 12:21:43,922 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-122,5,main]
2018-06-10 12:21:43,925 DEBUG [ProcessExecutor] Starting kill -9 403
2018-06-10 12:21:43,932 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2018-06-10 12:21:43,933 DEBUG [AbstractAVTranscodingDeliveryEngine] Removing transcoding job 'transcoding-temp-208c3e6a275c74ab3e94e70bb7c4b5e2.stf' of client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
KO Stream:
2018-06-10 12:16:49,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2018-06-10 12:16:53,694 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:46263: HEAD /resource/1000003010001441/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:16:53,695 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:16:53,696 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:53,696 DEBUG [ResourceDeliveryProcessor] Request for resource 1000003010001441 and type 'MEDIA_ITEM' received
2018-06-10 12:16:53,696 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:53,696 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000003010001441, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:16:53,697 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file http://path_to_online_stream/184.ts
2018-06-10 12:16:53,697 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:53,697 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:16:53 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:16:53,712 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:46264: GET /resource/1000003010001441/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:16:53,712 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:16:53,712 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:53,712 DEBUG [ResourceDeliveryProcessor] Request for resource 1000003010001441 and type 'MEDIA_ITEM' received
2018-06-10 12:16:53,712 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:53,713 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000003010001441, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:16:53,713 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file http://path_to_online_stream/184.ts
2018-06-10 12:16:53,713 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:53,713 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:53,713 DEBUG [VideoDeliveryEngine] Delivering item '1000003010001441' for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:53,713 DEBUG [VideoDeliveryEngine] Delivering file 'http://path_to_online_stream/184.ts' using transcoding
2018-06-10 12:16:53,714 DEBUG [AbstractAVTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:53,714 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://path_to_online_stream/184.ts
2018-06-10 12:16:53,714 DEBUG [ProcessExecutor] Starting /usr/bin/ffmpeg -fflags +genpts -threads 0 -analyzeduration 10000000 -i http://path_to_online_stream/184.ts -y -threads 0 -c:v copy -c:a:0 ac3 -b:a:0 384k -ac:a:0 2 -map 0:0 -map 0:1 -sn -f mpegts pipe:
2018-06-10 12:16:54,214 DEBUG [StreamBasedTranscodingDeliveryStrategy] Adding client to stream multiplexer: Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:54,714 DEBUG [StreamBasedTranscodingDeliveryStrategy] Already multiplexing stream output to client: Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:54,715 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:54,715 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-06-10 12:16:54,715 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2018-06-10 12:16:54,715 INFO [PlaybackEventsManager] Playback of media item 1000003010001441 (http://path_to_online_stream/184.ts [http://path_to_online_stream/184.ts]) has started at 0% on Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:54,716 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:16:54 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:16:58,490 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2018-06-10 12:16:58,490 DEBUG [WebServer] I/O error: Broken pipe (Write failed)
2018-06-10 12:16:58,494 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:46265: GET /resource/1000003010001441/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:16:58,494 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:16:58,495 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:58,495 DEBUG [ResourceDeliveryProcessor] Request for resource 1000003010001441 and type 'MEDIA_ITEM' received
2018-06-10 12:16:58,495 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:58,495 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000003010001441, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:16:58,496 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file http://path_to_online_stream/184.ts
2018-06-10 12:16:58,496 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:58,496 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:58,497 DEBUG [VideoDeliveryEngine] Delivering item '1000003010001441' for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:58,497 DEBUG [VideoDeliveryEngine] Delivering file 'http://path_to_online_stream/184.ts' using transcoding
2018-06-10 12:16:58,497 DEBUG [AbstractAVTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:58,498 DEBUG [StreamBasedTranscodingDeliveryStrategy] Already multiplexing stream output to client: Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:59,370 DEBUG [PipedOutputStreamMultiplexer] Caught exception: Read end dead
java.io.IOException: Read end dead
at java.io.PipedInputStream.checkStateForReceive(PipedInputStream.java:262)
at java.io.PipedInputStream.receive(PipedInputStream.java:226)
at java.io.PipedOutputStream.write(PipedOutputStream.java:149)
at org.serviio.external.io.PipedOutputStreamMultiplexer$3.call(PipedOutputStreamMultiplexer.java:87)
at org.serviio.external.io.PipedOutputStreamMultiplexer$MultiplexCaller.multiplex(PipedOutputStreamMultiplexer.java:119)
at org.serviio.external.io.PipedOutputStreamMultiplexer.write(PipedOutputStreamMultiplexer.java:89)
at org.serviio.external.io.PipedOutputBytesReader.processOutput(PipedOutputBytesReader.java:58)
at org.serviio.external.io.OutputReader.run(OutputReader.java:47)
2018-06-10 12:16:59,371 DEBUG [PipedOutputStreamMultiplexer] Removing client from multiplexer: Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:59,498 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:59,498 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-06-10 12:16:59,498 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2018-06-10 12:16:59,499 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:16:59 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:16:59,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
Serviio server is running on Linux ubuntu.
Many many thanks for your help... before I'm becoming fully crazy !
Post Sun Jun 10, 2018 3:43 pm
Re: Impossible to stream some online sources
Many online sources require some sort of plug-in. Since you haven't identified the site you are attempting to access, I can't offer much more than that. You could browse the plug-in forum (viewforum.php?f=20) and see if your site might already have one.
loscar
Post Mon Jun 11, 2018 6:47 pm
Hello Dan,
Thanks for your feedback. Actually, both sources are .ds sources, and I've tried with ffmpeg and they all work... (also successfully tested with VLC). So I don't think there"s a missing plug-in.
Do you know how I can have aa even more detailed log file ?
Post Mon Jun 11, 2018 9:38 pm
You can enable detailed logging by following the link in my sig.
loscar
Post Sun Jun 17, 2018 4:59 pm
I've already setup this detail level of log... is there a way to have even more detailed ?
Post Sun Jun 17, 2018 6:24 pm
Sorry, I didn't notice you had debug enabled in what you posted above. No, there's no other level of logging available. I'm not knowledgeable about online sources, so someone else will need to chime in here with any suggestions.
